POV-Ray : Newsgroups : povray.beta-test : POV-Ray v3.8.0-alpha.9861167 : Re: POV-Ray v3.8.0-alpha.9861167 Server Time
12 Oct 2026 20:49:17 EDT (-0400)
Date: 6 Oct 2018 07:14:13
Message: <5bb89905$1@news.povray.org>
On 10/05/2018 03:04 PM, clipka wrote:
> Am 05.10.2018 um 20:33 schrieb Alain:
>> I expected some message about the max_gradient found to be around 9 but
>> set at 1.0.
>> The resulting image show obvious holes.
>> But, I don't get any message after the render is complete.
> Can't reproduce:
> - I only see an (almost perfect) clay-brown slab, even with the
> max_gradient 1 setting. No holes for me.
> - Previous versions (tested with v3.7) do not produce a max_gradient
> warning for this scene either. [*]
> - When I set max_gradient even lower (0.1), I do get holes, but I also
> do get a warning with alpha.9861167. [*]
> - The reported maximum gradient found is 0.990, not around 9.
> [* Fun side note: At a max_gradient setting of 0.1, it is POV-Ray v3.7
> that fails to issue a warning.]
I do see a few apparent holes (no AA) in the upper let corner for
example, but otherwise agree with Christoph.
I think the bounding is off with z low being zero:
  contained_by {box {<-1,-1,0>, <1,1,1>}}
In other words, I think the function is mostly being clipped so we are
seeing a slice of the function's "inside" and which on that slice is
noisy at the edges. Change that zlow bounding 0 to -1, for example, and
you'll get gradient warnings for the max gradient of 1.
Aside 1: Another way to clean up the edges in the clipped (zlow=0) case
is to crank the accuracy way up so the clipped inside resolves more
cleanly at the edges. Say maybe 0.00005 or less.
Aside 2: IIRC there is still a thread collision in the current
implementation (which Thomas, in 3.8 no longer needs to be "naked"
thanks to Christoph's updates) - meaning you are not guaranteed to see
the very worst found gradient. In practice it's close. Practical
implication is you need to bump any reported max a little for the
setting not so much for result, but to be sure some later render doesn't
report a slightly larger gradient just due the internal ordering of
stuff.
Bill P.
