![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
KNOWN BUGS
Re: trivial question on topic (job000038)
(Poly Object Bug: heart has a dark line of artifacts)
http://news.povray.org/3BEBEB4C.CA854309@pacbell.net
Highlight bug (job000137)
(highlights are sometimes visible where they should be in shadow)
http://news.povray.org/3bb4cf08@news.povray.org
Macro bug (job000146)
(POV can dereference a deallocated pointer if you return a local from a
macro.)
http://news.povray.org/3BB4ED11.8EC69CEC@hotmail.com
(also reported as: strings operations crash with both compiles
http://news.povray.org/e3piut8anmf4cli4pnfmstadgc3nleqvb2@4ax.com)
Radiosity sampling, with fix method (job000177)
(radiosity sample counter is reset to the start every time, sampling
artefacts are produced)
http://news.povray.org/3BC5A13E.9C022BD6@reading.ac.uk
Strange spline problem (job000181)
(Changes from render to render. Control points are sometimes missing.)
http://news.povray.org/Xns9136AC2E64F60seed7@povray.org
Spline bug (job000182)
(The spline path is all wrong when certain time values are used.)
http://news.povray.org/3bb41dc8@news.povray.org
Blob problem (job000189)
and Blob : Toward a solution
(blob surface develops holes when "radius" is very small)
http://news.povray.org/3b99052c@news.povray.org
http://news.povray.org/3B991C90.D715B7A3@free.fr
Additional (?) blob bug (job000189)
(blob component disappears when radius is 317 or greater)
http://news.povray.org/Xns9115B92CF7D8ACQ@204.213.191.226
(also reported as: Blob rendering error (job000136))
http://news.povray.org/Xns91203DC7F3CCQ@204.213.191.226
Bug with blobs and media (job000189)
(possibly related to blob surface develops holes when "radius" is very
small)
http://news.povray.org/3be5f0b2@news.povray.org
Blob component textures transformed twize (job000189)
http://news.povray.org/3bf70645@news.povray.org
Superellipsoid epsilon to big ? (job000190)
(strange dark patches occur on a superellipsoid when the east-west-
exponent is set very small)
http://news.povray.org/3b992a81@news.povray.org
Slow rendering when using +ua and antialiasing method 1 (job000191)
(No details available)
http://news.povray.org/3bbf6347@news.povray.org
Bug: dispersion_samples affects photon brightness (job000193)
(higher dispersion_samples also gives brighter refractive photons)
http://news.povray.org/MPG.1631c5fca936293298969e@news.povray.org
Another strange photon behavior (job000195)
(a: bright colored caustics. b: holes/circular black spots)
http://news.povray.org/MPG.16510f3e44067d3f9896ae@news.povray.org
panoramic projection bug? (job000196)
(When "angle" keyword within camera statement appears after "panoramic"
keyword then looks like ignored.)
http://news.povray.org/avnfut8fof5ualgf8hnrtpl1knlg8828sp@4ax.com
Light_sources in light_groups don't cast shadows (job000197)
(rendering without light buffers (-UL) puts the shadows back)
http://news.povray.org/3bfd4d63@news.povray.org
no_image, merge and shadows (job000198)
(setting no_image to an object in a merge causes that object to stop
casting shadows)
http://news.povray.org/vqfd0ucm5276q9j8sdh34afjliapc1kj0n@4ax.com
Re: triangle texture interpolation (job000199)
(the second texture is on the first point and the third texture is used
on the second and third points)
http://news.povray.org/3C0A8288.DDA0905B@free.fr
bug in sphere_sweep for removing parts of an object (job000200)
(discontinuous normals on inverse of sphere_sweep)
http://news.povray.org/3C1A5D47.EA38F6E5@amc.uva.nl
color dot operators (job000201)
((Color.red) doesn't work as a macro parameter)
http://news.povray.org/ofpr1ug9r6q3cak417pmj72bck6ufmgbtg@4ax.com
Bicubic patch triangles disappear (job000202)
(When the triangles are fairly small)
http://news.povray.org/3c23b26c@news.povray.org
Array assignment crash (job000203)
(It should overwrite the old array with the newly created, correct
array, but crashes)
http://news.povray.org/3bcc54ab$1@news.povray.org
Photon Problems (job000204)
(Rendering the file makes the image strangely bright)
http://news.povray.org/3bc4d0a9$1@news.povray.org
crash during debugging of parsing (job0205)
http://news.povray.org/332m2uspk9nfqfq6g7oc8qtmkcu5higjs7@4ax.com
crash with loop (job000205)
(infinite loop of "#local"s causes stack fault)
http://news.povray.org/3c2cb9b7@news.povray.org
#macro crush (job000206)
http://news.povray.org/3c2c78cf$1@news.povray.org
double_illuminate only works with direct lighting (job000207)
http://news.povray.org/3BF6F1FE.D21B0C6@oreka.com
Isosurfaces *much* slower in beta 7?
