POV-Ray : Newsgroups : povray.beta-test : Known Bugs Sep 28 Server Time
11 Nov 2026 00:16:34 EST (-0500)
  Known Bugs Sep 28 (Message 1 to 22 of 22)
Subject: Known Bugs Sep 28
Date: 28 Sep 2001 11:21:17
Message: <3bb4956d@news.povray.org>
Here are the known and confirmed bugs as per today. Corrections to the list
are still very welcome.
18077  Blob problem
http://news.povray.org/povray.beta-test/18087/
18089  Blob : Toward a solution
http://news.povray.org/povray.beta-test/18089/
18094  Superellipsoid epsilon to big ?
http://news.povray.org/povray.beta-test/18094/
18105  Additional (?) blob bug
http://news.povray.org/povray.beta-test/18105/
18391  hf_gray_16 + png creates wrong output image
http://news.povray.org/povray.beta-test/18391/
18456  Blob rendering error
http://news.povray.org/povray.beta-test/18456/
18522  Small window title bug
(Title switches back to "POV-Ray for Windows" after minimize or restore. )
http://news.povray.org/povray.beta-test/18522/
18529  16-bit PGM pigment and height field problems
http://news.povray.org/povray.beta-test/18529/
18535  Blend map crash
http://news.povray.org/povray.beta-test/18535/
18565  Radiosity with recursion > 1
(With recursion_limit > 1 clear axis aligned bands appear on the surfaces.)
http://news.povray.org/povray.beta-test/18565/
18577  Rendering animation (MS Windows)
(Message that indicates the frame to be render is displayed AFTER the
rendering.)
http://news.povray.org/povray.beta-test/18577/
18638  Stop during mosaic: crash
http://news.povray.org/povray.beta-test/18638/
18650  sin(X)^sin(X) -> crash!
http://news.povray.org/povray.beta-test/18650/
18672  Bug with parse_string
http://news.povray.org/povray.beta-test/18672/
18740  Spline bug
(The spline path is all wrong when certain time values are used.)
http://news.povray.org/povray.beta-test/18740/
18746  Radiosity crash when user stops render during pretrace.
http://news.povray.org/povray.beta-test/18746/
Rune
Rune's World:    http://rsj.mobilixnet.dk (updated June 26)
Subject: Re: Known Bugs Sep 28
Date: 28 Sep 2001 20:12:12
Message: <3bb511dc$1@news.povray.org>
"Rune" <run### [at] mobilixnetdk> wrote in message
news:3bb4956d@news.povray.org...
Just found that hf_gray_16 (on) won't allow a render to proceed.  That bug
mentioned was only about TGA file output being okay but not for PNG and with
the Beta 2.  I get the message:
File Init Error: Cannot open output file.
whether png or tga is specified.
Intel opt. Beta 4, WinMe, PIII, 512MB
Bob H.
Subject: Re: nevermind
Date: 28 Sep 2001 23:02:50
Message: <3bb539da@news.povray.org>
Just found a message by Bonsai here from the 24th saying the same thing I
just did about File Init Error.  Ron suggests it would be fixed in Beta 5.
Bob H.
Date: 28 Sep 2001 23:30:28
Message: <slrn9rag2o.6ml.ron.parker@fwi.com>
Or some future beta.  One never knows; I might check it in just after Chris
starts building the beta.
#macro R(L P)sphere{L __}cylinder{L P __}#end#macro P(_1)union{R(z+_ z)R(-z _-z)
R(_-z*3_+z)torus{1__ clipped_by{plane{_ 0}}}translate z+_1}#end#macro S(_)9-(_1-
_)*(_1-_)#end#macro Z(_1 _ __)union{P(_)P(-_)R(y-z-1_)translate.1*_1-y*8pigment{
rgb<S(7)S(5)S(3)>}}#if(_1)Z(_1-__,_,__)#end#end Z(10x*-2,.2)camera{rotate x*90}
Date: 30 Sep 2001 17:27:02
Message: <3bb78e26@news.povray.org>
You forgot to mention the *sphere_sweep with radiosity bug*
Jonathan
"Rune" <run### [at] mobilixnetdk> ha scritto nel messaggio
list
> 18077  Blob problem
surfaces.)
> rendering.)
> 18740  Spline bug
> Rune
> 3D images and anims, include files, tutorials and more:
Date: 1 Oct 2001 11:23:02
Message: <a1vgrtgkmem30dmqvmd265tulhpivjsb9l@4ax.com>
On Fri, 28 Sep 2001 17:15:53 +0200, "Rune"
Perhaps there is a reason but you attached only one my post.
