POV-Ray : Newsgroups : povray.beta-test : bug in texture_map Server Time
11 Nov 2026 00:26:37 EST (-0500)
  bug in texture_map (Message 1 to 17 of 17)
Subject: bug in texture_map
Date: 20 Sep 2001 10:10:49
Message: <3ba9f8e9$1@news.povray.org>
my machine is a PIII 450 MHz, 128 MB RAM and WinNT 4.0 Service Pack 5,
POV-Ray 3.5 Beta 2
The following code gives a parse error: Blend_Map too long
// Start of code //
#version 3.5;
camera {location <10, 10, -10> look_at <0.5, 0.5, 0.5>}
light_source {<10, 10,-10> color rgb 1}
plane {<0, 1, 0>, 0
       texture {cells
                texture_map
                        #declare i = 0;
                        #while (i <= 1)
                          #declare my_color = color rgb i
                          [i pigment{my_color}]
                          #declare i = i + 0.0078;
// End of code //
O.k. there are too many texture_map items.
Then I changed the #declare of "i" in the #while loop to:
#declare i = i + 0.0079;
Now there are no parsing errors but POV-Ray crashed immediately after the
render window appeared. After reloading POV-Ray and restarting the rendering
without any change on the scene file it renders fine. No problems. Very
strange! :-(
So long,
Bonsai
Subject: Re: bug in texture_map
Date: 20 Sep 2001 10:13:39
Message: <3ba9f993@news.povray.org>
Oh, this should have a semicolon at the end:
#declare my_color = color rgb i;
But the error is still there...
Bonsai
Date: 20 Sep 2001 11:41:10
Message: <3BAA0E55.36814667@b0n541.net>
Me again :-)
On an other machine (Athlon 1 GHz, 392 MB RAM, Win 98 SE, POV-Ray 3.5
Beta 2) POV-Ray tells me more about the problem:
A dialog box appears: Failed to allocate display bitmap
and in the render window I can read:
StretchDIBits () failed! (Windows error)
Hmm, maybe there is a problem with the editor and not with the
texture_map.
After restarting POV-Ray everything renders o.k.
Hope that helps...
So long,
Bonsai
Date: 21 Sep 2001 05:39:19
Message: <3bab0ac7@news.povray.org>
"Bonsai" <bon### [at] b0n541net> wrote in message
news:3BAA0E55.36814667@b0n541.net...
> texture_map.
No, it must be a bug.  Either that or Ron hasn't let us know (via Help docs)
that the cells pattern can't use above 128 entries in a blend (color) map.
Pretty bad crash you found there.  First time through it I didn't even get a
error dialog, although successive times did show me the usual kernel.exe
error.
The display failure kind of hints at something more to it but I didn't get
any such thing happening here so I don't know if it's related specifically
to that cells pattern crash or just a side effect.
Sure hope Ron Parker has some answers or it might be with us awhile.
Bob H.
Date: 21 Sep 2001 06:16:57
Message: <3bab1399@news.povray.org>
"Bob H." <omn### [at] msncom> schrieb im Newsbeitrag
news:3bab0ac7@news.povray.org...
docs)
I think it's related to the texture_map:
see 6.7.5.1  Texture Maps:
"There may be from 2 to 256 entries in the map."
The error also occurs after changing cells to leopard or an other pattern
type.
I was also able to reproduce the crash in POV-Ray 3.1g *but* only under my
Win98 SE environment. So it's not a new thing.
So long,
Bonsai
Date: 21 Sep 2001 07:00:28
Message: <3bab1dcc@news.povray.org>
news:3bab1399@news.povray.org...
> docs)
map.
> type.
Well... that's not good, is it...?  I can't recall a crash happening for a
texture map in a while loop and my last OS was Win98SE.
Bob H.
Date: 21 Sep 2001 10:10:27
Message: <slrn9qmiil.grj.ron.parker@fwi.com>
>error.
I am not responsible for the help docs, and I've never touched the cells
pattern, so I'm not sure why my name is being invoked here.
It's always been impossible to have more than 256 entries in a blend map;
I'm not sure where the 128 you mention comes from.
#macro R(L P)sphere{L __}cylinder{L P __}#end#macro P(_1)union{R(z+_ z)R(-z _-z)
R(_-z*3_+z)torus{1__ clipped_by{plane{_ 0}}}translate z+_1}#end#macro S(_)9-(_1-
_)*(_1-_)#end#macro Z(_1 _ __)union{P(_)P(-_)R(y-z-1_)translate.1*_1-y*8pigment{
rgb<S(7)S(5)S(3)>}}#if(_1)Z(_1-__,_,__)#end#end Z(10x*-2,.2)camera{rotate x*90}
Date: 21 Sep 2001 10:21:44
Message: <3bab4cf8@news.povray.org>
"Ron Parker" <ron### [at] povrayorg> schrieb im Newsbeitrag
news:slr### [at] fwicom...
It may come from my example because I put in 2 blend map entries per loop.
That's why POV-Ray gives a parse error after 128 loops in this scene.
