POV-Ray : Newsgroups : povray.beta-test : the lowest pixel getting dimmed Server Time
10 Nov 2026 22:52:12 EST (-0500)
  the lowest pixel getting dimmed (Message 1 to 22 of 22)
Subject: the lowest pixel getting dimmed
Date: 21 Dec 2001 19:00:19
Message: <3c23cd13@news.povray.org>
Hi!
I know this will be a wired description (and sorry for the headline),
but I try:
Render an animation of this one:
about 50 (or 100) frames (AA) height:3 width:20
///start
default { finish {ambient 1}}
/// +w20 +h3
#local F = function(x,y,z) {1-min(abs(z),1)}
box {-1,1
  function {F(x,y,z)}
  color_map {
   [0.0 color rgb 0]
   [1.0 color green 1]
  scale .4
 rotate y*90
 location <0,1,0>
 orthographic
 right <1,0,0>*2
 up <0,1,0>*2
 look_at 0
 translate x*sin(clock*2*pi)
///end
(it was written to make a vertical "copper" - this kind of
assemblertrick: moving a colored bar in the background in textmode -
but vertical)
Make the renderwindow fullscreen and look at the lowest of the three
pixel while realtime-rendering: The first half of the animation they
are as bright as the ones above, the other half they are somewhat 50%
dimmed.
I don't know what it's comming from lowering up and right in the
camera reduces but doesn't solve the problem.
It was working with beta 8 - something has to be changed.
amd 1.4GHz Win98
thank you for looking into this!
Kalle
Subject: Re: the lowest pixel getting dimmed
Date: 22 Dec 2001 03:55:46
Message: <5ar55HAAEBJ8EwXk@econym.demon.co.uk>
>dimmed.
When I make it full screen, I just get a white panel and the text
"StretchDIBits () failed ! (Windows Error)". This seems to happen when w
is less than 38 and h is less than 9.
POV 3.5b8, Win 98se, Celeron II 850, 128 Mb
I observe no dimming on the images that are produced when I look at them
later.
Mike Williams
Gentleman of Leisure
Date: 22 Dec 2001 04:54:04
Message: <3c24583c$1@news.povray.org>
hmm. For that matter you may use +w38 +h9 - I can still see the lowest row of
pixels very good and dimmed...
do you meant really beta 8? Am I too early with beta9 - having downloaded it
without an official announcement in this group? I'm soory then. But maybe it
was just a typo...
> later.
Now, I have to search for another one to confirm this
(but its you, keeping the buglist...)
using msvc compile I got the same behaviour: the lowest row is dimmed for the
second half of the animation...
cukk
Date: 22 Dec 2001 05:02:13
Message: <3c245a25@news.povray.org>
In article <3c24583c$1@news.povray.org> , "KalleK" <kal### [at] gmxde> wrote:
What does it look like in the _output_ image on disk?
    Thorsten
Date: 22 Dec 2001 06:16:57
Message: <3c246ba9@news.povray.org>
Mike Williams <mik### [at] nospamplease> wrote:
: POV 3.5b8, Win 98se, Celeron II 850, 128 Mb
  How did you manage getting beta8 to work after the expiration period?
Date: 22 Dec 2001 06:35:31
Message: <3c247003$1@news.povray.org>
Is this some kind of trick question?
Setting back the clock is relly not that hard...
Rune
Rune's World:    http://rsj.mobilixnet.dk (updated Nov 5)
Date: 22 Dec 2001 08:32:25
Message: <3c248b69@news.povray.org>
I posted an example in p.b-t.b.
I tested a bit more: If you turn off AA or enlarge the box by "scale 10"
there are no dimmed pixel anymore.
Maybe it's something about the "picture a half pixel off"-"bug" or has to do
with it beeing fixed (but there's nothing about a change with that or AA in
revision.txt). (It's strange that it appears only in the second half.) I'm
not really sure anymore if it's a bug.
But it changed from beta 8 to beta 9.
cukk
Date: 22 Dec 2001 10:02:29
Message: <3c24a085$1@news.povray.org>
do
in
Your problem sounds very much like a case of the half-pixel camera bug. That
bug has not been fixed in beta 9. As for it only being visible in the second
half, the AA threshold is playing tricks on you. If you use either +am2 or
+a0.0, the bug is visible through the whole animation.
Anders
Date: 22 Dec 2001 10:27:15
Message: <3c24a653@news.povray.org>
That
second
Could be. The only strange thing is, it wasn't there in beta 8 (at least not
in my case - using the same code with beta 8 produced no dimmed pixels for
me.)
cukk
Date: 22 Dec 2001 11:03:40
Message: <3c24aedc@news.povray.org>
In article <3c24a085$1@news.povray.org> , "Anders K."
It hasn't been a problem for 15 years, so I would say it isn't a bug but
standard behavior of POV-Ray.  Thus, changing it is a feature request...
I think so, too.  Adjusting either the box size of the camera position will
make it look as expected.
    Thorsten
e-mail: tho### [at] trfde
Date: 23 Dec 2001 05:43:17
Message: <3c25b545@news.povray.org>
That
Ok. I will adjust my scene.
Just want to add: Concerning that behavior something changed from beta 8 to
beta 9, because I had no dimmed pixel with beta 8. If that is ok. If not,
there is something unexpected.
