POV-Ray : Newsgroups : povray.beta-test : Re-discovering issues with finding ini files in library path : Re: Re-discovering issues with finding ini files in library path Server Time
23 Mar 2026 06:44:44 EDT (-0400)
Date: 15 Apr 2024 22:49:13
Message: <661de729$1@news.povray.org>
On 3/20/24 01:49, William F Pokorny wrote:
> With that change I'm able to run the following (reminder yuqk is
> linux/unix only):
>      yuqk playpen.pov include_ini="quickres.ini[1024x768, AA 0.3]"
> or
>      yuqkZ playpen.pov +ini"quickres.ini[1024x768, AA 0.3]"
> Of course, with that set up you can then only reach local directory ini
> files afterward because those are all that will be found.
First, as an addition to the previous post, I should have added as a
footnote that using include_ini= (*) or +ini with a full path or
complete relative path specification for ini files works.
Today. These options are in fact the only way other than copying all the
ini files you need into the local rendering directory to be sure(**) you
find ini files (other than install or user-local povray.ini) correctly.
(*) - The include_ini= option exists today in official releases, but
isn't documented.
(**) - This isn't the same as saying the current ini mechanism doesn't
often work. Of course, this is an ugly position to be in as it means the
ini behavior, where other than having all same directory ini file(s), is
unreliable.
The above said, the aim of this post is to document that I've found
issues with ini parsing error reporting when ini files are directly
included! :-(
(Yes, now guessing that, not documenting 'include_ini=' might have been
some sort of a 'delay for fixes' which never happened.)
Basically, ini files included via this mechanism can have serious
parsing issues which end up completely ignored in official releases of
POV-Ray (Linux / Unix versions at least). They are 'somewhat ignored'
with current releases of the yuqk fork.
The yuqk fork reports the parsing problems with additional text messages
where official releases usually don't. However, today in released yuqk
versions up to R13, the parsing still doesn't stop on finding serious
issues. The bad error return code gets eaten / overwritten due how the
include_ini= option was originally implemented.
Because it's part of the 'ini' tofix pile and related, I'll toss out
again that the ini directory ordering, as affected by library paths, is
glitch-y. We should not be using the library search paths for ini files
at all, but rather only for include files.
It believe it should always have been another path set up mechanism for
ini files (perhaps an INIPATH env var similar to PATH?). Or, no path
searching at all and just include_ini= or +ini usage. This latter
approach is how I plan to go with yuqk - though I've not yet worked out
the code changes to disable to sometimes searching of the library path
for ini files, so we'll see.
Bill P.
