POV-Ray : Newsgroups : povray.beta-test : bug with #declare order Server Time
10 Nov 2026 23:32:20 EST (-0500)
  bug with #declare order (Message 1 to 22 of 22)
Subject: bug with #declare order
Date: 26 Oct 2001 05:44:58
Message: <1nbitto64ipgqujonpn6m6r7097rsol9ec@4ax.com>
platform: POV35b6 on PII233 128 MB with NT4 SP6
I hope it is not a limitation like #if inside #if
two-line script
  #declare A#declare A=0;=1;
  #warning str(A,0,0)
prints 1 and I expected it
but script
  #declare A=#declare A=0;1;
  #warning str(A,0,0)
prints 0 but I expected 1
but what is most strange when I joined both
  #warning str(A,0,0)
  #warning str(A,0,0)
it twice prints 1
but when I changed it to (replaced second A with B)
  #warning str(A,0,0)
  #declare B=#declare B=0;1;
  #warning str(B,0,0)
it prints 0 and 1
ABX
#declare _=function(a,b,x){((a^2)+(b^2))^.5-x}#default {pigment{color rgb 1}}
union{plane{y,-3}plane{-x,-3}finish{reflection 1 ambient 0}}isosurface{ //ABX
function{_(x-2,y,1)|_((x+y)*.7,z,.1)|_((x+y+2)*.7,z,.1)|_(x/2+y*.8+1.5,z,.1)}
contained_by{box{<0,-3,-.1>,<3,0,.1>}}translate z*15finish{ambient 1}}//POV35
Subject: Re: bug with #declare order
Date: 26 Oct 2001 06:20:39
Message: <3bd938f7@news.povray.org>
In article <1nbitto64ipgqujonpn6m6r7097rsol9ec@4ax.com> , W„odzimierz ABX
> two-line script
>   #warning str(A,0,0)
> but script
>   #warning str(A,0,0)
>   #warning str(A,0,0)
>   #warning str(A,0,0)
> it twice prints 1
>   #warning str(A,0,0)
>   #warning str(B,0,0)
> it prints 0 and 1
While I agree that the behavior is confusing, for versions up to and
including 3.5 and any 3.x version or bug fix release that may follow, assume
the behavior of nesting directives inside other directives is not specified.
So the answer is: Don't use it (also the parser allows it) because the
behavior is unlikely to be made consistent before a rewrite of POV-Ray.
    Thorsten
e-mail: tho### [at] trfde
Date: 26 Oct 2001 06:46:30
Message: <dueitto7imgspv5ojmn81htn9pvbof35v0@4ax.com>
On Fri, 26 Oct 2001 12:20:37 +0200, "Thorsten Froehlich"
While I can get such answer, shouldn't be such sentence builded into
documentation instead of "directives can appear in almost any place in
the scene file - even in the middle of some other statements". You
wrote "the behavior of nesting directives inside other directives is
not specified". What about #macro inside #macro? #switch inside
#switch? Or mixing: #local inside #macro? This subject should be IMO
described little more within documentation.
ABX
Date: 26 Oct 2001 07:59:48
Message: <0qjittsg3bmv8422pj5egqvo8p4sg9p36h@4ax.com>
Is this the same thing ?
#local A=array#local C=1;#while(C<=5)[C]#local C=C+1;#end
personally I prefer post such things to warn people it not work
ABX
Date: 26 Oct 2001 09:07:08
Message: <3bd95ffc@news.povray.org>
In article <dueitto7imgspv5ojmn81htn9pvbof35v0@4ax.com> , W„odzimierz ABX
You misunderstood what I mean with nesting.  Think about it and it should be
obvious what is meant with nesting based on your examples.
    Thorsten
Date: 26 Oct 2001 09:09:16
Message: <3bd9607c@news.povray.org>
In article <0qjittsg3bmv8422pj5egqvo8p4sg9p36h@4ax.com> , W„odzimierz ABX
I would not recommend the above as it isn't disallowed.  Use a macro and
call it, that will always work as you expect.
    Thorsten
Date: 26 Oct 2001 09:19:01
Message: <icoittcv9sfj456mtla771o8csgf1gp6eg@4ax.com>
On Fri, 26 Oct 2001 15:07:05 +0200, "Thorsten Froehlich"
Perhaps.
I just want to say it's good idea to add not working statements to
documentation and write something about this problem.
ABX
Date: 26 Oct 2001 09:21:36
Message: <lloittsoa1lusa6n1of9epl8or51rt8s6e@4ax.com>
On Fri, 26 Oct 2001 15:09:14 +0200, "Thorsten Froehlich"
like this ?
#macro B() array#local C=1;#while(C<=5)[C]#local C=C+1;#end #end
#local A=B()
it still not work with beta 6
ABX
Date: 26 Oct 2001 09:28:48
Message: <l5pittsu5l5peakv2dda70nu1n88s6m04h@4ax.com>
On Fri, 26 Oct 2001 15:21:31 +0200, W�odzimierz ABX Skiba
> #local A=B()
but this works fine
#local A=array[#local C=1;#while(C<=4)C][#local C=C+1;#end 5]
ABX
Date: 26 Oct 2001 09:37:07
Message: <1npittopq343jbkgtlm1vthlg7uhffe6b8@4ax.com>
> #local A=B()
it is probably connected with next thread
ABX
Date: 26 Oct 2001 09:48:02
Message: <3bd96992@news.povray.org>
In article <lloittsoa1lusa6n1of9epl8or51rt8s6e@4ax.com> , W„odzimierz ABX
> #local A=B()
Move the "array" out of the macro perhaps?  Or have the whole declare in the
macro?