Thank you for explaining my problem and for POVRay!
cukk
(shutting up now)
Date: 23 Dec 2001 06:06:53
Message: <3c25bacd@news.povray.org>
This is expected because now the transparency (for the alpha channel) it
taking into account when doing anti-aliasing.
    Thorsten
Date: 23 Dec 2001 08:09:08
Message: <3c25d774@news.povray.org>
> say it isn't a bug but standard behavior of POV-Ray.
It has been a problem for many, but maybe not big enough a problem for
anyone to make a patch to fix it.
Rune
Date: 23 Dec 2001 09:02:47
Message: <3c25e407@news.povray.org>
OK. :-)
Date: 27 Dec 2001 21:56:53
Message: <3c2bdf75$1@news.povray.org>
I disagree. By definition, the camera is supposed to be centered on the
look_at point, but it isn't. For most scenes, the half pixel doesn't matter
very much, but for things which require to-the-pixel accuracy, the current
behavior is *very* annoying. And a lot more scenes require this accuracy
than one would think at first glance. For an example, look no further than
Insert > Scene Templates > Orthographic Scene.
I actually described how to fix it for 3.1g. See my earlier thread, "Camera
is off by half a pixel".
Anders
Date: 28 Dec 2001 12:29:31
Message: <3c2cabfb@news.povray.org>
In article <3c2bdf75$1@news.povray.org> , "Anders K."
If you want it centered, one very simple solution is to add one pixel to the
width and height of the image.
I think orthographic camera scenes are the only place where this may matter
in a very few scenes.  Of course, the above solution will still work fine.
    Thorsten
Date: 28 Dec 2001 15:01:58
Message: <3c2ccfb6$1@news.povray.org>
the
What if I don't want to add one pixel to the width and height of the image?
For example, one of my POV-Ray projects is creating a set of tiles for a 2D
game. There are hundreds of tiles, and they are rendered by a single file as
an animation. I don't want to have to go in manually with an image editor to
remove one row and column from every single image. Moving the camera works,
but then I need to change the amount I move it by every time I change the
size of the images, and I'm making two sizes of tiles (32x32 and 48x48).
matter
That doesn't change the fact that the current behavior is simply incorrect,
and it is very easy to fix. I know you're probably worried about backwards
compatibility, but as you pointed out, it only makes a big difference on a
few scenes, and even on those scenes it would be much better to have the
camera in the right place anyway.
Anders
light_source{6#macro A(B)#declare C=mod(E B);#declare E=(E-C)/B;C#end
#macro B(E)#while(E)#if(A(8)=7)#declare D=D+2.8;#else#if(C<3)cylinder
{0(C=<1 2>).2translate<D+C*A(2)A(4)#else intersection{torus{1 .2}box{
-y 2}rotate<-1 0C+1>*90translate<D+1A(2)*2+1#end-2 13>finish{specular
1}pigment{red 1}}#end#end#end#local D=-8;1}B(445000298)B(519053970)B(
483402386)B(1445571258)B(77778740)B(541684549)B(42677491)B(70)
Date: 28 Dec 2001 17:27:57
Message: <3c2cf1ed@news.povray.org>
Yes, it's not always a useful solution.
Besides, it actually skews the aspect ratio slightly! ;)
> Moving the camera works, but then I need to change the
> amount I move it by every time I change the size of the
I've had the exact same problem every time I create logos, icons, cursors,
web graphics etc. It's rather annoying.
And I don't always use orthographic camera for that by the way.
> is simply incorrect, and it is very easy to fix. I know
> you're probably worried about backwards compatibility,
> on a few scenes, and even on those scenes it would be
> much better to have the camera in the right place anyway.
I agree.
Rune
Date: 28 Dec 2001 23:07:48
Message: <slrna2qgco.hao.ron.parker@fwi.com>
For this was netpbm created.
#macro R(L P)sphere{L __}cylinder{L P __}#end#macro P(_1)union{R(z+_ z)R(-z _-z)
R(_-z*3_+z)torus{1__ clipped_by{plane{_ 0}}}translate z+_1}#end#macro S(_)9-(_1-
_)*(_1-_)#end#macro Z(_1 _ __)union{P(_)P(-_)R(y-z-1_)translate.1*_1-y*8pigment{
rgb<S(7)S(5)S(3)>}}#if(_1)Z(_1-__,_,__)#end#end Z(10x*-2,.2)camera{rotate x*90}
Date: 29 Dec 2001 10:48:48
Message: <3c2de5e0$1@news.povray.org>
Even if this worked, you shouldn't have to work around incorrect behavior.
However, adding one row and column doesn't even work: it scales everything
by <(w+1)/w, (h+1)/h>. And for camera types other than orthographic, moving
the camera doesn't work either, since objects closer to the camera would get
shifted more than objects farther away. Rotating the camera would skew the
whole image unpredictably. So there is no satisfactory workaround.
Anders
Date: 29 Dec 2001 12:29:50
Message: <3c2dfd8e@news.povray.org>
In article <3c2de5e0$1@news.povray.org> , "Anders K."
Actually, a quick look at the code suggests that your observation may not be
correct (but I never really cared about this part of the code before)...
    Thorsten
Date: 29 Dec 2001 13:17:54
Message: <3c2e08d2@news.povray.org>
everything
moving
get
the
be
> correct [...]...
How so?
Anders
