POV-Ray : Newsgroups : povray.beta-test : v3.8b2. height_field input values at 0.0 not clean. : Re: v3.8b2. height_field input values at 0.0 not clean. Server Time
24 Mar 2026 00:49:58 EDT (-0400)
Date: 18 Feb 2023 19:45:00
Message: <web.63f170d91428d28bd7e7326789db30a9@news.povray.org>
William F Pokorny <ano### [at] anonymousorg> wrote:
> On 2/17/23 20:49, Tor Olav Kristensen wrote:
> >> Aside: You can use the 3 term select depending upon a boolean result in
> >> the first term test by doing something like:
> >> select(1-(2*((x<0.0) | (x>1.0))), 0, 1)
> > How about just this:
> > select(
> >      -((x < 0.0) | (1.0 < x)),
> >      0,
> >      1
> > - or this:
> > select(
> >      -((0.0 <= x) & (x <= 1.0)),
> >      1,
> >      0
> Very likely OK in practice, and cleaner in form than my three term select.
> What spooks me some is that -0 and +0 are real things in the IEEE
> floating point standard and as supported by C++. If a C++ coder has
> thought to test for -0 < 0, they can.
When you mention it, I think that I've actually have run into a problem with
negative zero in a version of POV-Ray.
IIRC I got different result when I used select() from what I got when I used <
or > in an #if statement.
So yes, it is scary.
Tor Olav
http://subcube.com
https://github.com/t-o-k
