POV-Ray : Newsgroups : povray.beta-test : POV-Ray v3.8.0 experimental versions : Re: POV-Ray v3.8.0 experimental versions Server Time
25 Mar 2026 23:04:15 EDT (-0400)
Date: 19 Feb 2019 15:03:21
Message: <5c6c6109$1@news.povray.org>
Am 19.02.2019 um 19:05 schrieb Le_Forgeron:
> For the freetype, I now get:
> for gnu compiler, disp_sdl.cpp is failing with min(), suggesting
> std::min() (same for max / std::max)
Did you pull the tagged version?
If you instead pulled the `experimental/freetype` head, that would
explain why you're seeing the issue: I forgot to push that branch, so
it's lagging behind. The tagged branch is `autobuild/freetype`.
