![](/i/fill.gif) |
This code works in POVRay 3.1
3.5 complains about not being able to open the font file (wingdings.ttf) -
Other standard fonts seem to work. Most of my downloaded TTF files don't
work either, but that's ok - as long as the official Microsoft ttf's work...
can anyone confirm?
I don't use any other include files than colors.inc - so you can test this
code on 3.1 and 3.5.
sky_sphere{
agate
color_map{
[0.0 color Blue]
[0.5 color Gray75]
[1 color White]
scale .35
location <-.5, 1, -2.5>
//location <1.2, .7, -3 >
look_at <1.2, .7, 0>
#declare Green_Frame =
merge {
difference{
box {
<0, 0, 0>
<1, 1, 1>
scale <2.2, .8, .1>
box {
<0, 0, 0>
<1, 1, 1>
scale <2, .6, .2>
translate <.1, .1, -.05>
box {
<0, 0, 0>
<1, 1, 1>
scale <.1, .6, .2>
translate <.9, .1, 0>
text {ttf "arial.ttf" "Go" 1, 0
pigment { color White }
finish {specular .25}
scale .5
translate <.2, .2, 0>
text {ttf "arial.ttf" "Mail" 1, 0
pigment {color Black}
scale .5
translate <1.05, .2, 0>
#declare Granite_Block =
box {
<0,0,0>
<1,1,1>
scale <2.4, 1.5, 2.5>
#declare Envelope =
text {ttf "WingDings.ttf" "*" 1, 0
scale .4
#declare Domain =
text { ttf "arial.ttf" ".co.za" 1 ,0
scale .5
object { Granite_Block
granite
color_map {
[0.0 color rgb <.1, .1, .45>]
[0.1 color rgb <.3, .1, .6>]
[0.3 color rgb <.1, .3, .45>]
[1 color rgb <.3, .1, .5>]
scale .8
object { Green_Frame
bozo
color_map {
[0.0 color rgb <.3,.6,.3>]
[0.33 color rgb <.3,.3,.3>]
[0.66 color rgb <.1, .75, .1>]
[1 color rgb <.3, .5, .3>]
turbulence 2
scale .2
scale z*.5
translate <.1, .6, -.05>
object { Envelope
texture{
rotate z*30
translate <.25, .08 ,-.05>
object { Domain
pigment {color Black }
translate <.8, .2, -.05>
plane {
<0, 1, 0>, 0
color Blue
normal {
ripples
scale .4
translate <2, 1, 0>
finish {
reflection .7
specular .15
height_field {
tga "basic.tga"
smooth
agate
color_map {
[0.0 color Brown]
[0.5 color .3*Green]
[0.9 color Yellow]
scale .8
scale <20, 1, 20>
translate <-10, -.05, -5>
fog {
fog_type 2
distance 5
fog_offset .2
fog_alt .6
color White
turbulence .5
light_source {
<1.5, 1.5, -3>
color White
![](/i/fill.gif) |