Here are other not finished with explanation or "will be fixed"
  Crash after constant function
  http://news.povray.org/povray.beta-test/18496/
  Bug with intersection stack (I gave solution)
  http://news.povray.org/povray.beta-test/18696/
  #if inside #if (but Nathan said - no solution anywhere :-( )
  http://news.povray.org/povray.beta-test/18701/
  Another string bug (or even two)
  http://news.povray.org/povray.beta-test/18706/
  Old accuracy bug - perhaps with no chance to fix
  http://news.povray.org/povray.beta-test/18702/
There is also something new from me
  Select within select
  http://news.povray.org/povray.beta-test/18823/
I answered for your request for help
  http://news.povray.org/povray.beta-test/18618/
Have you readed this? Was this helpful ? Should I continue ?
ABX
Date: 1 Oct 2001 14:27:09
Message: <3bb8b57d@news.povray.org>
> one my post. Here are other not finished with
Note:
Only confirmed bugs can get on the list.
You couldn't know this, but for the future, please specify messages this
way:
http://news.povray.org/Xns9115B92CF7D8ACQ@204.213.191.226
(The part after http://news.povray.org/ is the message ID.)
I'll add this.
I'll add it.
That's not a bug but a limitation.
I'll add "Crash with long strings, ignore documentation bug report"
This bug doesn't seem to have been confirmed.
This hasn't been confirmed properly.
Yes. Yes. Yes. (Sorry I didn't answer before to that.)
Rune
Date: 22 Oct 2001 05:11:25
Message: <ahn7ttc31av05805lom27csqk778mpdvvl@4ax.com>
On Mon, 1 Oct 2001 20:28:47 +0200, "Rune"
ok.
> way:
where on the www interface I can find it that way ?
> I'll add this.
is seems it's gone for beta 6
> I'll add it.
it still present for beta 6
than I must wait for sources :-(
can anybody confirm this ?
I can confirm that it still present for beta 6
yes, wrong noise generator
ok, I see it is still not finished for beta 6 therefore I'll start
with it.
ABX
Date: 22 Oct 2001 06:47:01
Message: <3bd3f925@news.povray.org>
In article <ahn7ttc31av05805lom27csqk778mpdvvl@4ax.com> , W„odzimierz ABX
Just _follow_ the link, at is all you need to do to find it.
    Thorsten
e-mail: tho### [at] trfde
Date: 22 Oct 2001 08:12:42
Message: <q338tt4tlomhlieng38togpei5t3i8phf4@4ax.com>
On Mon, 22 Oct 2001 12:46:59 +0200, "Thorsten Froehlich"
perhaps there is some limitation in my English but I not asked how use
links but how generate link with message ID having opened message via
www interface
ABX
Date: 22 Oct 2001 08:44:14
Message: <3bd4149e@news.povray.org>
In article <q338tt4tlomhlieng38togpei5t3i8phf4@4ax.com> , W„odzimierz ABX
> www interface
No, this is a mistake on my part.  I misunderstood the question.
The short answer is: You can't.
The long answer is: You can build it on your own, but you need a newsreader
that can show you the message header.  Then just take the message ID header
field and combine it with the link to the main newsgroup web interface page.
While the resulting link is not compatible with old browsers (because the
URL isn't encoded properly), it will work with all more recent browsers.
Alternatively you can use Netscape to get a link in the same format with a
properly encoded URL.  You just change the news:// Netscape puts in front to
a http:// and you are all set.  The web interface does not care if the URL
is encoded properly or not.
    Thorsten
Date: 22 Oct 2001 14:07:36
Message: <3bd46068@news.povray.org>
> therefore I'll start with it.
Thank you! It's very appreciated.
Rune
Date: 29 Oct 2001 06:01:16
Message: <madqttov353hsu8gaef92809kscol9pre3@4ax.com>
this macro is not on the list but I think it could be usefull
(and that's why I talked so much about declaring arrays
and pointing to elements with loops - this macro could
be veeery short with it)
// Array - an array to be resized
// Dimension - number of dimension to be resized
// NewSize - new number of entries for Dimension of Array
#macro Resize_Multi_Array(Array, Dimension, NewSize)
    #if((Dimension>0)&(dimensions(Array)>=Dimension)&(int(Dimension)=Dimension))
        #if(dimensions(Array)!=1)
            #switch(dimensions(Array))
                #case(2)
                    #local NewArray=array
                        [(Dimension!=1?dimension_size(Array,1):NewSize)]
                        [(Dimension!=2?dimension_size(Array,2):NewSize)]
                    #local Max1 =
min(dimension_size(NewArray,1),dimension_size(Array,1));
                #break
                #case(3)
                        [(Dimension!=3?dimension_size(Array,3):NewSize)]
                #break
                #case(4)
                        [(Dimension!=4?dimension_size(Array,4):NewSize)]
                #break
                #case(5)
                        [(Dimension!=5?dimension_size(Array,5):NewSize)]
                #break
                #else
