POV-Ray : Newsgroups : povray.beta-test : Difference in wrapped vs raw wood in normal{} : Difference in wrapped vs raw wood in normal{} Server Time
22 Jun 2026 23:36:41 EDT (-0400)
Date: 27 Nov 2024 08:00:55
Message: <67471807@news.povray.org>
In writing this post to the v4.0 forum:
http://news.povray.org/povray.pov4.discussion.general/thread/%3C67471126%241%40news.povray.org%3E/
I discovered weird differences in results between using the wood pattern
directly within a normal and wrapping it in pigment_pattern{} or
function{pattern{}}.
In other words, the following:
normal {
   wood
   rotate*90
Results in behavior different than either:
#declare Fn = function {
   pattern {
     wood
     rotate x*90
normal { Fn(x,y,z) }
     or
normal {
   pigment_pattern {
     wood
     color_map {
       [0 rgb 0]
       [1 rgb 1]
     rotate x*90
In the attached image the left column is using one of the wood {}
wrapped forms. The middle column uses 'wood' directly in the normal{}.
The right column showing a 4x multiple of differences which should not
exist. No AA used. The image results are from v3.8 beta 2, but this
issue exists in the yuqk fork too.
The top row is just the wood base normal. The bottom row showing the
wood based normal used in a slope map{}.
Real life keeping me busy over the next few days, but I plan to dig into
this when I get some time. My guess at the moment is it is some
numerical difference near values of 0 and/or 1, but we'll see.
Bill P.
Download 'wrappedvsrawwoodinnormal.jpg' (145 KB)
Preview of image 'wrappedvsrawwoodinnormal.jpg'
