POV-Ray : Newsgroups : povray.beta-test : #while in normal statements in layered textures Server Time
10 Nov 2026 23:44:17 EST (-0500)
  #while in normal statements in layered textures (Message 1 to 5 of 5)
Subject: #while in normal statements in layered textures
Date: 21 Oct 2001 17:22:54
Message: <3bd33cae@news.povray.org>
The following code returns a "Parse error : must have at least one entry in
map".
Declaring the layers separately doesn't cause the problem. (Beta 6, WinNT4)
light_source{<-1,1,-1>*5 rgb 1}
#declare txtSol=
    texture{
        pigment{rgb 1}
        normal{
            average
            normal_map{
                #declare i=1;
                #while (i<10)
                    [1 bumps .1 scale i]
                    #declare i=i+1;
    texture{
        pigment{rgbt <1,0,0,1>}
        normal{
            average
            normal_map{
                #declare i=1;
                #while (i<10)
                    [1 bumps .1 scale i*2]
                    #declare i=i+1;
plane{y,-1 texture{txtSol}}
http://www.oyonale.com
- Graphic experiments
- Posters
Subject: Re: #while in normal statements in layered textures
Date: 21 Oct 2001 17:34:49
Message: <3BD3410C.6236C9D6@pacbell.net>
> map".
Don't work in v3.1g either.
Ken Tyler
Date: 22 Oct 2001 04:12:29
Message: <krk7tt0gjne97pudg0t6hfneif9hps0tf3@4ax.com>
On Sun, 21 Oct 2001 23:23:54 +0200, "Gilles Tran" <tra### [at] inapginrafr>
wrote:
> The following code returns a "Parse error : must have at least one entry in map".
I can extend description of this bug.
it is not connected with parsing of normal_map but rather with parsing
of leyered texture. Why ? Becouse take second line
>                #declare i=1;
and move it line by line to top. It always shows parse error within
statememnt opened before this #declare
ABX
after 4 weeks I'm back to play with betas
Date: 22 Oct 2001 10:40:25
Message: <3bd42fd9$1@news.povray.org>
"W³odzimierz ABX Skiba" <abx### [at] babilonorg> wrote in message
news:krk7tt0gjne97pudg0t6hfneif9hps0tf3@4ax.com...
> >                #declare i=1;
I know, maybe this has been so since v3.1 and before.  Reason I think that
is because I had encountered the inability to use #declare, #while, #if,
etc. within a texture at certain times (layers).  You'll get a warning about
the parse seeing a "#" in a layered texture.
I brought it up before here at the newsgroups but I can't find the message
posts about it now.
Bob H.
Date: 24 Oct 2001 08:37:49
Message: <m9ddtt8go23p77646t04k622mua9old405@4ax.com>
On Mon, 22 Oct 2001 10:12:22 +0200, W�odzimierz ABX Skiba
> of leyered texture.
I can extend description again. It's not connected with parsing of
leyered texture but parsing of declaration of leyered texture. When
the same specification of leyered texture is passed directly to the
plane everithing is ok.
ABX