(isosurfaces with "evaluate" are now very slow)
http://news.povray.org/3bdf24b3$1@news.povray.org
Strange alpha channel bug
(assumed_gamma affects the transparency of shadowed areas)
http://news.povray.org/3c1168c5$1@news.povray.org
Slow render time after several runs
(when stopped during radiosity calculations and restarted)
http://news.povray.org/3bd40c6d$1@news.povray.org
problem with transparent image_maps
(Objects with transparent image_maps have "non-transparent" shadows)
http://news.povray.org/3c24d1b3@news.povray.org (cancelled)
http://news.povray.org/eGSwuBAritK8EwLH@econym.demon.co.uk
CSG difference with text
(Text objects appear to be very slightly tilted)
http://news.povray.org/3c304eaf@news.povray.org
Julia object bug (Michael McKnight)
(Looks rather like coincident surfaces)
http://news.povray.org/3839f08c@news.povray.org
crash with some boxes /infinite boxes
http://news.povray.org/3c375d62$1@news.povray.org
#while crash..
http://news.povray.org/3c38646f@news.povray.org
Mapping warp and render window bugs
(Object lighting is calculated incorrectly when mapping warps are used
in normals and the object is rotated)
http://news.povray.org/Xns9190F27EBFE9Bcsbhccse@204.213.191.226
Small window title bug
(Title switches back to "POV-Ray for Windows" after minimize or
restore.)
http://news.povray.org/3ba92966$1@news.povray.org
Black outline in smooth meshes
(The outline of smooth meshes exhibit black dots or areas (which go away
with double_illuminate))
http://news.povray.org/3bf6794e$1@news.povray.org
Camera is off by half a pixel
http://news.povray.org/3bccc696@news.povray.org
Crash with no objects in scene
(Doesn't happen on most people's machines)
http://news.povray.org/3bd985b0@news.povray.org
(also reported as http://news.povray.org/3C19B9EA.D2E16FBC@gmx.de)
Render Window Bug
(Render window pops up when application minimised, after which the
application doesn't open when clicked on the task bar.)
http://news.povray.org/3bde157e@news.povray.org
Povray main window disappears during rendering
(Possibly the same as the above)
http://news.povray.org/3c1350f4@news.povray.org
installer behaves strangely
(one would expect povray to install after pressing the "next" button and
not the "button")
http://news.povray.org/Xns916AE9B08012frankverlaathotmailc@204.213.191.2
26
Keep Single Instance (always does, no matter setting)
(Partially fixed)
http://news.povray.org/3c0b0881$1@news.povray.org
Little bug in the editor?
(can get confused about whether the file is saved)
http://news.povray.org/3a1e2559@news.povray.org
tiff problems in reading (including crash, including [doc])
(LZW decompression fails. 4-bit scrambles the colours. 1-bit and 24-bit
upside down. JPG decompression crashes)
http://news.povray.org/n96b3uk1ft7mvb991s3htjt14ekb7j8fn7@4ax.com
Little render window bug?
(If either the width or the height of an image you're rendering is
bigger than the screen's size, then the sliders of the render windows
show in both (height and width) sizes and you can't see the full image
at once, even if one of the image_sizes is smaller than the screen)
http://news.povray.org/3c3746d6@news.povray.org
silly winpov bug
(Double clicking the title bar on some machines causes "text selection
not supported")
http://news.povray.org/3c3b7a3f@news.povray.org
non hollow flat disc
http://news.povray.org/mi9t3uophkvlv9hfah5uv7enn2pamhuvd7@4ax.com
crash inside two #while
(Possibly specific to Windows 2000)
http://news.povray.org/3c3f1f29$1@news.povray.org
Strange Sphere_Sweep bounding boxes
(bounding box always includes point <0,0,0>)
http://news.povray.org/3bcbcbb7$1@news.povray.org
Possible bug with blobs
(holes in blob surface when an invisble object is nearby)
http://news.povray.org/3c407ad3$1@news.povray.org
bug : declared camera with normal statement crashes
http://news.povray.org/3C41A226.7030703@skynet.be
FIXED IN NEXT BETA
sin(X)^sin(X) -> crash! (job000179 and job000180)
http://news.povray.org/3baf7992@news.povray.org
Delayed syntax checking (job000192)
(declare without the "#" can cause a much later line to fail to parse
Parser will ignore the first token following old-style declares without
a #.)