Date: 26 Oct 2001 09:55:03
Message: <3bd96b37@news.povray.org>
There's a difference between something like
and something like
  #switch (Something)
    #switch (SomethingElse)
In the first case, the second #declare is actually *inside* the first
#declare. In the second case, the second switch is *between* the first
#switch and the first #end. (I know that's also commonly called "inside" but
it's a different kind of "inside".)
Date: 26 Oct 2001 10:02:20
Message: <joqitt063eivvf17ilrcc5ebbhmecq37fg@4ax.com>
On Fri, 26 Oct 2001 15:48:02 +0200, "Thorsten Froehlich"
> > #local A=B()
No. It not work and cursor is wrongly positioned inside line when
showing error.
> macro?
The same error: Expected 'object or directive'.
And the same thing appear when I call elements of declared array. This
not work:
#local A=array[1][1][1][1][1]{{{{{0}}}}}
#local B=A #local C=1;#while(C<=5)[0]#local C=C+1;#end
Do you agree it should works ? I ask becouse it could shorten a lot my
macros for arrays.inc requested by Rune.
ABX
Date: 26 Oct 2001 10:23:08
Message: <20sittk6rd8k5cf906ef8aoj1n5ba87dpq@4ax.com>
On Fri, 26 Oct 2001 09:57:07 -0400, "Anders K." <and### [at] f2scom>
> There's a difference between something like ...
yes, but I thought about different inside than you :-)
look at below syntax and try answer how many "1" should be printed out
#macro Go(Level)
  #debug "1\n"
  #switch (Level>0?Go(Level-1):0)
    #case(0) 1  #break
#local A=Go(1);
it produces 98 lines of "1" and error "to many nested symbol tables".
why ?
perhaps it is not the same bug but ...
ABX
Date: 26 Oct 2001 10:25:52
Message: <3bd97270@news.povray.org>
In article <joqitt063eivvf17ilrcc5ebbhmecq37fg@4ax.com> , W„odzimierz ABX
Well, it doesn't really matter is it should work - as pointed out earlier, I
don't think it is going to change in 3.5.  Only if it worked in 3.1 I would
say it should work in 3.5.
    Thorsten
Date: 26 Oct 2001 10:36:56
Message: <3bd97508@news.povray.org>
> #macro Go(Level)
>   #debug "1\n"
>     #case(0) 1  #break
>   #end
> #end
The problem here is that Go(Level - 1) is *always* evaluated, whether Level
> 0 or not, because POV-Ray doesn't use short-circuit evaluation.
Date: 26 Oct 2001 10:39:55
Message: <ubtitt4t1t8lvk9tfjl9h0h7or4rf37irj@4ax.com>
On Fri, 26 Oct 2001 16:25:48 +0200, "Thorsten Froehlich"
Could anybody check this ? I have 3.1 uninstalled.
ABX
Date: 26 Oct 2001 10:49:16
Message: <eptittcu7fakkaid4fu211m94ar2srrfv4@4ax.com>
On Fri, 26 Oct 2001 10:38:59 -0400, "Anders K." <and### [at] f2scom>
wrote:
> > #macro Go(Level)
> >   #debug "1\n"
> >     #case(0) 1  #break
> >   #end
> > #end
yes, right, I missed this.
but how it should looks with #if ?
it seems not work too.
ABX
Date: 26 Oct 2001 11:27:40
Message: <3bd980ec@news.povray.org>
> > > #macro Go(Level)
> > >   #debug "1\n"
> > >     #case(0) 1  #break
> > >   #end
> > > #end
Level
Well, there's also another problem: if the result of the #switch statement
isn't 0, the macro doesn't return anything, which causes errors. I'm not
sure what you meant to write, but this is definately not a bug in POV-Ray.
Anders
Date: 26 Oct 2001 22:38:52
Message: <3BDA1E12.1AAF58DB@hotmail.com>
"W³odzimierz ABX Skiba" wrote:
> On Fri, 26 Oct 2001 15:21:31 +0200, W³odzimierz ABX Skiba
> > #local A=B()
> but this works fine
Are you REALLY sure that it is necessary
to EVER write such ugly lines of code ???
Tor Olav
Date: 29 Oct 2001 02:48:43
Message: <6a2qttofvlo4mp4rje55lm8cn3p51nu610@4ax.com>
On Sat, 27 Oct 2001 04:38:10 +0200, Tor Olav Kristensen
<tor### [at] hotmailcom> wrote:
> "W?odzimierz ABX Skiba" wrote:
> > On Fri, 26 Oct 2001 15:21:31 +0200, W?odzimierz ABX Skiba
> > > #local A=B()
> > but this works fine
working line is ugly but not working line is pretty usefull
I found it not by playing but working on useful macro
ABX
Date: 29 Oct 2001 03:53:28
Message: <h56qttsfg1edb3mp9j4db73ve0ikkvqrfk@4ax.com>
On Fri, 26 Oct 2001 11:29:44 -0400, "Anders K." <and### [at] f2scom>
yes, this "fight" made me mad and I've made mistake, sorry
ABX
