POV-Ray : Newsgroups : povray.beta-test : still loop bug? Server Time
10 Nov 2026 23:56:30 EST (-0500)
  still loop bug? (Message 1 to 6 of 6)
Subject: still loop bug?
Date: 10 Oct 2001 11:54:42
Message: <3bc46f42$1@news.povray.org>
P3-933, windows ME, 3.5.beta.6.icl.win32
Following scene crashes for me:
#declare I = 0;
#while(I < 2)
   #declare C = pigment { crackle }
   #declare CF = function { pigment { C } }
   #declare I = I + 1;
#macro C(X,Y)cylinder{X*x<X,0,-Y/2>.1}#end#macro U(R,X,Y)intersection{torus{.9
.1}box{-1 0rotate y*R*90}translate<X,0,Y>scale 1-z*.5}#end union{U(0,0,0)U(1,0
,0)U(2,-1,-1)U(1,1,0)U(1,1.5,-3)U(1,2,0)U(3,1,0)U(2,2,0)U(0,3,0)U(3,2,.5)C(.1,
2)C(.8,1)C(.8,-1)C(1.1,1)C(1.9,-1)pigment{rgb 10}rotate x*90translate<-1,0,4>}
Subject: Re: still loop bug?
Date: 10 Oct 2001 12:17:20
Message: <3BC47490.5A5241A2@gmx.de>
> #declare I = 0;
> #while(I < 2)
>    #declare I = I + 1;
> #end
That's a different bug i think, for the same reason, the insert menu
crashed in the waveform sample too.  Bob's workaround was to use #local
and #undef.
Date: 10 Oct 2001 12:42:05
Message: <3bc47a5d@news.povray.org>
> and #undef.
Where can I get this file? I could only find the waveform.bmp, but no
.pov for it.
I tried with #local and #undef, but no success so far. Well, I added
the array to still access the calculated function, else there would
be no point for my code..
#local A = array[10]
#local I = 0;
#while(I < 2)
   #local C = pigment { crackle }
   #local CF = function { pigment { C } }
   #local A[I] = function { CF }
   #undef CF
   #undef C
   #local I = I + 1;
Thanks for this reply and any other suggestions. In case there is
no easy work around, I just wait for the next beta :) (b5 crashes
all the time, and b4 refuses to work.. so not much choice..)
Probably it's not the best idea to develop with a beta anyway, I
still have constants at odd places, because of an earlier bug :)
Date: 10 Oct 2001 12:56:29
Message: <3bc47dbd$1@news.povray.org>
In article <3bc47a5d@news.povray.org> , "Elias Pschernig"
<eli### [at] aonat> wrote:
> (b5 crashes
Maybe you should try beta 6?
Date: 10 Oct 2001 13:05:26
Message: <3BC47FD0.E0D235E2@gmx.de>
> .pov for it.
It's named 'Attributes.pov' in the Insert Menu directory.
Date: 10 Oct 2001 13:16:59
Message: <3bc4828b@news.povray.org>
> > .pov for it.
Many thanks. By looking at the code there, I think I found out how to get it
working. In my modified version I was using the wrong syntax for storing the
function in the array..
