POV-Ray : Newsgroups : povray.beta-test : Stream <type>_file=false ini options not working. : Re: Stream <type>_file=false ini options not working. Server Time
5 Apr 2026 10:23:41 EDT (-0400)
Date: 1 Mar 2024 13:32:24
Message: <65e21f38$1@news.povray.org>
On 01.03.2024 15:58, William F Pokorny wrote:
> It looks like these options have not functioned correctly since at least
> v3.7.
> I have not yet fixed them the yuqk fork - the fix priority is low.
> The options in particular are:
> all_file=false
> debug_file=false
> fatal_file=false
> render_file=false
> statistic_file=false
I think this is more a documentation error remaining than a missing
feature. All this would do is turn OFF output to a file, which already
will only be written if it is specified in the first place ... what does
work is setting this to an empty string.
However, if you wanted to implement "false" it, it should be in
frontend/renderfrontend.cpp method RenderFrontendBase::CreateScene
Find the line
if(ProcessOptions::IsTrue(UCS2toSysString(shd.streamnames[gStreamNumber[i]]).c_str())
== true)
and add a case for IsFalse that sets the
shd.streamnames[gStreamNumber[i]] to an empty string.
Thorsten
