POV-Ray : Newsgroups : povray.beta-test : Spline inconsistencies Server Time
29 Oct 2026 12:13:11 EDT (-0400)
  Spline inconsistencies (Message 45 to 54 of 54)
<<< Previous 44 Messages Goto Initial 50 Messages
Subject: Re: Spline inconsistencies
Date: 23 Feb 2002 14:08:36
Message: <3c77e8b4@news.povray.org>
Christopher James Huff <chr### [at] maccom> wrote:
> There's room for improvement, but what's there is a good
> start, and is very useful as is.
  Yes, but what I am saying is that the improvements should be made *now*,
not some time in the future, because improvements will most probably need
a syntax change which will break backwards compatibility.
Date: 23 Feb 2002 14:11:43
Message: <3c77e96e@news.povray.org>
Mark Wagner <mar### [at] gtenet> wrote:
>>  By the way, any chance of making the time values optional?
> No.  The time for feature requests is over, particularly for difficult
> feature requests such as this.
  Adding support for catmull-rom splines was a feature request, which is
being considered.
  I was just suggesting that as someone is going to make changes to the
spline code anyways, if he could go a bit further.
Date: 23 Feb 2002 15:10:50
Message: <chrishuff-D3CCEA.15104223022002@netplex.aussie.org>
In article <3c77e8b4@news.povray.org>, Warp <war### [at] tagpovrayorg>
I don't think so...it would be fairly easy to support the current syntax
along with a new one. Brackets (either {} or []) could be added now to
prevent having to do this though...I'd use [] for consistency with
*_maps.
Date: 23 Feb 2002 16:30:23
Message: <3c7809ef@news.povray.org>
"Warp" wrote:
>   You didn't get my point: I was complaining about
> *forcing* each time value to be specifically written.
I think you didn't get my point: You are not forced to specifically write
each time value when you can have a macro do it for you.
Rune
Rune's World:    http://rsj.mobilixnet.dk (updated Feb 16)
Date: 23 Feb 2002 19:39:08
Message: <3c78362b@news.povray.org>
  I think it would be quite difficult and a bit cumbersome to make a
macro which supports optional time values (ie. any point can have a time
value or not).
Date: 23 Feb 2002 20:09:59
Message: <3c783d67@news.povray.org>
> cumbersome to make a macro which supports optional
> time values (ie. any point can have a time value or not).
Then we must make such a macro and include it in the standard distribution
so the user don't have to fiddle with it. I volunteer to make it.
Rune
Date: 24 Feb 2002 01:03:32
Message: <3c788234@news.povray.org>
Warp wrote in message <3c77e96e@news.povray.org>...
>being considered.
When I re-wrote the MegaPOV spline code, I deliberately made it easy to add
more spline types.  Consequently, doing so will probably take about two to
three hours to implement and debug.
The work needed to add catmull-rom splines:
Add a catmull_rom_interpolate() function to splines.cpp
Add one "case" statement to the switch statement in Get_Spline_Val() in
splines.cpp
Add a #define for catmull-rom splines to the splines.h file
Add a CASE(CATMULL_ROM_SPLINE_TOKEN) to Parse_Spline() in express.cpp
Add a CASE(CATMULL_ROM_SPLINE_TOKEN) to Parse_Num_Factor() in express.cpp
Possibly add the definition of "catmull_rom_spline" and
"natural_cubic_spline" to parse.h and tokenize.cpp
The work needed to add optional time values to splines:
A partial re-write of the Parse_Spline() function
A re-write of Insert_Spline_Entry()
Adding a "Post_Spline()" function to compute the time values that were not
given once parsing the spline is complete.
Far more time spent debugging this feature than I will have available in the
next few months
Mark
Date: 24 Feb 2002 09:51:52
Message: <3c78fe08@news.povray.org>
"Warp" wrote:
>   Eh, you didn't understand what I meant: I meant that
> a macro would be cumbersome because of limited syntax
> capabilities.
The suggested syntax I've described in the other thread is not *that*
cumbersome. You have to write a few more characters per point, yes, but
complaining about that is most of all nit-picking IMO.
> Using an "illegal" value to mean optionality is not
> very handy either (in a worst case scenario you would
> have to write tens or even hundreds of these "optional"
> time values even though you are using just two or three
> regular time values).
Copy and paste.
>   The idea was that you don't have to write any time
> value for those points which you want to be calculated
> automatically.
I must admit that it would make it better for the purposes of obfuscated
signatures. Pity eh?
Rune
Date: 24 Feb 2002 12:12:36
Message: <3c791f04@news.povray.org>
You might want to check with Thorsten, but I think it was more or less
decided to call the catmull-rom spline for "cubic_spline" and the natural
cubic spline for "natural_spline".
Rune
Date: 24 Feb 2002 13:07:52
Message: <3c792bf8$1@news.povray.org>
In article <3c788234@news.povray.org> , "Mark Wagner" <mar### [at] gtenet>
> splines.cpp
If you just do this part, I can easily do the rest while integrating the code.
You can test it by temporarily using the cubic_spline option or something -
integrating parser code based on pre-3.5 code would take more time than
writing it from scratch...
    Thorsten
e-mail: tho### [at] trfde
