POV-Ray : Newsgroups : povray.beta-test : png gamma error Server Time
11 Nov 2026 00:26:39 EST (-0500)
  png gamma error (Message 1 to 29 of 29)
Subject: png gamma error
Date: 23 Sep 2001 06:56:54
Message: <3badbff6$1@news.povray.org>
Hi all!
System: POV-Ray for Windows v3.5b3, Win98SE, AMD Athlon 1.4 GHz,
            1024 megs SDRam
PNG output (by +fn) in beta 3 makes image output way too bright. It can only
be seen with an extern viewer, not while rendering. It seems output has a
gamma of 1.0 while it should be 2.2.
Beta 2 behavior was correct.
Norbert
Subject: Re: png gamma error
Date: 23 Sep 2001 07:13:57
Message: <3BADC431.8AED574@engineer.com>
ACDSee Classic and Photoshop 5.5 png display seems to be correct. Win98SE.
Are you sure you have configured the viewer correctly?
_____________
Kari Kivisalo
Date: 24 Sep 2001 03:06:16
Message: <3baedb68@news.povray.org>
I have noticed this error some time ago.
  The problem seems that POV-Ray outputs to the PNG file a gamma value of
1.0 while it should be 1.0/Display_Gamma, which would give the correct result.
  (Another solution is to not to output any gamma value to the PNG... But
then the Display_Gamma option would not have effect on the final image; this
may even be better...)
Date: 24 Sep 2001 04:04:55
Message: <3BAEE8A6.C4301557@geocities.com>
I REALLY like the idea that display gamma has no effect whatsoever on the output
file. I would assume that assumed gamma would.
Jon A. Cruz
http://www.geocities.com/joncruz/action.html
Date: 24 Sep 2001 05:01:07
Message: <3baef652@news.povray.org>
Jon A. Cruz <jon### [at] geocitiescom> wrote:
: I REALLY like the idea that display gamma has no effect whatsoever on the output
: file.
  Then POV-Ray should not write any gamma value to the PNG file (this is
easy to implement in the current source code by commenting out 2 lines).
: I would assume that assumed gamma would.
  It already does. The assumed_gamma value affects the actual values of the
pixels written to the image file (regardless of the format).
Date: 24 Sep 2001 08:55:02
Message: <3BAF2D61.12639AF2@engineer.com>
> file.
Then what's the the point in specifying and measuring display gamma?
The samples in the file are calculated using assumed_gamma/Display_Gamma
as the exponent. Assumed gamma is best used as a contrast control for
compensating scene lighting conditions (indoors/outdoors/night) and should
not be included in the display gamma information in the image file.
TweakPNG shows that pov sets the gamma header to 1.0 on all pngs. It
should be 1/Display_Gamma as Warp pointed out.
As usual Photoshop does it's own thing and ignores the png gamma :)
I wonder how many applications actually use the png gamma information?
_____________
Kari Kivisalo
Date: 24 Sep 2001 11:12:08
Message: <3BAF4D9C.6123C620@sycomore.fr>
> > file.
assumed_gamma is (should be) the gamma at which the scene was
designed. Display_Gamma is (should be) the gamma of the system
on which the file is being rendered.
Of course, when rendering on the system on which the file was
created the values are (should be) the same. So the files are
written on the disk as if no gamma correction has happened,
which is the right thing to do since most format can't account
for gamma correction.
But give your PC-source to a Mac user, and the values will be
different (and well needed). So the files are written on the
disk with a gamma correction - but this gamma correction was
achieved through higher-precision internal POV math.
Finally, 1/Display_Gamma is (should be!) written into gamma-
supporting file formats, so that viewers on other platforms
can correct the image on the fly, if they have been configured
correctly. Anyway, the user on the other platform can also
rerender the file, if he has the source.
* Kari, I'm sure you know all this, but I felt the need
* to recap, if only for my own understanding of the issue.
I agree.
Not many, I'm afraid. Worst of all, they don't say if they do,
and to which extend.
Actually, I find that gamma has become impossibly hard to
manage, since every application layer corrects (corrupts?)
it to some extent, now. Windows does some gamma correction
on its own through color profiles. Then, e.g. Paint Shop Pro
adds another layer of gamma correction, and I have the worst
experience: if you select a color in the palette (drawn
by Windows), your pencil draws with another color, because
it was corrected by PSP on the way. :-(
But that doesn't diminish the need for assumed_gamma and
Display_Gamma, which are independant of all this mess.
