![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I could not see the 'first function in code initialisation problem'
listed in the current bug list, so maybe I'm trying something odd?
Here is the test code:-
// -- start ---
#declare f_PT = array [2]
#declare f_PT[0] = function { abs(sin(x)*sin(y)) }
#declare f_PT[1] = function { abs(sin(x)*sin(y)) }
plane { -z, 0
pigment { function { f_PT[0](x,y,z) } } // <- parse fails
finish { ambient 1 diffuse 0 }
location -30*z up y
direction 2*z look_at 0
// -- end --
As the code stands it fails parsing at the pigment statement with 'Parse
Error: Attempt to access an uninitialized array element.'
Using f_PT[1] works correctly.
Also if a line such as
#declare FIX = function {1}
is added at the start of the code, there is no problem using f_PT[0].
I think this (or a related) error was causing PoV to crash with a more
complex usage, not getting caught in the parser.
System: 1GHz Athlon, 256MB, WinNT4 sp6, PoV 3.5.beta.10 win32 (.icl)
Mike Andrews.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
On Wed, 06 Feb 2002 12:54:30 +0000, Michael Andrews <M.C### [at] reading ac uk>
I can confirm this behaviour, but I think it is somehow connected with arrays.
When you remove array (as below) then it works fine
// -- start ---
#declare f_PT0 = function { abs(sin(x)*sin(y)) }
#declare f_PT1 = function { abs(sin(x)*sin(y)) }
plane { -z, 0
pigment { function { f_PT0(x,y,z) } } // <- parse _not_ fails
location -30*z up y
// -- end --
POV 3.5 b 10 icl on WinNT Sp 6 PII 233 with 128 MB
ABX
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Subject: Re: Still a first function initialisation error?
Date: 6 Feb 2002 09:02:20
Message: <3c61376b@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Michael Andrews <M.C### [at] reading ac uk> wrote:
: f_PT[0](x,y,z)
I would guess that the parser just doesn't support this []() syntax (someone
forgot adding support for it, or whatever).
IMHO this should be fixed.
N(11117333955)N(4254934330)N(3900569407)N(7382340)N(3358)N(970)}// - Warp -
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
But when you use an array of simple pigments it works right, and if you
put any function declaration before the array function declarations it
also works ...
Mike.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>: f_PT[0](x,y,z)
Unlikely, since it reportedly works when you put in a subscript of 1.
Also, the tokenizer doesn't care about what comes after the []; it parses
the array reference at too high a level to care.
#macro R(L P)sphere{L F}cylinder{L P F}#end#macro P(V)merge{R(z+a z)R(-z a-z)R(a
-z-z-z a+z)torus{1F clipped_by{plane{a 0}}}translate V}#end#macro Z(a F T)merge{
P(z+a)P(z-a)R(-z-z-x a)pigment{rgbt 1}hollow interior{media{emission T}}finish{
reflection.1}}#end Z(-x-x.2y)Z(-x-x.4x)camera{location z*-10rotate x*90}
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Date: 6 Feb 2002 13:41:47
Message: <3c6178eb@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
In article <3C6### [at] reading ac uk> , Michael Andrews
If is a different bug with the same cause and symptoms. It will be fixed in
the next beta.
Thorsten
e-mail: tho### [at] trf de
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> the next beta.
> Thorsten
Hi Thorsten,
I'm glad it was an actual bug, and even happier you could fix it so
quickly :-)
Many thanks,
Mike Andrews.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> the next beta.
> Thorsten
Hi Thorsten,
Sorry, but the test code I posted now crashes beta 11, rather than being
System: Athlon 1GHz, 256MB, WinNT4 sp6, PoV-Ray 3.5.beta.11 win32 (.icl)
Mike Andrews.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Date: 11 Feb 2002 07:11:12
Message: <3c67b4e0@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Hmm, works fine for me. Maybe there is some side effect. I will check
this...
Thorsten
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
