POV-Ray : Newsgroups : povray.beta-test : Fwd: Stack Size Testers Wanted : Re: Fwd: Stack Size Testers Wanted Server Time
22 Mar 2026 16:12:57 EDT (-0400)
Date: 17 Feb 2019 21:05:09
Message: <5c6a12d5$1@news.povray.org>
On 2/17/19 6:41 PM, William F Pokorny wrote:
> OK. Surprised the heap allocation is slower than one on the stack. I
> figured the allocation and free mechanisms were more or less the same -
> just being a difference of where in memory it happened. Guess not?
The compiler figures out how much stack space a function call needs, and
allocating that memory is simply a matter of moving the stack pointer
*once*, a single register operation, upon entry to a function.
Heap requires a separate function call for each object to be allocated.
That function examines its tables trying to find a "best fit" for the
size requested, mark those tables as allocated, and return a pointer.
For the reverse, free'ing tries to merge freed memory [1].  Much, much
more expensive than stack.
[1] Old MS-DOS systems you could kill it by allocating all of memory as
1KB blocks, free all those blocks, then try to allocate a 2KB block. Out
of memory.
> Also surprised allocations on the stack have to be of fixed size. Is it
> so on the function call just one allocation can happen on the stack for
> all the dynamic variables in the function?
See above.
dik
Rendered 1024 of 921600 pixels (0%)
