POV-Ray : Newsgroups : povray.beta-test : semicolon not expected Server Time
20 Mar 2026 08:35:36 EDT (-0400)
  semicolon not expected (Message 1 to 10 of 18)
Subject: semicolon not expected
Date: 7 Jan 2002 02:21:17
Message: <jmii3uc9k44v8s2rrmqi9kv9fn7j71v6ss@4ax.com>
POV 3.5 b 9.icl on PII 233 128 MB with NT 4 Sp 6
POV 3.5 b 9.icl on PII 233 128 MB with Win 95 OSR2
below script causes parsing error
"Expected 'object or directive', ; found instead"
#macro Test1()          1      #end
#macro Test2() #if(yes) 2 #end #end
#local F=Test1()   // works
#local F=Test1();  // works
#local F=Test2()   // works
#local F=Test2();  // not
Any confirmation ?
ABX
Subject: Re: semicolon not expected
Date: 7 Jan 2002 07:18:46
Message: <3c399226@news.povray.org>
> Any confirmation ?
Semicolons are listed as required after every #local, #declare and #version
with a float, vector or color value.  If you don't include the required
semicolon the problem is in your scene and the parser reports it as soon as
it is possible to report this.
    Thorsten
e-mail: tho### [at] trfde
Date: 7 Jan 2002 07:30:24
Message: <s35j3us07nout2lghojdb674e6bjbl3eeo@4ax.com>
On Mon, 07 Jan 2002 13:18:44 +0100, "Thorsten Froehlich" <tho### [at] trfde>
I think you misunderstand my report so I post shorter example:
#local F=Test2();
note: there is semicolon but parser expects object or directive
ABX
Date: 7 Jan 2002 07:41:15
Message: <3c39976b$1@news.povray.org>
> #local F=Test2();
Indeed, I agree that this should work.
    Thorsten
Date: 7 Jan 2002 09:00:15
Message: <3c39a9ef@news.povray.org>
: #macro Test2() #if(yes) 2 #end #end
: #local F=Test2();
  Isn't the "right way" of returning values from a macro something like:
#macro Test2() #if(yes) #local res=2; #end res #end
Date: 7 Jan 2002 10:47:00
Message: <3c39c2f4@news.povray.org>
In article <3c39a9ef@news.povray.org> , Warp <war### [at] tagpovrayorg>  wrote:
Hmm, what do the docs say about this?  Maybe it should be made clear that
only data appearing in the macro block itself is considered a return
value...
    Thorsten
Date: 7 Jan 2002 10:51:20
Message: <5tgj3u8clfje8f8pialrkg9oesbfirv7d7@4ax.com>
On Mon, 07 Jan 2002 16:46:55 +0100, "Thorsten Froehlich" <tho### [at] trfde>
> value...
6.2.8.3
ABX
Date: 7 Jan 2002 13:54:43
Message: <3C39EFF8.C144AAFF@hotmail.com>
Thorsten Froehlich wrote:
> ABX
> > #local F=Test2();
The problem appears under 3.1g as well, with the same fix as is
given elsewhere in this thread.
ICQ: 46085459
Date: 7 Jan 2002 14:39:18
Message: <3c39f966@news.povray.org>
> be made clear that only data appearing in the macro
> block itself is considered a return value...
It doesn't have anything to do with macros at all, as this also generates an
error:
#declare C = #if(1) 1 #else 2 #end ;
Rune
Rune's World:    http://rsj.mobilixnet.dk (updated Jan 2)
Date: 7 Jan 2002 17:10:53
Message: <chrishuff-99EEE5.17113807012002@netplex.aussie.org>
In article <3c39f966@news.povray.org>,
> error:
If you wrap the conditional in parentheses, it will work fine:
#declare C = (#if(1) 1 #else 2 #end);
#macro Test2() (#if(yes) 2 #end) #end
#local F = Test2();
