POV-Ray : Newsgroups : povray.beta-test : image_pattern Server Time
10 Nov 2026 23:00:09 EST (-0500)
  image_pattern (Message 1 to 2 of 2)
Subject: image_pattern
Date: 2 Dec 2001 05:15:16
Message: <3c09ff34@news.povray.org>
-Hail
  Some test renders show me that image_pattern produces unexpected results.
If a map is used with the full 8-bit range 0-255 (haven't checked 16-bits)
then the actual range in the map is not 0-255 (0-1 pov language), I found it
to be 76-255 (almost 0.3-1 pov language). I will post two images shortly in
the binaries section that display this. Test.png is a Photoshop generated
file with pixel values from 0-255, next is bugtest.png which is the
rendering done by pov and last is the source code of the scene.
P2-450, 64Mb, W2k.
Subject: Re: image_pattern
Date: 2 Dec 2001 07:52:25
Message: <3c0a2409@news.povray.org>
In article <3c09ff34@news.povray.org> , "Vampyrium" <cyb### [at] hotmailcom>
Confirmed and fixed.  The code used an incorrect formula to turn a color
image into a grayscale image.  The workaround is to use a real grayscale
image rather than a color image with only gray colors.
    Thorsten
Thorsten Froehlich
e-mail: mac### [at] povrayorg
I am a member of the POV-Ray Team.