So long,
Bonsai
Date: 21 Sep 2001 12:27:34
Message: <3bab6a76@news.povray.org>
news:3bab4cf8@news.povray.org...
map;
Oh yeah, okay, I see that now.  I just through the number 0.0079 into the
calculator thinking 1/0.0079 (or 0.0078) would be around 128.  I ignored the
double entry.  It is of course still only just greater that 128 and 126
respectively.  So somethings wrong there when it crashes at >128.
Sorry Ron, I was sure you were the author of the cells pattern and I had no
idea you were not.  Just so everyone knows besides me know who did, that
would be John VanSickle.
Bob H.
Date: 21 Sep 2001 12:40:20
Message: <slrn9qmrbm.h0s.ron.parker@fwi.com>
I'm sure you got that notion because I am responsible for crackle solid and
all of the other changes to crackle in 3.5.  I'm not really upset, just
don't want anyone who is in a position to fix the problem to shy away because
they think I'll look at it.
That's not to say I *won't* look at it, just to say that if someone else
gets to it first I don't want to discourage them from fixing it instead.
#macro R(L P)sphere{L F}cylinder{L P F}#end#macro P(V)merge{R(z+a z)R(-z a-z)R(a
-z-z-z a+z)torus{1F clipped_by{plane{a 0}}}translate V}#end#macro Z(a F T)merge{
P(z+a)P(z-a)R(-z-z-x a)pigment{rgbt 1}hollow interior{media{emission T}}finish{
reflection.1}}#end Z(-x-x.2y)Z(-x-x.4x)camera{location z*-10rotate x*90}
Date: 21 Sep 2001 13:04:49
Message: <3bab7331@news.povray.org>
"Ron Parker" <ron### [at] povrayorg> wrote in message
no
and
because
Yep, crackle I was certain of and you had mentioned cells enough for me to
associate you with it.
I checked and found that the last post around here by John was on the 7th of
this month to say he was leaving for a trip and wouldn't even be getting the
Beta of POV 3.5 to take along with him.  Been two weeks now so wonder if
he'll soon see about this? (talking to myself)
Ideally of course every feature's author would be the fix-it person.  Or
better yet, someone with extra know-how because I suppose troubleshooting
often goes beyond the part added into the source.  Goes without saying.  I
can only admire from afar.
Bob H.
Date: 21 Sep 2001 13:44:02
Message: <3BAB7D0C.2060101@inapg.inra.fr>
IIRC, John VanSickle is working for the Pentagon, so he may have some
other concerns right now.
And no, he's not in the (partial) missing person lists.
G.
http://www.oyonale.com
Graphic experiments
Pov-ray gallery
Date: 21 Sep 2001 13:54:43
Message: <3bab7ee3$1@news.povray.org>
"Gilles Tran" <tra### [at] inapginrafr> wrote in message
news:3BA### [at] inapginrafr...
I forgot that, thinking I remember something to that effect too.
Real glad you also said the last part too, thanks.
Bob H.
Date: 22 Sep 2001 01:32:40
Message: <3BAC2398.8B4DF1F2@pacbell.net>
John was working at the Pentagon but was transfered or relocated to
Germany several months ago. I think he is simply taking a vacation
right now.
Ken Tyler
Date: 28 Sep 2001 11:03:07
Message: <3bb4912b@news.povray.org>
> immediately after the render window appeared. After
> reloading POV-Ray and restarting the rendering without
> Very strange! :-(
I can confirm this bug.
Furthermore:
The bug also manifests itself if the texture is only declared but never
invoked. However, the crash happens after the render window appears, as
Bonsai pointed out.
The bug also manifests itself using a pigment_map, but not with a color_map.
After having rendered with i = i+0.0078 you can increase 0.0078 with any
number, and the bug still happens. For example you can change it to 0.1.
This code is enough to reproduce the bug:
#declare M =
   wood
   pigment_map {
      #declare i = 0;
      #while (i<1)
         [i, color rgb i]
         [i, color rgb i]
I'm using POV-Ray 3.5 beta 4
on a P150, 16MB RAM
Windows 95  4.00.450 B  IE 5 5.00.2919.6307
Rune
Rune's World:    http://rsj.mobilixnet.dk (updated June 26)
Date: 26 Nov 2001 13:01:41
Message: <qscdECA5WnA8Ew$A@econym.demon.co.uk>
Wasn't it Bonsai who wrote:
>Hi,
>POV-Ray 3.5 Beta 2
>// Start of code //
>#version 3.5;
>plane {<0, 1, 0>, 0
>       texture {cells
>                texture_map
>                        #declare i = 0;
>                        #while (i <= 1)
>                        #end
>// End of code //
>strange! :-(
I've just been doing a bit of checking through the known bugs list, and
can't seem reproduce this in beta 7. It was confirmed in beta 2 and
beta 4.
I reckon that it's now fixed and intend to remove it from the known bugs
list.
Mike Williams
Gentleman of Leisure
Date: 27 Nov 2001 02:05:39
Message: <3c033b43$1@news.povray.org>
"Mike Williams" <mik### [at] nospamplease> schrieb im Newsbeitrag
news:qscdECA5WnA8Ew$A@econym.demon.co.uk...
> beta 4.
> list.
I can't reproduce the crash either.
So long,
Bonsai
