POV-Ray : Newsgroups : povray.beta-test : Known Bugs 24 Dec 2001 (beta 9) Server Time
27 Mar 2026 17:54:21 EDT (-0400)
  Known Bugs 24 Dec 2001 (beta 9) (Message 8 to 17 of 37)
<<< Previous 7 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: Known Bugs 24 Dec 2001 (beta 9)
Date: 26 Dec 2001 16:52:11
Message: <slrna2khkd.c4m.ron.parker@fwi.com>
On Mon, 24 Dec 2001 00:12:32 +0000, Mike Williams wrote:
> Delayed syntax checking (job000192)
> (declare without the "#" can cause a much later line to fail to parse
> Parser will ignore the first token following old-style declares without
> a #.)
> http://news.povray.org/AM3LOAABMO27EwFh@econym.demon.co.uk
Fixed for next time.
Change 1297 by parkerr on 2001/12/26 16:44:11
	If a declare doesn't start with a '#' don't allow the optional
	semicolons.  This shouldn't be a problem, as the hash-less syntax
	has been deprecated for at least two versions now and the optional
	semicolons are new with this version.
	This is a roundabout bugfix for a problem where declare without the
	hash would ignore the following token.
#macro R(P)z+_(P)_(P)_(P+1)_(P+1)+z#end#macro Q(C,T)bicubic_patch{type 1u_steps
6v_steps 6R(1)R(3)R(5)R(7)pigment{rgb z}}#end#macro _(Y)#local X=asc(substr(C,Y
,1))-65;<T+mod(X,4)div(X,4)9>-2#end#macro O(T)Q("ABEFUQWS",T)Q("WSXTLOJN",T)#
end O(0)O(3)Q("JNKLCGCD",0)light_source{x 1}// ron### [at] povrayorg
Date: 26 Dec 2001 19:53:56
Message: <3C2A7123.E923B0B4@spiritone.com>
I'm not sure if this is a bug or not but POV-Ray spits out a bunch of
information in the message window on the Macintosh version. I have
posted a screenshot of the warnings generated at the end of a trace. I
think it is reporting on information for each object in the scene.
Josh English
eng### [at] spiritonecom
http://www.spiritone.com/~english
Date: 27 Dec 2001 02:29:47
Message: <3c2acdeb@news.povray.org>
> > a #.)
On a related note, it'd be helpful if words such as "declare" weren't
syntax-highlighted when they didn't have the #.
- Slime
[ http://www.slimeland.com/ ]
[ http://www.slimeland.com/images/ ]
Date: 27 Dec 2001 02:48:47
Message: <FHjm+BAv5sK8Ew5O@econym.demon.co.uk>
>> sin(X)^sin(X) -> crash! (job000179 and job000180)
>> http://news.povray.org/3baf7992@news.povray.org
>This does not crash in beta9. At least not with the MSVC compile.
It still crashes with "invalid page fault" on my machine.
Mike Williams
Gentleman of Leisure
Date: 27 Dec 2001 02:48:49
Message: <9Wg4KFAiAtK8EwPv@econym.demon.co.uk>
I can't seem to find anything that can interpret that image.
Is it just the list of isosurface max_gradient suggestions?
Can you not save the text from the message window on a Mac, and post
that rather than a platform-specific screen grab.
Mike Williams
Date: 27 Dec 2001 06:17:52
Message: <3c2b0360$1@news.povray.org>
In article <3C2A7123.E923B0B4@spiritone.com> , Josh English
Yes, these messages exist.  Just ignore them.
    Thorsten
e-mail: tho### [at] trfde
Date: 27 Dec 2001 10:45:17
Message: <slrna2mggf.eil.ron.parker@fwi.com>
>> > a #.)
That might look pretty, but it'll smack you in the face when you find out
that the parser still recognizes them without the # as well.
#macro R(L P)sphere{L __}cylinder{L P __}#end#macro P(_1)union{R(z+_ z)R(-z _-z)
R(_-z*3_+z)torus{1__ clipped_by{plane{_ 0}}}translate z+_1}#end#macro S(_)9-(_1-
_)*(_1-_)#end#macro Z(_1 _ __)union{P(_)P(-_)R(y-z-1_)translate.1*_1-y*8pigment{
rgb<S(7)S(5)S(3)>}}#if(_1)Z(_1-__,_,__)#end#end Z(10x*-2,.2)camera{rotate x*90}
Date: 27 Dec 2001 13:46:45
Message: <3C2B6C8F.86790EB3@spiritone.com>
>     Thorsten
I would love to, but a six second render has spent the last ten minutes
spitting out these messages and it has made beta 9 completely unusable.
I tossed the prefs but it hasn't helped.  I thought earlier versions had
a preference to stop output to some render streams but I can't find any
preference like that in the current version.
Josh English
Date: 27 Dec 2001 13:53:25
Message: <3C2B6E24.C97D8BF3@spiritone.com>
It's a Macintosh PICT file
Nope. No isosurfaces in the scene.
The message window prints things in chunks and you can only select one
chunk at a time. I would be here until Michelmas cutting and pasting
thousands of messages.
Here are a few:
 NULL, // UV_Trans
 0.000000, // Ph_Density
 0x92, // Flags
 { -1.000000, 0.000000, -2.000000 }, // apex
 { -2.000000, -0.000000, -0.000000 }, // base
  0.200000, // apex_radius
And the message window looks like it's scrolling every time you select
something new or bring the window to the front, so each copy and paste
takes about ten seconds to wait for the scroll.
Josh English
Date: 27 Dec 2001 15:53:02
Message: <3c2b8a2e@news.povray.org>
In article <3C2B6E24.C97D8BF3@spiritone.com> , Josh English
> chunk at a time.
You can save the whole output window contents via the File menu.
The messages will only be there for spheres, cones and text objects.
The problem exists only in the Mac version and there is no way to turn them
off.  My time does not permit to upload a new beta 9 without these debug
messages.  Sorry!
    Thorsten
Thorsten Froehlich
e-mail: mac### [at] povrayorg
I am a member of the POV-Ray Team.
