POV-Ray : Newsgroups : povray.beta-test : Difference in wrapped vs raw wood in normal{} : Re: Difference in wrapped vs raw wood in normal{} Server Time
28 Mar 2026 11:21:44 EDT (-0400)
Date: 27 Nov 2024 14:28:41
Message: <674772e9$1@news.povray.org>
On 11/27/24 08:00, William F Pokorny wrote:
> Real life keeping me busy over the next few days, but I plan to dig into
> this when I get some time. My guess at the moment is it is some
> numerical difference near values of 0 and/or 1, but we'll see.
What is going on popped into my head 10 minutes ago. The following does
produce the same result as normal{ wood rotatex*90 } :
     #declare Fn = function {
         pattern {  // This {} enables value modifiers
             wood
           //rotate x*90
     normal {
         Fn(x,y,z)
         rotate x*90  // Moved the rotation here
Where I had coded this:
             wood
             rotate x*90
     normal {
         Fn(x,y,z)
In the top the rotate happens in normal{} context. With the bottom
encoding it happens in the pre-compiled function{ pattern{} } context.
The normal{} value sampling - in being only a pyramid  of 4 samples - is
asymmetric. It sees the wood pattern's value not-rotated in one case and
rotated in the other and we get different perturbed normal results.
Bill P.
