POV-Ray : Newsgroups : povray.beta-test : `datetime(now)` issue - suggestions for a solution : Re: `datetime(now)` issue - suggestions for a solution Server Time
30 Mar 2026 00:21:37 EDT (-0400)
Date: 12 Aug 2021 08:16:27
Message: <6115111b$1@news.povray.org>
On 8/11/21 2:07 PM, clipka wrote:
> If people want precise performance metrics, anything based on a real
> time clock - even `std::chrono::steady_clock` - is a poor choice of tool
> anyway. In general, I would guess that the task/thread scheduling jitter
> introduces far more noise into the measurements than the occasional
> system clock adjustment. CPU time would be a far better candidate for
> such things.
> Also note that for the purpose of performance metrics, we already
> provide measurements of the total parsing time, both real time and CPU
> time.
> If you think we should provide more tools for performance measurements,
> I would argue that some `#split_time` directive to print out the current
> parser stats would make more sense than some basic building block that
> users would have to build additional SDL code around, that in turn would
> potentially skew the results, to actually put to use.
> But I don't see any dire need for such a feature.
First, thanks for the detailed response.
I remain of the opinion POV-Ray would be better positioned with two
'now's with a 'now_for_datetime' and a 'now_for_timing'.
A now_for_datetime can be sloppy to the order most concerns we've
pointed out are OK. It could always use the local machine's epoch and
local setting - aligning with other local tools in the machine/OS
environment. Something easier for users to use date time wise.
As to timing things inside the parser. My initial reaction was similar
to yours. The idea rattled around a while inside the cavity behind my
eyes, and, I started to think that certain sorts of timing
characterizations are likely simpler/better-done within the parser.
The parser, in being single threaded, is at some advantage timing wise
for using only a one thread.
Something which gets asked every now and again, is whether POV-Ray could
provide some idea as to the relative expense of certain features over
others.
Instead of timing some block of user SDL code, imagine instead a parser
only job which first characterizes the cost of an empty loop and - to
the degree it can - other "wrapper" costs. We then start inserting
things to characterize in that loop/wrapper. Single patterns in turn as
called via functions. Functions themselves one at a time. Or trace()
operations against base shapes/surfaces one at a time. Or particular
parser functions one a time. Or whatever else. In many respects the
parser can more easy isolate particular functionality than can be
accomplished via other methods.
Imagine a large, long running, parser characterization job for all the
'things' for which we want to track relative performance. The
information from which we, perhaps, stick in a big table via jr's new
macro and publish. Regular timing results useful to users and developers.
This the sort of parser timing application which I believe requires a
more stable and dedicated 'now_for_timing'. But, yep, it's just another
idea at this point - except for now having povr's timer specific
f_clock() feature in hand.
Bill P.
