POV-Ray : Newsgroups : povray.beta-test : default camera angle in Doc Server Time
10 Nov 2026 23:56:26 EST (-0500)
  default camera angle in Doc (Message 1 to 12 of 12)
Subject: default camera angle in Doc
Date: 16 Oct 2001 04:32:09
Message: <3BCBF089.CBB50DBB@chez.com>
hello pov.monde
In the doc:
http://www.povray.org/working-docs/id000158.html#6_4_1_3
was it possible to add the default angle value used if no
angle given ?
Thierry, (42++)++     :::      http://la.buvette.org/exPOV/
Subject: Re: default camera angle in Doc
Date: 16 Oct 2001 06:31:54
Message: <3bcc0c9a@news.povray.org>
"Thierry B." <oul### [at] chezcom> wrote in message
news:3BCBF089.CBB50DBB@chez.com...
> hello pov.monde
> In the doc:
> angle given ?
If you are asking about what the default is or if it should be added to the
documentation I have only found it to be approximately angle 67 for the
perspective projection camera.  When I try to find that according to the
formula mentioned in that section, "direction_length = 0.5 * right_length /
tan(angle / 2) where right_length is the length of the right vector", I come
up with about 'direction 0.56' which is just more than half of what it ought
to be.  I just don't know if I'm figuring that correctly.  Although I have
compared a direction 1 to angle 67 and managed to see nearly an equivalence.
I haven't checked again recently to see if it remains that way, but it might
be okay to add that angle defaults to approx. 67 in the documentation if it
is so.  Either that or someone needs to provide an exact number for it I
guess.
Bob H.
Date: 16 Oct 2001 11:35:07
Message: <3bcc53ab$1@news.povray.org>
come
ought
> to be.
Really? I come up with 1.00722346241. The exact value for angle is 2 atan
(2/3), or about 67.38013502.
Anders
Date: 16 Oct 2001 11:45:54
Message: <3bcc5632$1@news.povray.org>
Speaking of this, in doc sections 6.4.1.5.1 and 6.4.1.5.2, it says that the
default value for right is <1.33, 0, 0>. Shouldn't this be <4/3, 0, 0>, as
stated in section 6.4.1.5?
Date: 16 Oct 2001 12:18:31
Message: <3bcc5dd7$1@news.povray.org>
"Anders K." <and### [at] f2scom> wrote in message
news:3bcc5632$1@news.povray.org...
Hmm, AFAIK 4/3 cannot be expressed accurately in either dec. or bin. - both
therefore look like approximations - or did you just mean for consistency's
sake?
Date: 16 Oct 2001 12:41:34
Message: <3BCC633C.FFF910D0@gmx.de>
> sake?
To clarify things, the default right vector is 1.33*x so this is what the
docs should say too IMO.
Date: 16 Oct 2001 15:16:00
Message: <3bcc8770@news.povray.org>
news:3bcc53ab$1@news.povray.org...
right_length
> come
> ought
> > to be.
Right.  Well, apparently tan 67/2 isn't a good way to go about calculating
it.  I left off the parentheses in my quick attempt  :-)
Bob H.
Date: 16 Oct 2001 17:27:46
Message: <3bcca652$1@news.povray.org>
If the default right vector is really 1.33*x and not 4/3*x then that is a
program bug (or design flaw, or whatever), since the aspect ratio of the
images it normally produces is *exactly* 4 to 3 and not 1.33 to 1.
Of course, I realize that 1.33 is an "approximation" to 4/3, but IMO it's a
pretty bad approximation, especially for large images. And in this case
there is no need to approximate at all (other than the internal floating
point rounding error, which is going to be much, much less than .01). So I
think that both the program and the docs should use 4/3.
Anders
Date: 17 Oct 2001 03:31:52
Message: <Xns913D60F49492Aseed7@povray.org>
> what the docs should say too IMO.
If this value comes from the source, I'll match the documentation.
Ingo
Date: 17 Oct 2001 07:30:00
Message: <3BCD6BC0.48ED3CCC@gmx.de>
It does (in Povray 3.1)
Date: 17 Oct 2001 15:34:02
Message: <3bcddd29@news.povray.org>
ingo <ing### [at] homenl> wrote:
: If this value comes from the source, I'll match the documentation.
  Also I think that it's the source which should be fixed (to 4.0/3.0).
Date: 17 Oct 2001 17:36:10
Message: <Xns913DF01946A88seed7@povray.org>
>   4.0/3.0).
Could The Team take a position on this so I can make the appropriate
changes?
Ingo