Adrien Beau - adr### [at] freefr - http://adrien.beau.free.fr
 Mes propos n'engagent que moi et en aucun cas mes employeurs
Date: 24 Sep 2001 11:13:35
Message: <3BAF4DF5.8CDD4FA7@sycomore.fr>
Not necessarily. You can only say "behavior was different".
What are your assumed_gamma and Display_Gamma settings?
Date: 24 Sep 2001 13:18:14
Message: <3baf6ad6$1@news.povray.org>
> designed.
Not necessarily -- according to the docs:
"For new scenes, you should use an assumed gamma value of 1.0 as this models
how light appears in the real world more realistically."
Date: 24 Sep 2001 13:32:57
Message: <3baf6e49$1@news.povray.org>
"Anders K." <and### [at] f2scom> wrote in message
news:3baf6ad6$1@news.povray.org...
> > designed.
models
Yeah, I can't follow that line of reasoning even if it is only because of
what I see when rendering the images.
If you read there about how the MacIntosh or Apple computers Display_Gamma=
should be around 1.8 and PC's around 2.2 I wonder even more about the
statement you quoted.
In the paragraph above that one you brought up:
For PC systems, the most common display gamma is 2.2, while for scenes
created on Macintosh systems should use a scene gamma of 1.8. Another gamma
value that sometimes occurs in scenes is 1.0.
Makes me more confused than ever.  As you can see, it actually is suggestive
of assumed gamma when speaking of the Mac.  Wrong wording?
Bob H.
Date: 24 Sep 2001 13:53:53
Message: <3baf7331$1@news.povray.org>
I followed the diskussion and you are surely right, in an academic sense.
I reported the bug, because the BMP and the PNG output were different on
Polyview.
Polyview had shown no problem with earlier beta and other pov-ray versions.
My assumed_gamma value is 1 since some months, so there should be no
difference anyway.
I don`t know, where I can see my Display_Gamma, but it should be normal.
Norbert
Date: 24 Sep 2001 14:24:49
Message: <3baf7a70@news.povray.org>
Kari Kivisalo <ray### [at] engineercom> wrote:
: I wonder how many applications actually use the png gamma information?
  At least xv, Image Magick and Netscape 6.x in unix. All of them use the
gamma correction value and show the same result.
Date: 24 Sep 2001 14:57:27
Message: <3baf8217@news.povray.org>
"Norbert Kern" <nor### [at] t-onlinede> wrote in message
news:3baf7331$1@news.povray.org...
> Polyview.
versions.
> difference anyway.
POV directory\renderer\povray.ini holds the Display_Gamma= if you have one.
Bob H.
Date: 24 Sep 2001 16:23:08
Message: <Xns9126E3B74B171seed7@povray.org>
> scenes created on Macintosh systems should use a scene gamma of
> 1.8. Another gamma value that sometimes occurs in scenes is 1.0.
 Guessing (as I used a pre 3.1 versions only for a week or two): going
from version 2.2/3.0/3.1 a few things changed. In older versions you
had to set the resulting gamma in the scene file. When a scene was
designed on a Mac and renderd on a PC there had changes to be made to
the scene file.
 In the current situation this is not needed anymore as display_gamma
is set in the INI file, or defaults to the right value (at least
for PC). assumed_gamma 1 just tells the system to use that
display_gamma. final gamma = display_gamma/assumed_gamma, so
assumed_gamma can be used to make small changes to the illumination of
the scene, but in general it would be better to do it with the
lightning sceme to prevent cross platform problems.
 As to the value to be written to the PNG file, shouldn't it be
1/final_gamma instead of 1/display_gamma? Or is that one correction too
much?
Ingo
Date: 25 Sep 2001 04:14:53
Message: <3bb03cfd@news.povray.org>
"ingo" <ing### [at] homenl> wrote in message
news:Xns### [at] povrayorg...
> the scene file.
> much?
Don't know, but looking at the last line of the last paragraph of section
5.2.2.2 in the doc I see it says newer hardware could use Display_Gamma 1.0.
Having tried that just now since I have the ATI mobility 128, which must
certainly have gamma correction of some sort, and putting assumed_gamma 1.0
as recommended I get a perfectly good rendering.  So it was the visually
adjusted display gamma I had always set before which messed that idea up.  I
kept thinking display gamma had to be set manually by using the graphic
supplied in the doc.
Anyway, I'll be checking into this once again to find how the images end up.
Bob H.
