POV-Ray : Newsgroups : povray.beta-test : while bug ? Server Time
10 Nov 2026 23:56:31 EST (-0500)
  while bug ? (Message 1 to 27 of 27)
Subject: while bug ?
Date: 10 Oct 2001 04:12:39
Message: <3bc402f7$1@news.povray.org>
#local i=0;
#while (i<1)
  #debug concat(str(i,0,2),"\n")
  #local i=i+0.1;
gives
0.00
0.10
0.20
0.30
0.40
0.50
0.60
0.70
0.80
0.90
1.00
is the1.00 normal ???
if we change i=i+0.1 into i=i+0.2 it stops at 0.8
povray3.5b6 win2000 Athlon 900MHz 256MB
M
Subject: Re: while bug ?
Date: 10 Oct 2001 05:18:40
Message: <Xns9136730FC78FDseed7@povray.org>
Same happens in 3.1g
Ingo
Date: 10 Oct 2001 08:00:15
Message: <slrn9s8e2f.9hj.ron.parker@fwi.com>
It's roundoff error.  I is probably .9999999 or so for the last iteration,
but it gets rounded for output.
#macro R(L P)sphere{L F}cylinder{L P F}#end#macro P(V)merge{R(z+a z)R(-z a-z)R(a
-z-z-z a+z)torus{1F clipped_by{plane{a 0}}}translate V}#end#macro Z(a F T)merge{
P(z+a)P(z-a)R(-z-z-x a)pigment{rgbt 1}hollow interior{media{emission T}}finish{
reflection.1}}#end Z(-x-x.2y)Z(-x-x.4x)camera{location z*-10rotate x*90}
Date: 10 Oct 2001 08:30:07
Message: <3bc43f4f@news.povray.org>
isn t it strange to get a roundoff error for only 10 additions  ? i thought
pov was more precise :(
M
Date: 10 Oct 2001 08:39:10
Message: <3BC4411A.7060206@videotron.ca>
> M
You can get roundoff error with only one addition.  It comes from the
fact that floating point numbers can not always be converted between
base2 and base10 without roundoff.
To see what happens, you have to modify your code to show all the
decimal places, like this:
#local i=0;
#while (i<1)
   #debug concat(str(i,0,17),"\n")
   #local i=i+0.1;
Which (on my machine) produces:
0.00000000000000000
0.10000000000000001
0.20000000000000001
0.30000000000000004
0.40000000000000002
0.50000000000000000
0.59999999999999998
0.69999999999999996
0.79999999999999993
0.89999999999999991
0.99999999999999989
/*   videotron.ca  */}camera{location<6,1.25,-6>look_at a orthographic}
Date: 10 Oct 2001 08:46:21
Message: <3bc4431d$1@news.povray.org>
ok, thank you, it's clear.. we can't trust computers for maths :)
i'll change the test in the loop to avoid this
M
Date: 10 Oct 2001 08:54:04
Message: <slrn9s8h7d.9kj.ron.parker@fwi.com>
The problem is that .1 in decimal is a repeating fraction in binary, so it
can never be represented precisely,  just as 1/3 is a repeating fraction in
decimal (but terminates in base 3.)
Date: 10 Oct 2001 08:59:42
Message: <3bc4463e$1@news.povray.org>
> #local i=0;
> #while (i<1)
>   #local i=i+0.1;
> #end
Try
#local i = 0;
#while (i < 10)
  #debug concat(str(i/10, 0, 2), "\n")
  #local i = i + 1;
Since there is no round off error with adding integers.
Date: 10 Oct 2001 09:03:49
Message: <3BC446E1.3090107@videotron.ca>
Yes we can.  As long as we remembers that computers do not have the same
number of fingers to count on.
Date: 10 Oct 2001 09:55:02
Message: <3bc45335@news.povray.org>
Mael <mae### [at] hotmailcom> wrote:
: isn t it strange to get a roundoff error for only 10 additions  ? i thought
: pov was more precise :(
  0.1 can't be represented accurately with binary floating point format.
  The reason is the same as why 1/3 can't be represented accurately with
decimal format.
Date: 10 Oct 2001 10:29:28
Message: <3bc45b48$1@news.povray.org>
Note that counting in integers will work fine, and so should counting by
fractions that are non-repeating decimals in binary, such as .25, .125, and
.0625.
- Slime
[ http://www.slimeland.com/ ]
[ http://www.slimeland.com/images/ ]
"Francois Labreque" <fla### [at] videotronca> wrote in message
news:3BC### [at] videotronca...
> /*Francois Labreque*/#local a=x+y;#local b=x+a;#local c=a+b;#macro P(F//
> /*    flabreque    */L)polygon{5,F,F+z,L+z,L,F pigment{rgb 9}}#end union
> /*        @        */{P(0,a)P(a,b)P(b,c)P(2*a,2*b)P(2*b,b+c)P(b+c,<2,3>)
Date: 10 Oct 2001 10:44:44
Message: <3bc45edc@news.povray.org>
Slime <noo### [at] hotmailcom> wrote:
: Note that counting in integers will work fine
... as long as they are not too big.
  Of course the integers you can handle accurately with a double type are
quite big (several thousands of millions...).
Date: 11 Oct 2001 10:22:44
Message: <3BC5AAE4.2D531AF1@aol.com>
Now *there's* a phrase to cause anxiety in an American listening to an
international audience.
thousand=1E03
million = 1E06
thousand millions=1E09?
