POV-Ray : Newsgroups : povray.beta-test : POV-Ray v3.8.0-alpha.10011104 : Re: POV-Ray v3.8.0-alpha.10011104 Server Time
3 Apr 2026 01:08:38 EDT (-0400)
Date: 13 Jan 2019 15:10:00
Message: <web.5c3b9a5b2cb80e7848892b50@news.povray.org>
hi,
> Am 13.01.2019 um 18:23 schrieb jr:
> > ok.  do you have a 'wget'able url for that file, please?
> I have no idea what a "'wget'able" URL is, but maybe this one qualifies:
"man 1 wget", or "curl".  command-line tools to fetch stuff.
https://raw.githubusercontent.com/POV-Ray/povray/master/source/parser/parser_functions_utilities.cpp
will do nicely.  thanks.
> > btw, the alpha (also) crashes when there's an "old-style" text primitive, ie
> > without cmap {}, irrespective of charset present in global_settings.  does the
> > above workaround fix that too?
> I thought you were confirming that v3.8.0-alpha.10011104 fixed your
> issue? Please clarify, and double-check the version you're running.
> Those `text` primitive crashes you were observing are totally unrelated
> to the user-defined function crashes.
yes, I appreciate that.
I used a reduced version of the 'pav-patt.pov' for the test, with the latest (ie
10011104) alpha.  it crashes when T2 "visible":
#version 3.8;
global_settings {assumed_gamma 1}
#declare S = "abcdef";
#declare T1 = text {
  ttf "arialbd.ttf" cmap { 1,0 charset 0 }
  S
  0.001 0
  pigment { color rgb<1.0, 0.6, 0.2>*1.25 }
  no_shadow
#if (0)
#declare T2 = text {
  ttf "arialbd.ttf"
  S
  0.001 0
  pigment { color rgb 0.1 }
  no_shadow
regards, jr.