Date: 25 Sep 2001 04:34:22
Message: <3BB041E4.76733B14@sycomore.fr>
Most card drivers allow you to change the gamma to any
value you want. So you can work at gamma 1.0. OTOH, lots
of people will then complain about your images. IIRC,
Fabien Mosen told me he worked at a gamma around 1.7.
But what was your Display_Gamma?
> I
Definitely yes.
Subject: Re: png gamma error [bug]
Date: 25 Sep 2001 04:38:40
Message: <3BB042E7.2FDE49C1@sycomore.fr>
> Polyview.
That's interessant! I don't think this is a correct behaviour.
Can anybody else test it? I'm at work and I can't.
Have you tried other programs?
E.g. http://www.irfanview.com is not a very big download (~600KB)
Date: 25 Sep 2001 05:05:21
Message: <3bb048d1@news.povray.org>
"Adrien Beau" <adr### [at] sycomorefr> wrote in message
news:3BB041E4.76733B14@sycomore.fr...
section
1.0.
1.0
1.0 also, as was suggested for newer (about post-1995 do you think? :-))
video hardware in the doc.
> Definitely yes.
If I set that to 2.3 though, which is what I get for the LCD screen near as
I can tell, then I must use assumed_gamma 2.3 also or none at all.  Using
1.0 for both settings is the exact same thing.  This is what I wonder about
then, whether it makes any difference once rendering on another machine.
This of course depends on whether or not assumed gamma is applied at all or
not.
Apparently the concept of using 1.0 for both isn't expressed in no uncertain
terms, that's why I always set display gamma to a visual appearance and then
expected assumed gamma would compensate from there.  Sorry about being so
inept about this but it's one of those things that leads me in circles.
I'm posting (yet another) gamma comparative image to p.b.i. in a minute just
to see if anyone has some more ideas on this cross-platform stuff which I
have no idea about.
Bob H.
Date: 25 Sep 2001 07:09:35
Message: <3BB0662D.236C2598@engineer.com>
LCD and gamma don't mix. Gamma correction is for CRT only.
The response curve of non compensated LCD displays is totally
different from CRT response and trying to measure or apply
gamma with that hardware won't do much good.
I know there are TFT displays that emulate sRGB CRT and those
are hard wired to gamma 2.2. They can be used for graphics work
but the LCD displays I have seen have been non compensated
and unsuitable for editing graphics.
So, if the manual that came with the hardware doesn't mention
anything about sRGB, CRT or gamma emulation forget gamma.
Quick search produced this review about LCD projectors. What is
said here applies also to LCD displays. In short, LCD displays
are problematic.
From http://www.zdnet.co.uk/pcmag/labs/2000/04/projectors/21.html
Gamma is a critical parameter for any display product because it
determines how accurately tonal values are reproduced. Although
this might not be so important for high-contrast business
graphics, it's important for the reproduction of natural
images--high-quality images of fine art, for example. Displays
with response curves that follow a power curve
(but with the 'wrong' exponent) can be corrected to the desired
curve. However, some display products exhibit black and white
compression, resulting in an S-shaped curve. Unless this can be
removed by manipulation of the brightness and contrast controls,
images displayed by these products can't be improved purely by
simple gamma correction.
The gamma characteristics for many of these projectors show large
deviations from the ideal, and the controls that relate to gamma
contrast and brightness were difficult to set. In this review, the
Philips Hopper XG10 and, to a lesser extent, the Toshiba TLP651E
both have S-shaped gamma curves.
_____________
Kari Kivisalo
Date: 25 Sep 2001 10:09:38
Message: <3bb09022@news.povray.org>
Oh yeah, sorry about forgetting what you said a few months ago concerning
that.  Thanks.
Does this mean only a LCD is liable to be okay for setting both display and
assumed gamma to 1.0?  Or is that okay for a CRT too?  I take it the answer
is no.
Bob H.
"Kari Kivisalo" <ray### [at] engineercom> wrote in message
news:3BB0662D.236C2598@engineer.com...
> are problematic.
> _____________
> Kari Kivisalo
Date: 25 Sep 2001 10:55:05
Message: <3bb09ac9@news.povray.org>
> is no.
You should be able to measure your display and have software adjust the
color representation accordingly.  Of course, with a CRT this is much easier
because its colors usually don't change much when viewed from a different
angle.  So, if you are up for a 'realistic' color representation, calibrated
output on a CRT is preferable over any LCD.  Of course, in a few years this
might change once better LCDs or other technologies are available.
