POV-Ray : Newsgroups : povray.beta-test : Field rendering status Server Time
10 Nov 2026 23:32:15 EST (-0500)
  Field rendering status (Message 1 to 15 of 15)
Subject: Field rendering status
Date: 27 Oct 2001 14:30:26
Message: <3BDAFCBA.3E20163C@geocities.com>
Soo.....
After looking into it again, I think it's clear that POV-Ray is doing
things a little bit halfway compared to other 3D & video packages.
However, my off-hand guess is that it would take a bit of work to get
things to save two fields per one file. :-(
So, does this then chang it from a bug to "works as designed", and thus
changing it becomes a feature-request instead of a bug-fix?
If it's WAD, I could probably write up a new bit for the docs to explain
it better.
Jon A. Cruz
http://www.geocities.com/joncruz/action.html
Subject: Re: Field rendering status
Date: 27 Oct 2001 15:07:43
Message: <3bdb05ff@news.povray.org>
In article <3BDAFCBA.3E20163C@geocities.com> , "Jon A. Cruz"
> it better.
Well, POV-Ray could automatically use half the clock step size and thus
generate as many frames as expected (twice as many as it does not)...
    Thorsten
e-mail: tho### [at] trfde
Date: 27 Oct 2001 15:28:48
Message: <3bdb0af0$1@news.povray.org>
I imagine it would be very hard to fix this, because POV would have to parse
what is internally two separate scenes for a single frame.
Someone needs to write a program that will take the output images and
combine them as necessary. =)
- Slime
[ http://www.slimeland.com/ ]
[ http://www.slimeland.com/images/ ]
"Jon A. Cruz" <jon### [at] geocitiescom> wrote in message
news:3BDAFCBA.3E20163C@geocities.com...
> Soo.....
> it better.
> Jon A. Cruz
Date: 29 Oct 2001 05:44:08
Message: <3BDD3334.DEFED0A4@atosorigin.com>
"Jon A. Cruz" wrote:
> Soo.....
Two fields per file is a BAD idea. Where is the gain when one would only
want to rerender the odd fields
(on one computer, and the even fields on another).
When doing fields thing, at 25fps, I believe it's normal to have to provide
50 files per second. The content of each file may have to be adapted for
the current animation softwares, but that's another story.
Date: 29 Oct 2001 13:19:14
Message: <3bdd9da2$1@news.povray.org>
-Hail
  You say it is a bad idea, that claerly shows that you never did any work
involving video. I tried once to use pov for my multimedia projects and I
almost lost my job because I was trying to get the field rendering to work
proprly in the end I scrapped this idea because I had no choice, then on my
spare time I figured out the way to do this right, it involved many tests
with many types of footage. The conclusion I came to is clear and I dont see
why you could be against this. Name one piece of software or hardware that
will accept this format.
Date: 29 Oct 2001 13:27:26
Message: <3bdd9f8e@news.povray.org>
In article <3bdd9da2$1@news.povray.org> , "Vampyrium"
QuickTime and all the DVD tools Apple sells (which have more than 50% DVD
authoring market share), Adobe Premiere, ...
    Thorsten
Date: 29 Oct 2001 13:43:47
Message: <3bdda363@news.povray.org>
-Hail
  So, this is an apple thing. If you check out Adobe Premiere (PC version)
you will find otherwise. Anyhow this topic should have been resolved by now,
since it isnt lets come to a final solution that remains permanent as this
is taking up useful time from both sides.
Date: 29 Oct 2001 14:15:08
Message: <3bddaabc@news.povray.org>
In article <3bdda363@news.povray.org> , "Vampyrium" <cyb### [at] hotmailcom>
No, it isn't.  As there should be no difference between the Premiere
versions on Macs and PCs.  Also the other remaining DVD authoring software
company Sonic/Daikin (they recently merged) seems to supports such import
with their products (I don't know anybody who has access to those).  So I
really don't see a problem other than that POV-Ray doesn't adjust the clock
frequency to create twice as many images when field rendering is used - and
that is a really simple to "fix" problem.
