POV-Ray : Newsgroups : povray.beta-test : Animated textures Server Time
10 Nov 2026 23:22:20 EST (-0500)
  Animated textures (Message 1 to 5 of 5)
Subject: Animated textures
Date: 8 Nov 2001 01:31:27
Message: <3bea26bf@news.povray.org>
-Hail
  I made a macro that puts an image_map {} in the pigment statement and it
changes the file name of the image so that I have animations as textures.
The sequence has to follow filename000.xxx...filename001.xxx and so on. It
works well apart from the fact that in each frame the image is not cleared
from memory and after a few frames memory usage goes quite high, especially
if large image maps are used. I didnt test it in other situations but it
should be the same.
Subject: Re: Animated textures
Date: 8 Nov 2001 03:35:25
Message: <3bea43cd@news.povray.org>
In article <3bea26bf@news.povray.org> , "Vampyrium" <cyb### [at] hotmailcom>
> should be the same.
Could you please provide a small scene?  You find details how to report bugs
in the welcome message of this group or read the web news copy of it at
<http://news.povray.org/povray.beta-test/*/116102/>.
In general you should not only include assumptions why a problem appears
because this information alone is most likely useless for the POV-Team.
What we need to have is an easy (read: we don't have to create a scene) way
to reproduce the problem in order to fix it.
Thanks for understanding,
    Thorsten
Date: 8 Nov 2001 05:02:50
Message: <3bea584a@news.povray.org>
-Hail
 I will post a short scene file shortly in the binary section. You will
still however need to create an image sequence to test this.
Date: 11 Nov 2001 05:17:26
Message: <3bee5036@news.povray.org>
-Hail
  Could someone please take the time to verify this?
Date: 11 Nov 2001 11:40:44
Message: <3beeaa0c@news.povray.org>
"Vampyrium" <cyb### [at] hotmailcom> wrote in message
news:3bea26bf@news.povray.org...
especially
> should be the same.
In WinXP I get a slight increase (<4%) from the first frame to the second,
but from there on it remains the same.
Bob H.
