POV-Ray : Newsgroups : povray.beta-test : v3.8b2. height_field input values at 0.0 not clean. : Re: v3.8b2. height_field input values at 0.0 not clean. Server Time
7 Apr 2026 08:56:00 EDT (-0400)
Date: 18 Feb 2023 20:40:00
Message: <web.63f17d0f1428d28b1f9dae3025979125@news.povray.org>
William F Pokorny <ano### [at] anonymousorg> wrote:
> In looking at your results I'm not at all sure why the max extent values
> for x and z are all zero? The HF max extent should be 1 or larger for x
> and z (always I think if not scaled) ?
This got me curious as well.
So I just threw some quick lines of code together.
The hf looks fine to me.   Typo in Ken's code?
#declare delta_hf = 1/pow (2, 16);
#debug concat ("1/pow (2, 16) = ", str (delta_hf, 0, 8), "\n")
#declare HF = height_field {
     function 800, 800 { 1 }
#declare Min = min_extent (HF);
#declare Max = max_extent (HF);
-0.0 shows up as : -0.000000
+0.0 shows up as : 0.000000
Var negZero shows up as : -0.000000
Var posZero shows up as : 0.000000
Var hmmZero shows up as : -0.000000
select () interprets -0 as zero
sgn () interprets -0 as zero
Ternary interprets -0 as zero
#if interprets -0 as zero
1/pow (2, 16) = 0.00001526
Heightfield min_extent = = 0.00000000, 0.99998474, 0.00000000
Heightfield max_extent = = 1.00000000, 0.99998480, 1.00000000
Changing the function result to 0 yields:
Heightfield min_extent = = 0.00000000, -0.00000002, 0.00000000
Heightfield max_extent = = 1.00000000, 0.00000002, 1.00000000