Date: 11 Oct 2001 10:40:03
Message: <3bc5af43$1@news.povray.org>
I had a discussion at work here about that once:
In the US:
million = 10^6
billion = 10^9  (thousand million)
In UK:
million = 10^6
billion = 10^12 (million million)
Read this article from the Straight Dope:
http://www.straightdope.com/mailbag/mgazilli.html
-tgq
"Greg M. Johnson" <"gregj56590[:-0]"@aol.com> wrote in message
news:3BC5AAE4.2D531AF1@aol.com...
> thousand=1E03
> million = 1E06
Date: 11 Oct 2001 11:37:36
Message: <3bc5bcbf@news.povray.org>
Greg M. Johnson <"gregj56590[:-0]"@aol.com> wrote:
:> (several thousands of millions...).
: Now *there's* a phrase to cause anxiety in an American listening to an
: international audience.
  I know the 'billion' problem in the UK/US, so I deliberately used the
term "thousands of millions" instead. I don't know how good it sounds, but
I don't care; I don't want to cause confusion.
Date: 11 Oct 2001 12:11:20
Message: <3BC5C457.3954809B@aol.com>
and "thousand" is 10^3.
> In the US:
> million = 10^6
> In UK:
> million = 10^6
Date: 11 Oct 2001 13:08:49
Message: <3BC5D1D0.24B313B8@aol.com>
Is that 10^9?
Date: 11 Oct 2001 19:17:03
Message: <3bc6286f@news.povray.org>
:> term "thousands of millions" instead. I don't know how good it sounds, but
:> I don't care; I don't want to cause confusion.
: Is that 10^9?
  If you take a million one thousand times, how much do you get?-)
Date: 12 Oct 2001 10:24:39
Message: <3bc6fd27@news.povray.org>
"Mael" <mae### [at] hotmailcom> wrote in message news:3bc43f4f@news.povray.org...
On that subject, a recent faq wot I wrote (corrections and/or criticisms happily
accepted - and please note the very long url)
http://www.ccl.com/cgi-bin/protonfaq.cgi?faq=itemconfigwhydowetalkofaccuracynots
izeforfloatingpointnumbers
Date: 12 Oct 2001 14:00:46
Message: <3BC72F71.25A8D9A0@aol.com>
10^9, unless outside the territorial United States, ha mon?
Date: 12 Oct 2001 16:39:06
Message: <3bc754ea@news.povray.org>
: 10^9, unless outside the territorial United States, ha mon?
  Where "a thousand millions" is not 10^9?
Date: 15 Oct 2001 08:57:07
Message: <3BCADCE4.889DD713@aol.com>
The vagueness of your reply in my attempt to nail down its meaning merely
underscores the barrier to technical communication in international audiences
from the use of either the terms "thousand" or "million".  Americans won't
know what a non-American really means; I'm afraid I'll never know what you
mean...
Date: 15 Oct 2001 09:51:27
Message: <3bcae9df$1@news.povray.org>
audiences
> mean...
FYI, my dictionary gives two definitions of "billion" (the American 10^9 and
the British 10^12) but only one definition for "million" (10^6) and one
definition for "thousand" (10^3). So IMHO there can be no ambiguity in
saying thousand million.
Date: 15 Oct 2001 10:15:02
Message: <3bcaef66$1@news.povray.org>
This is correct.  10^n is 10^n no matter where you are, it is a (as far as
we know) universal constant.  The problem comes with terminology.  A
"thousand" is the same in US/UK (10^3), so is a "million" (10^6) and,
therefore, so would a "thousand million"  (10^3 x 10^6 = 10^9), but in the
US a "thousand million" is also known as a "billion" but not so in the UK,
it is still a "thousand million" (Or also a "milliard").  The UK reserve the
word "billion" to describe a "million million" (which is known as "trillion"
in the US).  Also, a UK "trillion" is a "million million  million" (quite
the mouthful) or 10^18 ("million"^3, "quadrillion" = "million"^4, etc.). All
in all, it is always better to use scientific notation so as to keep
confusion about such large numbers to a minimum when talking to an
-tgq
"Anders K." <and### [at] f2scom> wrote in message
news:3bcae9df$1@news.povray.org...
merely
> audiences
won't
you
> > mean...
and
Date: 15 Oct 2001 10:41:10
Message: <3bcaf586$1@news.povray.org>
> we know) universal constant.  The problem comes with terminology. [...]
What Warp said was "several thousands of millions". While Americans may have
another name for it, one thousand million is still 10^9. There is no other
way it can be interpreted.
Date: 15 Oct 2001 11:59:57
Message: <3bcb07fd@news.povray.org>
Yes, that's right, but I think Greg's original point was that Americans tend
not to use the phrase "thousands of millions" but rather "billions" and
maybe wonder why Warp specified thousands of millions rather than just
saying billions even though they mean the same in American terms.
-tgq
news:3bcaf586$1@news.povray.org...
as
have
Date: 17 Oct 2001 07:46:08
Message: <3BCD7071.71DF9F86@reading.ac.uk>
Well, this is true as long as everyone is working in the same base.
10^n (base 13) is not the same as 10^n (base 10), so 10^n may not be the
same everywhere. ;-)
	Mike Andrews.
