POV-Ray : Newsgroups : povray.beta-test : Skysphere problem Server Time
10 Nov 2026 21:59:58 EST (-0500)
  Skysphere problem (Message 1 to 5 of 5)
Subject: Skysphere problem
Date: 11 Mar 2002 08:38:42
Message: <3c8cb362@news.povray.org>
Skysphere seems to be misbehaving in the following scene:
global_settings {
  assumed_gamma 1.0
  max_trace_level 5
  location  <0.0, 0.5, -4.0>
  look_at   <0.0, 0.0,  0.0>
sky_sphere {
    gradient y
    color_map {
      [0.0 rgb <0.6,0.7,1.0>]
      [0.7 rgb <0.0,0.1,0.8>]
light_source {
  <0, 0, 0>
  color rgb <1, 1, 1>
  translate <-30, 30, -30>
Subject: Re: Skysphere problem
Date: 11 Mar 2002 08:43:26
Message: <3C8CB4C0.FE8DF5E0@pacbell.net>
I don't see anything wrong with it. Perhaps you could be more specific
about what *you* think is wrong.
Ken Tyler
Date: 11 Mar 2002 08:44:44
Message: <k2dp8ucc77pjqh9f3d0t2dsh0u955gm74t@4ax.com>
On Mon, 11 Mar 2002 13:38:53 -0000, "James Philbin" <phi### [at] csicom> wrote:
What exactly you mean ? Have you verified your observation with "Gradient"
section of "Patterns" chapter (6.7.11.17) ? Have you noticed new behaviour of
3.5 in this subject ?
ABX
Date: 11 Mar 2002 09:07:20
Message: <3c8cba17@news.povray.org>
  As ABX mentioned, it could be the modified behaviour of the gradient pattern.
Date: 11 Mar 2002 09:09:21
Message: <3c8cba90@news.povray.org>
By the way, could you read the bug reporting guidelines?
  Your post lacks the used POV-Ray version, your hardware and OS
specifications and the description of the potential bug.
