POV-Ray : Newsgroups : povray.beta-test : 3.8 and text {} : Re: Hello darkness (was Re: 3.8 and text {}) Server Time
30 Mar 2026 12:23:30 EDT (-0400)
Date: 14 Nov 2019 23:58:33
Message: <5dce3079$1@news.povray.org>
On 11/14/19 7:26 AM, William F Pokorny wrote:
> Have you tried changing the default ambient back to 0.1 when changing
> your version to 3.8?
The global ambient_light is silently ignored if the #version is 3.8
I used the Basic Scene 01 - Checkered Plane template
and added a Wire_Box.  Then at the top changed these 3 lines:
#version 3.8;
global_settings{ assumed_gamma 1.7 ambient_light 5.0}
//#default{ finish{ ambient 0.1 diffuse 0.9 }}
If the version is 3.7, then that ambient_light 5.0 washes everything
right out.  If the version is 3.8, it matters not what I set that number to.
So I tried
global_settings{ assumed_gamma 1.7 }
#default{ finish{ ambient 0.1 }}
This does look a lot like the effect I want, after a couple of tests on
my movie.  However, I am greeted with a plethora of:
Parse Warning: Scene language version changed after a 'default'
statement. The changes in defaults normally associated with the language
version change are not applied.
because the standard includes push the version, change to 3.5, pop the
version.
sigh.
dik
Rendered 23,792,486,400 of 40,928,716,800 pixels (58%)