    Thorsten
e-mail: tho### [at] trfde
Date: 25 Sep 2001 11:12:50
Message: <3BB09F2D.EAB9E5EB@engineer.com>
> is no.
When assumed_gamma=Display_Gamma the samples written to the image file
are linear. Easier way to make this happen is not to use assumed_gamma
at all.
It all depends on whether you want gamma correction or not. Because
povray can't do correction for LCD displays you have to find another
way to do it and have povray output linear samples. Most of the time
it's sensible to enable gamma correction when working with CRT.
You are of course free to use any means to get the image look good on
LCD but...
Then there is the problem of publishing images designed on LCD. Because
99% of images are not viewed on LCDs the LCD correction has to be removed
and (preferably) gamma 2.2 applied before publishing. When using 8 bit
samples this means the image will be in pretty bad shape after all these
conversions.
_____________
Kari Kivisalo
Date: 25 Sep 2001 12:54:44
Message: <3bb0b6d4@news.povray.org>
From all this discussions it's starting to seem to me that the best way
to go is just that POV-Ray would not write any gamma correction value to
the PNG. This way it works exactly like when writing to any other image
format.
  As this only requires commenting out 2 lines of the source code, it should
be easy to implement. Of course it can be discussed (for an eternity) whether
this really is the correct way of doing it.
  If the final version of 3.5 will behave like the current beta, I'll certainly
comment that part myself by hand when compiling the unix version. Of course
the Windows version will still have the problem as I don't have any compiler
for that...
Date: 25 Sep 2001 14:13:35
Message: <3bb0c94f$1@news.povray.org>
I insist on the png bug in beta 3 (and 4).
The png output is different from the bmp output, when I use Polyview as a
viewer program.
Beta 1, beta 2 and any other pov-ray version behaved okay and now something
has changed lately.
IIRC there was something "hacked".
Or am I too stupid to understand the whole discussion?
Norbert
"Warp" <war### [at] tagpovrayorg> schrieb im Newsbeitrag
news:3bb0b6d4@news.povray.org...
> format.
Date: 25 Sep 2001 14:30:57
Message: <3bb0cd61@news.povray.org>
I can confirm the bug here (beta 4, WinNT 4). It depends on the viewer
however : I have no problem with Micrografx Publisher but Microsoft Image
Composer and Netscape 6.1 show a clear difference.
G.
http://www.oyonale.com
Graphic experiments
Pov-ray gallery
Norbert Kern <nor### [at] t-onlinede> a écrit dans le message :
3badbff6$1@news.povray.org...
> Hi all!
>             1024 megs SDRam
only
> Norbert
Date: 25 Sep 2001 15:28:22
Message: <3bb0dad6@news.povray.org>
Norbert Kern <nor### [at] t-onlinede> wrote:
: The png output is different from the bmp output
  No, it isn't. It's just that POV-Ray outputs a gamma correction value to
the PNG which is not correct and the viewer program uses this gamma correction
value.
Date: 25 Sep 2001 15:29:19
Message: <3bb0db0f@news.povray.org>
Gilles Tran <tra### [at] inapginrafr> wrote:
: It depends on the viewer however
  This is because all programs do not support/use the gamma correction value
of the PNG file.
Date: 25 Sep 2001 15:41:18
Message: <3bb0ddde@news.povray.org>
news:3BB09F2D.EAB9E5EB@engineer.com...
and
answer
> > is no.
> at all.
Okay.  I stumbled across this web page that might be interesting to some:
http://positron.cs.berkeley.edu/gwlarson/vrml  (this is the directory
instead, I had some trouble using links there)
> LCD but...
> conversions.
Thanks for the reply as well Thorsten.  However the notebook LCD I have here
is probably not worth the effort to try and correct.  I sent the first one
back because of how the screen shifts in brightness from top to bottom.  I
thought getting a TFT Active Matrix kind would be better than it is for this
DELL.  My first experience with them and not a great one.  A trade off from
somewhat fuzzy, yet evenly lit, CRT to polarized-like, yet clear as it gets,
LCD.
Bob H.
Date: 25 Sep 2001 15:46:38
Message: <3bb0df1e@news.povray.org>
"Gilles Tran" <tra### [at] inapginrafr> wrote in message
news:3bb0cd61@news.povray.org...
Might want to have a look at the web pages I came upon authored by someone
from Silicon Graphics and IBM concerning linear gamma (?) for consistency in
VRML conversion to other renderers.  At least I think that was the idea
expressed.
Bob H.
