![](/i/fill.gif) |
I want to use rsh to start povray on a remote machine, an intel Pentium
III, 1GHz, 512M ram, running linux 2.4.3aau4.
I am using povray 3.5.beta.RC5.
When I log in using rlogin and then start povray from the shell prompt
it works nicely, but when i start it directly using rsh:
rsh clusn2 ./povray +Ipovray35/scenes/advanced/skyvase.pov
it segfaults.
The problem seems to involve using SVGAlib for displaying,
but adding the flag -D does not help.
Fredrik
when I run:
rsh clusn2 strace ./povray +Ipovray35/scenes/advanced/skyvase.pov
I get:
write(2, "This copy expires in 3 day(s).\n", 31This copy expires in 3
day(s).
) = 31
write(2, "\n", 1
) = 1
ioctl(0, TCGETS, 0xbffffb90) = -1 EINVAL (Invalid argument)
--- SIGSEGV (Segmentation fault) ---
+++ killed by SIGSEGV +++
using gdb:
rsh clusn2 gdb ./povray
(gdb) set args +Ipovray35/scenes/advanced/skyvase.pov
(gdb) run
Starting program: /export/scratch/fjansson/./povray
This is a TIME LIMITED BETA TEST version.
Distribution in any form is EXPRESSLY PROHIBITED!
Program received signal SIGSEGV, Segmentation fault.
0x081f249d in strstr (phaystack=0x0, pneedle=0x82c53b5 "tty")
at ../sysdeps/generic/strstr.c:58
in ../sysdeps/generic/strstr.c
(gdb) 58 ../sysdeps/generic/strstr.c: No such file or directory.
(gdb) info stack
#0 0x081f249d in strstr (phaystack=0x0, pneedle=0x82c53b5 "tty")
#1 0x080f222e in SVGAMode () at unix.cpp:1179
#2 0x080f20cd in UNIX_init_povray (argc=0xbffffda0, argv=0xbffffda4)
at unix.cpp:908
#3 0x080c405c in povray_render (argc=3, argv=0xbffffe34) at
povray.cpp:429
#4 0x080c3efb in main (argc=3, argv=0xbffffe34) at povray.cpp:286
#5 0x081d2972 in __libc_start_main (main=0x80c3ddc <main>, argc=3,
ubp_av=0xbffffe34, init=0x80480b4 <_init>, fini=0x8228360 <_fini>,
rtld_fini=0, stack_end=0xbffffe2c) at
../sysdeps/generic/libc-start.c:129
![](/i/fill.gif) |
