Subject: [doc] adapting a paragraph in 6.4.2 (orthographic camera)
Date: 15 Jan 2002 11:49:32
Message: <3C445DAB.688AEA43@pandora.be>
I suppose in 3.5 beta 10 there's a change concerning the syntaxis for
using different types of cameras.
Paragraph 6.4.2. of the docs starts with:
The following list explains the different projection types that can be
used with the camera. The most common types are the perspective and
orthographic projections. In
general the CAMERA_TYPE should be the first item in a camera statement.
If none is specified, the perspective camera is the default.
But further we can read:
If you add the orthographic keyword after all other parameters of a
perspective camera you'll get an orthographic view with the same image
area
So to obtain an orthographic view in beta 10 one has to change the place
of the word "orthographic".
Herman Serras
Gent (Belgium)
http://cage.rug.ac.be/~hs/
Subject: Re: [doc] adapting a paragraph in 6.4.2 (orthographic camera)
Date: 15 Jan 2002 11:56:04
Message: <3c445f24@news.povray.org>
In article <3C445DAB.688AEA43@pandora.be> , Herman Serras
> area
Yes, this part of the docs has not been updated. It no longer matters where
"orthographic" appears to change its behavior. The "trick" explained in
this place in the docs now always works as long as any of the modifiers only
valid for perspective cameras are used. This change allows to require the
camera type to always be the first thing in a camera statement, which
corrects some misunderstandings of the previous functionality, but still
keeps previously all available features.
Thorsten
e-mail: tho### [at] trf de
The doc will be changed,
Ingo
Date: 15 Jan 2002 14:31:35
Message: <3c448397@news.povray.org>
"Thorsten Froehlich" <tho### [at] trf de> wrote in message
news:3c445f24@news.povray.org...
> > area
where
only
Camera type must be the first keyword in a camera statement now or the parse
will error.
bob h
Date: 15 Jan 2002 16:33:06
Message: <3c44a012@news.povray.org>
By the way, is 'angle' supposed to have some effect in a panoramic camera?
N(11117333955)N(4254934330)N(3900569407)N(7382340)N(3358)N(970)}// - Warp -
Date: 15 Jan 2002 17:04:05
Message: <3c44a755@news.povray.org>
In article <3c44a012@news.povray.org> , Warp <war### [at] tag povray org> wrote:
it depends on where it is in the camera statement...
Date: 15 Jan 2002 17:50:36
Message: <3c44b23c@news.povray.org>
Thorsten Froehlich <tho### [at] trf de> wrote:
:> By the way, is 'angle' supposed to have some effect in a panoramic camera?
: it depends on where it is in the camera statement...
So where does it have some effect?
Date: 15 Jan 2002 18:14:50
Message: <3c44b7ea$1@news.povray.org>
In article <3c44b23c@news.povray.org> , Warp <war### [at] tag povray org> wrote:
Some me your camera and I can explain what happens currently.
Date: 15 Jan 2002 18:48:47
Message: <3c44bfde@news.povray.org>
: Some me your camera and I can explain what happens currently.
angle seems to have no effect whatsoever:
camera
{ panoramic
location -z look_at 0
angle 30
light_source { y*100, 1 }
plane { y,-1 pigment { checker rgb 1, rgb .5 } }
Date: 15 Jan 2002 19:57:21
Message: <3c44cff1@news.povray.org>
In article <3c44bfde@news.povray.org> , Warp <war### [at] tag povray org> wrote:
> camera
> { panoramic
> angle 30
Is angle supposed to work with other camera types than "perspective"?
Thorsten