                    #error "Wrong Dimension argument in Resize_Multi_Array macro"
            #local Max=array[dimensions(Array)]
            #local C=0;
            #while (C<dimensions(Array))
              #local
Max[C]=min(dimension_size(NewArray,C+1),dimension_size(Array,C+1));
              #local C=C+1;
            #local C=Max
                #case(2)
                    #local C[0]=0;
                    #while (C[0]<Max[0])
                        #local C[1]=0;
                        #while(C[1]<Max[1])
                            #ifdef(Array[C[0]][C[1]])
                                #local NewArray[C[0]][C[1]] = Array[C[0]][C[1]];
                            #local C[1] = C[1] + 1;
                        #local C[0] = C[0] + 1;
                #break
                #case(3)
                    #local C[0]=0;
                        #local C[1]=0;
                        #while(C[1]<Max[1])
                            #local C[2]=0;
                            #while(C[2]<Max[2])
                                #ifdef(Array[C[0]][C[1]][C[2]])
                                    #local NewArray[C[0]][C[1]][C[2]] =
Array[C[0]][C[1]][C[2]];
                                #local C[2] = C[2] + 1;
                #break
                #case(4)
                    #local C[0]=0;
                        #local C[1]=0;
                        #while(C[1]<Max[1])
                            #local C[2]=0;
                            #while(C[2]<Max[2])
                                #local C[3]=0;
                                #while(C[3]<Max[3])
                                    #ifdef(Array[C[0]][C[1]][C[2]][C[3]])
                                        #local NewArray[C[0]][C[1]][C[2]][C[3]] =
Array[C[0]][C[1]][C[2]][C[3]];
                                    #local C[3] = C[3] + 1;
                #break
                #case(5)
                    #local C[0]=0;
                        #local C[1]=0;
                        #while(C[1]<Max[1])
                            #local C[2]=0;
                            #while(C[2]<Max[2])
                                #local C[3]=0;
                                #while(C[3]<Max[3])
                                    #local C[4]=0;
                                    #while(C[4]<Max[4])
                                        #ifdef(Array[C[0]][C[1]][C[2]][C[3]][C[4]])
                                            #local
NewArray[C[0]][C[1]][C[2]][C[3]][C[4]] = Array[C[0]][C[1]][C[2]][C[3]][C[4]];
                                        #local C[4] = C[4] + 1;
                #break
                #else
            #declare Array = NewArray
        #else
            Resize_Array(Array,NewSize)
    #else
ABX
#declare _=function(a,b,x){((a^2)+(b^2))^.5-x}#default {pigment{color rgb 1}}
union{plane{y,-3}plane{-x,-3}finish{reflection 1 ambient 0}}isosurface{ //ABX
function{_(x-2,y,1)|_((x+y)*.7,z,.1)|_((x+y+2)*.7,z,.1)|_(x/2+y*.8+1.5,z,.1)}
contained_by{box{<0,-3,-.1>,<3,0,.1>}}translate z*15finish{ambient 1}}//POV35
Date: 29 Oct 2001 12:25:15
Message: <3bdd90fb@news.povray.org>
Hmm, I don't know, so I'd like to hear the opinions of others. Is this macro
useful enough for inclusion?
Rune
Date: 29 Oct 2001 13:10:45
Message: <3bdd9ba5$1@news.povray.org>
Why don't you allow the array to be one-dimensional? I know that there are
other macros for one-dimensional arrays, but it's trivial to add and it
would make this macro truly general-purpose.
Date: 30 Oct 2001 02:55:36
Message: <3BDE5CB2.5000400@yahoo.fr>
Yes imho
Philippe
Date: 31 Oct 2001 02:49:56
Message: <02bvttc9u5b4slf1arg3c6kbdtga15vvpn@4ax.com>
On Mon, 29 Oct 2001 18:19:33 +0100, "Rune"
I've designed this macro becouse I planned to write Append_To_Array
and Append_Array_To_Array macros working multidimensional.
ABX
Date: 31 Oct 2001 02:51:07
Message: <v8bvttsq74vv2n9rh68sdfj2nh1d0h48t7@4ax.com>
On Mon, 29 Oct 2001 13:12:59 -0500, "Anders K." <and### [at] f2scom>
perhaps you missed this but I don't allow, I just call ready macro to
not duplicate code within one inc file.
ABX
Date: 31 Oct 2001 10:23:07
Message: <3be0175b$1@news.povray.org>
You're right, I did miss this.
Date: 9 Nov 2001 10:05:35
Message: <s3snut4mqu9u2pp1ndms5i0dstp6gqulfb@4ax.com>
I still wait for the answer becouse I don't get strategy for rest of macros.
ABX
Date: 10 Nov 2001 11:32:28
Message: <3bed569c@news.povray.org>
I haven't got many opinions from others but ok, I'll include it.
Can anybody make it more effecient? ~130 lines is quite a lot for such a
macro.
Rune
Rune's World:    http://rsj.mobilixnet.dk (updated Nov 5)
Date: 12 Nov 2001 03:07:42
Message: <gk0vutksphcph3ed87fktg0b1r7ciqab19@4ax.com>
> macro.
It could be much shorten but as I showed in another thread some constructions
not work (http://news.povray.org/0qjittsg3bmv8422pj5egqvo8p4sg9p36h@4ax.com)
ABX
