POV-Ray : Newsgroups : povray.beta-test : Photons extremly slow under beta 7 icl Server Time
10 Nov 2026 23:32:18 EST (-0500)
  Photons extremly slow under beta 7 icl (Message 1 to 8 of 8)
Subject: Photons extremly slow under beta 7 icl
Date: 30 Oct 2001 16:35:13
Message: <3bdf1d11@news.povray.org>
Hi!
There seems to be something wrong with the Intel compile. The scene I'm
working on took about 6 minutes to compute photons (count 200000) under beta
6. With beta 7 it took over 20 minutes until the status bar showed something
like "this=500 total= 10454 ..." (values might vary a bit). The msvc version
seems to be a bit faster, but it's running at the moment, so I don't know
yet for sure. It displays "this=400, total 6189" after 7 minutes.
Can someone else verify this? Please don't say I have to wait a month (or
even more) to use photons again!
Marc-Hendrik
Subject: Re: Photons extremly slow under beta 7 icl
Date: 30 Oct 2001 17:10:14
Message: <3bdf2546@news.povray.org>
I'm still using my PII 450, 128 MB and Pov beta 7 (both compiles) :-)
Date: 30 Oct 2001 19:17:34
Message: <3bdf431e@news.povray.org>
"Marc-Hendrik Bremer" <Mar### [at] t-onlinede> wrote...
> Hi!
beta
something
version
Does your scene contain isosurfaces?  How does render time compare with
photons disabled?  (Photons are simply rays traced into the scene from the
light sources, so the problem may be caused by slower ray-intersection
tests.)
-Nathan
Date: 30 Oct 2001 21:52:39
Message: <6gputtg9e5gfo0moq15n71iq5k08a6idje@4ax.com>
On Tue, 30 Oct 2001 19:19:33 -0500, "Nathan Kopp" <nat### [at] koppcom>
>tests.)
But Nathan, Marc wrote that the same render was three times faster
with beta 6. Maybe it has to do with the iso changes in the core?
Peter Popov ICQ : 15002700
Date: 30 Oct 2001 21:55:16
Message: <klputts5299qtbes83qgb83supe4bl6lrq@4ax.com>
Sorry about the wild guessing bit, apparently Thorsten attributes it
to evaluate.
Date: 31 Oct 2001 02:59:00
Message: <3bdfaf44@news.povray.org>
Nathan Kopp schrieb in Nachricht <3bdf431e@news.povray.org>...
>tests.)
>-Nathan
Hi!
Yes, there is one Iso in the scene, but evaluate is not used. The rendertime
even without photons is way up. The scene used to render in about half an
hour (34 min IIRC). Yesterday I stooped it after 1h 5min. It renders about
1/3 of the image (640x480 pixel). The Isosurface is further "down" the image
and the upper part used to be the faster one. I would estimate that this
render takes about 7 to 8 times as long.
I hoped that there are just some debug options left on in this beta, but it
seems it's not this trivial.
Marc-Hendrik
Date: 31 Oct 2001 04:04:37
Message: <3bdfbea5@news.povray.org>
In article <3bdfaf44@news.povray.org> , "Marc-Hendrik Bremer"
Well, if you remove the isosurface, is it still slower?
    Thorsten
e-mail: tho### [at] trfde
Date: 31 Oct 2001 04:23:50
Message: <3bdfc326@news.povray.org>
Thorsten Froehlich schrieb in Nachricht <3bdfbea5@news.povray.org>...
Okay, that's it! I had a second look at my include file and "evaluate" was
used in it. Without the Iso, or without "evaluate" everything seems to work
at normal speed.
Thanks,
Marc-Hendrik