If you have a problem importing the format in Adobe Premiere I can try to
find someone who has the PC version and send you detailed instructions for
PCs if you think the PC version is different...
    Thorsten
Date: 29 Oct 2001 14:43:52
Message: <3bddb178@news.povray.org>
I have the PC version of Adobe Premiere, and although I haven't used it
extensively enough to say that this is or is not possible, I would
appreciate instructions on how POV's feild rendering could be imported into
it. As far as I can tell, from the way it uses feild rendering *itself* with
transitions and things, the two-feilds-in-one-frame method (the one POV
*doesn't* do) is the necessary one.
- Slime
"Thorsten Froehlich" <tho### [at] trfde> wrote in message
news:3bddaabc@news.povray.org...
version)
clock
and
>     Thorsten
Date: 29 Oct 2001 15:48:10
Message: <3bddc08a@news.povray.org>
I figured this out. First import the file (or list of still frames) through
File -> Import. Then place the clip onto the timeline. Right click on the
clip and go to Video Options -> Field Options. Select "Interlace consecutive
frames."
Then choose the Rate Stretch Tool (next to the razor blade tool) and shrink
the clip to half it's length.
That should give you what you want.
- Slime
"Slime" <noo### [at] hotmailcom> wrote in message
news:3bddb178@news.povray.org...
into
with
> - Slime
> version)
software
import
I
> clock
> and
to
for
> >     Thorsten
Date: 30 Oct 2001 16:06:11
Message: <3bdf24bd.24374094@news.povray.org>
On Sat, 27 Oct 2001 11:28:10 -0700, "Jon A. Cruz"
Here's an idea:
Allow the option of possibly not doubling up the feild lines, but
instead leaving them black. This will make it easier to make a utility
to combine different frames as you can just load two frames into an
array and simply add the frames to eachother- as opposed to the
slightly more complicated process of figuring out which elements are
the correct rows and interlacing them into a single frame.
Just an idea.
Also, it might be possible to make a script in povray SDL to combine
odd and even frames into single frames by forming a triangle mesh- two
triangles for each line and image mapping the appropriate image onto
each set of lines.
Again.. just some ideas.
I don't really know much about the povray source code so disregard the
following if it sounds really stupid, but.. for every other frame, why
couldn't povray just reopen the rendered image for the last frame and
replace the approprate rows with the rows for the current frame?
It does seem sort of ridiculous to render the two frames in parralel.
But would it really be hard to just reopen the image from the last
frame for the current frame?
Date: 30 Oct 2001 21:28:32
Message: <3bdf61d0@news.povray.org>
-Hail
  And here is yet another idea:
 Parse scene, render even fields (unless odd field flag is on) leaving odd
fields blank. parse next frame, render odd fields leaving even fields blank.
And start over on the next frame. If this method is used then antialiasing
should be taken care of not to intermingle with with the opposite field
(horizontal antialiasing?). Of course antialiasing is not very important
when working with interlaced material so it could be turned off.
Date: 2 Nov 2001 00:37:41
Message: <3BE2310F.19AEBD2B@geocities.com>
So, it's an import option. However,  Jérôme stated that the
both-fields-per-frame idea was bad and unsupported. It's the opposite. It's the
normal way for the field. (And at the multimedia company I was at, we used both
the mac and windows versions of Premier.)
But Thorsten points out that the POV images  _can_ work with Premier. However
for broadcast resolutions (720 x 485 or 720 x 576) the standard CCIR 601 format
is interlaced.
So I'd say it would be nice if the POV team had time and inclination to change
the output, however a simple documentation change makes it compatible with most
home-user software anyway, so no big deal.
Jon A. Cruz
Date: 2 Nov 2001 04:41:26
Message: <3be26a46@news.povray.org>
In article <3BE2310F.19AEBD2B@geocities.com> , "Jon A. Cruz"
> most home-user software anyway, so no big deal.
Which I would like to hand over to the documentation coordinator ;-)
    Thorsten
Date: 2 Nov 2001 07:12:09
Message: <Xns914D864DEB765seed7@povray.org>
> explain it better.
Who knows nothing about field rendering and has to rely on somebody
else to write a piece. Jon?
Ingo
