POV-Ray : Newsgroups : povray.beta-test : HF Macros - serious bug, optimizations and little suggestion Server Time
10 Nov 2026 21:20:01 EST (-0500)
  HF Macros - serious bug, optimizations and little suggestion (Message 1 to 6 of 6)
Subject: HF Macros - serious bug, optimizations and little suggestion
Date: 16 May 2002 02:59:03
Message: <28k6eu8aqjsbge8bfgjhgbpk609jd8jp2q@4ax.com>
RC4 for Win
Currently HF Macros works only when resolution <xRes,zRes> is specified with
xRes=zRes. For xRes<>zRes it stops parsing with error in face_indices. It is
becouse little but important mistake in last loop of HFCreate_() macro:
         #local A = (J  )+(K  )*zRes;
         #local B = (J+1)+(K  )*zRes;
         #local C = (J+1)+(K+1)*zRes;
         #local D = (J  )+(K+1)*zRes;
         <A,B,C>,<A,C,D>,
should be:
         #local A = (J  )*zRes+(K  );
         #local B = (J+1)*zRes+(K  );
         #local C = (J+1)*zRes+(K+1);
         #local D = (J  )*zRes+(K+1);
         <A,B,C>,<A,C,D>,
But since I was in this part I started to optimize this stuff. Note that
optimized part is exactly the same as:
         #local B = A + zRes;
         #local C = A + zRes + 1;
         #local D = A + 1;
         <A,B,C>,<A,C,D>,
But then it is exactly the same as:
         #local A = J*zRes+K;
         <A,A+zRes,A+zRes+1>,<A,A+zRes+1,A+1>,
         <0,zRes,zRes+1>+A,<0,zRes+1,1>+A,
But then it is exactly the same as (extending quoted part to whole loop):
   #local F1=<0,zRes,zRes+1>;
   #local F2=<0,zRes+1,1>;
   #local J=0;
   #while (J<xRes-1)
      #local K=0;
      #while (K<zRes-1)
         #local A=J*zRes+K;
         F1+A,F2+A,
         #local K=K+1;
      #local J=J+1;
But then A contains constant part J*zRes so why not move it before K-loop :
   #local J = 0;
   #while (J<xRes-1)
      #local A = J*zRes;
      #local K = 0;
      #while (K<zRes-1)
         F1+A,F2+A,
         #local A = A+1;
         #local K = K+1;
      #local J = J+1;
But then do we really need two indexes A and K ?
   #local J=0;
   #while (J<xRes-1)
      #local A=J*zRes;
      #while (mod(A+1,zRes))
         F1+A,F2+A,
         #local A=A+1;
      #local J=J+1;
Now it is little less readable but in my tests decreased parsing time from 36
seconds to 32 seconds. So let's look into two other loops in HFCreate_. Do we
really need to assign exported value to variable and then export it and forget
variable ? Can't we remove assigment ?
            #local Nvect =
            vnormalize(vcross(
               PArr[J][K+1]-PArr[J][K-1],
               PArr[J+1][K]-PArr[J-1][K]
            Nvect,
could be just:
            vnormalize(vcross(
and
            #local UVvect = <(J-1)/(xRes-1),(K-1)/(zRes-1)>;
            UVvect,
could be just:
            <(J-1)/(xRes-1),(K-1)/(zRes-1)>,
This change decreased parsing time for next 2 seconds. So alltogether I saved
~11% of parsing. I measured time of parsing scenes/incdemo/shapes.pov. I have
also little suggestion to this file. Perhaps could be good to additionaly
present UV-mapping on those macros. Just change apropriate parameter of macros
and change pigment{rgb1} to something like pigment{checker scale .1}.
ABX
Subject: Re: HF Macros - serious bug, optimizations and little suggestion
Date: 16 May 2002 07:44:49
Message: <3CE39BC9.E5F906F1@atosorigin.com>
"Włodzimierz ABX Skiba" wrote:
[About a bug, maybe he is right, I do not know]
>          <A,B,C>,<A,C,D>,
>          #local D = A + 1;
>          <A,B,C>,<A,C,D>,
I do not agree.
Mathematically, you are correct.
But Computationaly, you may end up with overlapping part and holes,
because the way you compute the coordinates are not always
exactly the same when you are iterating in the loop.
Maybe I'm just paranoid.
Date: 16 May 2002 09:32:59
Message: <n5d7eukjgaek8u1steguvccorcd7dfgqbi@4ax.com>
On Thu, 16 May 2002 13:45:13 +0200, J�r�me Grimbert
What you mean ? This time I have tested my suggestions.
ABX
Date: 16 May 2002 10:17:55
Message: <3CE3B24B.92CE09BD@frege.mathematik.uni-freiburg.de>
What I think J'er^ome means is that you assert the distributive law,
ie (a+b)*c=a*c+b*c. This law holds mathemtically but not
numerically. Counterexample:
  (2.01+2.01)*0.5 = 4.02*0.5 = 2.01
  2.01*0.5+2.01*0.5 = 1.00+1.00 = 2.00
or
  2.01*0.5+2.01*0.5 = 1.01+1.01 = 2.02
depending on how you round 1.005. This example uses 3-digit base-10
representation.
  Mark Weyer
Date: 16 May 2002 10:33:51
Message: <4hg7eu8ttso70cs3abpbvf06gmli6knftl@4ax.com>
On Thu, 16 May 2002 15:21:15 +0200, Mark Weyer
Each of components is integer (or should be becouse everything is float
internally during parsing). If integers are represented with very small
floating point accuracy then such problem appear for original version in
macros as well so my optimizations are still valid.
ABX
Date: 16 May 2002 18:49:28
Message: <3ce43778@news.povray.org>
ABX,
thanks for the bug fix and the optimizations.
Rune
Rune's World:  http://rsj.mobilixnet.dk (updated Apr 14)
POV-Ray Users: http://rsj.mobilixnet.dk/povrayusers/
POV-Ray Ring:  http://webring.povray.co.uk
