POV-Ray : Newsgroups : povray.beta-test : Stream <type>_file=false ini options not working. : Re: Stream <type>_file=false ini options not working. Server Time
22 Mar 2026 03:29:11 EDT (-0400)
Date: 2 Mar 2024 09:39:50
Message: <65e33a36$1@news.povray.org>
On 3/1/24 13:32, Thorsten wrote:
> I think this is more a documentation error remaining than a missing
> feature. All this would do is turn OFF output to a file, which already
> will only be written if it is specified in the first place ... what does
> work is setting this to an empty string.
> However, if you wanted to implement "false" it, it should be in
> frontend/renderfrontend.cpp method RenderFrontendBase::CreateScene
> Find the line
if(ProcessOptions::IsTrue(UCS2toSysString(shd.streamnames[gStreamNumber[i]]).c_str())
== true)
> and add a case for IsFalse that sets the
> shd.streamnames[gStreamNumber[i]] to an empty string.
Thank you, Thorsten, for digging.
Unfortunately, your suggestion to try the empty string highlights a
secondary bug. All of the variations below direct the stream to a
defaulted filename of debug.out in my testing (ini forms too).
yuqk debug.pov debug_file=on
yuqk debug.pov debug_file=true
yuqk debug.pov debug_file=yes
yuqk debug.pov debug_file=1
yuqk debug.pov debug_file=""
yuqk debug.pov debug_file=''
The secondary problem is ProcessOptions::IsTrue (and
uProcessOptions::IsFalse) use ProcessOptions::Matches which needs the
following code at the very top
    if ( ((v2[0] == 0) || (v1[0] == 0)) &&
        !((v2[0] == 0) && (v1[0] == 0)))
        return false;
to not, falsely, test 'true' on empty string options. With that
secondary fix in place, the following code is testing out OK for me.
(Ugly code formatting to avoid uglier formatting on posting of code...)
Replace:
     shd.streamnames[gStreamNumber[i]] =
         obj.GetUCS2String(gStreamTypeUtilData[i]);
     if (ProcessOptions::IsTrue(
         ) == true)
         SysToUCS2String(gStreamDefaultFile[i]);
With:
         UCS2toSysString(
         ).c_str()) == true)
     else if (ProcessOptions::IsFalse(
         UCS2toSysString(
         ).c_str()) == true)
         // Do nothing if the string indicates false (or empty).
     else
Bill P.