http://news.povray.org/AM3LOAABMO27EwFh@econym.demon.co.uk
Jpeg and memory problem during animations (job000194)
(It seems that some memory is not properly released between frames when
a jpeg file is used)
http://news.povray.org/3be2ef0d@news.povray.org
[bug] orthographic camera bug? (job000208)
(objects sometimes disappear when the orthographic camera is used)
http://news.povray.org/3bdca5eb@news.povray.org
Isosurface : 2 bugs
(int() causes crash)
http://news.povray.org/3c082dbe@news.povray.org
Function (optimization?) bug
('funciton{-y/1/2}' should be same as 'function{-y/1/(2)}')
http://news.povray.org/3c27fd29$1@news.povray.org
another crash with max_intersections
http://news.povray.org/j8fo2u8mbo97gi3as0udmab7t9ttap2iom@4ax.com
IsoCacti.pov
(displays 754 evaluate warnings, most with incorrect values)
http://news.povray.org/3c08c36c$1@news.povray.org
VRand_in_Obj function - syntax error
(Stream value should be last, rather than first)
http://news.povray.org/3bc423e5@news.povray.org
User_Abort_Command
(User_Abort_Command does not seem to work at all)
http://news.povray.org/Xns913D9F7268736seed7@povray.org
Re: Known Bugs 24 Dec 2001 (beta 9)
(garbage text in Mac message window)
http://news.povray.org/3C2A7123.E923B0B4@spiritone.com
Linux commandline
(-help causes loop)
http://news.povray.org/3c3edf08@news.povray.org
light_group+media bug
http://news.povray.org/MPG.160834111f191173989688@news.povray.org
Mike Williams
Gentleman of Leisure
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
In article <rsJ### [at] econym demon co uk> , Mike Williams
Excuse me, but I am slowly getting upset you continue to fail to take this
off the list. There is no point in keeping a list of bugs if you keep
things on there that have been explained as user errors several times...
Thorsten
e-mail: tho### [at] trf de
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
On Mon, 14 Jan 2002 06:06:37 +0000, Mike Williams <mik### [at] nospam please> wrote:
perhaps nothing important but your comment in () is mistaken becouse in original
post it sounds "looks like a 'coincident surfaces' type of problem, though of
course it is not."
ABX
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> KNOWN BUGS
perhaps I've read it not carefully but you probably missed some my reports
Crash with redeclared functions
http://news.povray.org/q6g83u4egq3ts0m8ip5nkn5lf0ljkacu8g%404ax.com
(Thorsten said it is not legal syntax but there is still bug becouse of crash)
Not catched function redeclaration
http://news.povray.org/tis83ugh1kcc22h5o6is9qpkv61pjgunc0%404ax.com
(Thorsten said it is not catched illegal syntax, perhaps the same job number as
above)
Function declaration and namespace
http://news.povray.org/l2ji3uc2k9su99o2gct3n2thgqoq7f4pd5%404ax.com
Wrong highlighting in editor (function_id)
http://news.povray.org/jfji3ug1faevn1jk3mlko64sb71ptmmn97%404ax.com
Splines - not working legal statement
http://news.povray.org/m7fq3u41ctia9e6i3tbnlstn6ek739vpke%404ax.com
ABX
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
job000209, by the way. Fixed, but probably not in beta 10.
#macro R(L P)sphere{L __}cylinder{L P __}#end#macro P(_1)union{R(z+_ z)R(-z _-z)
R(_-z*3_+z)torus{1__ clipped_by{plane{_ 0}}}translate z+_1}#end#macro S(_)9-(_1-
_)*(_1-_)#end#macro Z(_1 _ __)union{P(_)P(-_)R(y-z-1_)translate.1*_1-y*8pigment{
rgb<S(7)S(5)S(3)>}}#if(_1)Z(_1-__,_,__)#end#end Z(10x*-2,.2)camera{rotate x*90}
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>> KNOWN BUGS
Tracking these was a bit of a nightmare because some of them arrived on
my newserver with completely different subject lines and subtly
different message ids. I can search my article database by either of
those fields, or by author (but you wrote so many!).
Original Subject: crash during function creation in loop
Isn't this already reported in the thread that Thorsten referred you to?
>above)
Original Subject: can't redefine identifier
OK
I got totally confused by this thread, and can't seem to see if anything
ever actually got confirmed, and if so, what.
Unconfirmed
Original Subject: splines - documentation and reality
I'm not logging documentation errors. If there's anything there that's
not a documentation error, then I believe it's unconfirmed.
Mike Williams
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
BTW, I've read that the "good" camera will function only with
"#version 3.5" set. Is that true ?
Fabien.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
It's supposed to be. Guess I should implement that part. :)
plane{-z,-3normal{crackle scale.2#local a=5;#while(a)warp{repeat x flip x}rotate
z*60#local a=a-1;#end translate-9*x}pigment{rgb 1}}light_source{-9red 1rotate 60
*z}light_source{-9rgb y rotate-z*60}light_source{9-z*18rgb z}text{ttf"arial.ttf"
"RP".01,0translate-<.6,.4,.02>pigment{bozo}}light_source{-z*3rgb-.2}//Ron Parker
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
It is now.
#macro R(L P)sphere{L F}cylinder{L P F}#end#macro P(V)merge{R(z+a z)R(-z a-z)R(a
-z-z-z a+z)torus{1F clipped_by{plane{a 0}}}translate V}#end#macro Z(a F T)merge{
P(z+a)P(z-a)R(-z-z-x a)pigment{rgbf 1}hollow interior{media{emission 3-T}}}#end
Z(-x-x.2x)camera{location z*-10rotate x*90normal{bumps.02scale.05}}
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Fabien Mosen <fab### [at] skynet be> wrote:
: BTW, I've read that the "good" camera will function only with
: "#version 3.5" set. Is that true ?
If the default value of 'version' is '3.5', then you don't have to
explicitly write that.
It just means that if you write "#version 3.1" or smaller it won't work.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
