POV-Ray : Newsgroups : povray.beta-test : `datetime(now)` issue - suggestions for a solution : Re: `datetime(now)` issue - suggestions for a solution Server Time
23 Mar 2026 10:03:31 EDT (-0400)
Date: 12 Aug 2021 08:25:54
Message: <61151352$1@news.povray.org>
On 8/12/21 7:59 AM, clipka wrote:
> Am 11.08.2021 um 14:57 schrieb William F Pokorny:
>> Of note for POV-Ray v3.8 and onward is that the Fn_TimePt00,
>> Fn_TimePt00 method for capturing time points should work in v3.8 beta
>> 1, but it doesn't because when 'now' was added, the support for it was
>> not added to parser_strings.cpp alongside pi, tau, etc. This a stand
>> alone 'now' issue.
> I think you mean `parser_functions.cpp`?
I did, sorry.
As for what you say below... We're not going to agree. Plus, I need to
run to other stuff for the day.
The token 'now' is what it is when the parse sees it. It's no different
than 'pi' in that regard. Why create inconsistent behavior for users?
> There's a point to be made in keeping it that way: If we allow `now` in
> a function, what value should it evaluate to? The point of time when the
> function is parsed and compiled, or the one when it is invoked?
> Since the answer to both alternatives is probably "yes" (depending on
> the use case), allowing it at all in functions _will_ cause confusion.
> For e.g. `pi` and `tau`, by contrast, the answer is easy: "Who cares,
> it's the same either way."
> Also, if you design a function to return current date and time encoded
> in a different time format (say, POSIX timestamp), it's easy to just add
> another parameter, and pass `now` when invoking that function. (*)
> And while a function that evaluates to a different value upon each
> invocation during render _may_ sound like a fun idea, I'm quite sure its
> applicability is pretty much limited to being a novelty.
> (*Speaking of extra parameters: Passing the number of seconds in a day
> as a _parameter_...??!)
