POV-Ray : Newsgroups : povray.beta-test : Gamma question Server Time
10 Nov 2026 18:47:07 EST (-0500)
  Gamma question (Message 1 to 5 of 5)
Subject: Gamma question
Date: 23 Nov 2009 10:14:33
Message: <20091123121431.7c03a3e7.john@johncoppens.com>
Hello people.
I understand 3.7beta > 10 has now gamma-enabled by default, at 2.2 if I
understand correctly.
I have this scenario: A simple box, with an image_map projected from a
PNG image (which, I understand, defines it's proper gamma). I declared a
finish (ambient 1), and I don't use any light source (I wanted to have a
garanteed uniform lighting).
The rendered image is way too light. I can only return to normal results
if I disable gamma, by defining assumed_gamma 2.2).
What am I doing wrong here? Shouldn't the process be transparent in this
case?
John.
(This is 3.7beta34, compiled on linux)
Subject: Re: Gamma question
Date: 23 Nov 2009 11:34:20
Message: <4b0ab98b@news.povray.org>
  You have to specify the assumed gamma for the image used in the image_map.
  This feature has not yet been implemented. It will be implemented in a
future beta. (It may even be possible to specify a default assumed gamma
for all input images.)
Date: 23 Nov 2009 12:40:27
Message: <4b0ac90b@news.povray.org>
Speaking of future beta, the current one has expired 7 weeks ago. Is
there any estimate for beta 35 release?
Date: 23 Nov 2009 19:59:34
Message: <20091123215933.72d97f39.john@johncoppens.com>
On 23 Nov 2009 11:34:20 -0500
> image_map.
Just asking - isn't the gamma for PNG images defined in the image?
> future beta.
Ok, so I'm suspecting to be correct in disabling gamma correction then -
as the image is the only object I'm interested in (at the moment) is the
image_map, I have now a 1:1 from input to output.
Thanks!
John
Date: 23 Nov 2009 20:49:18
Message: <4b0b3b9e@news.povray.org>
> > image_map.
  POV-Ray 3.7 is not yet taking into account the input PNG gamma info
properly, IIRC.
> > future beta.
  You could also use #version 3.6 to make it use the same settings as
POV-Ray 3.6. That will most probably work on the final version of 3.7
as well.
