POV-Ray : Newsgroups : povray.beta-test : Code gets the processor too hot? : Re: Code gets the processor too hot? Server Time
1 Nov 2026 03:53:12 EST (-0500)
Date: 2 Apr 2013 13:13:50
Message: <515b11ce$1@news.povray.org>
Warp wrote:
> Ger <ger### [at] gmailcom> wrote:
>> When I otoh the Erode1 macro use, the parse times
>> are obviously much shorter but the processor get way too hot when tracing
>> the image.
> Yes, there's a super-secret function in povray that instructs the CPU to
> raise its temperature.
I knew it :)
> Seriously though, CPU temperatures are really not a problem of
> applications (especially not compute-intensive ones.) If your CPU gets too
> hot, it's a problem with your hardware. There may be several causes for
> that, such as:
> - The CPU is not getting enough ventilation. This may be caused by poor
>   chasis design, or not having enough fans (or them having been installed
>   in the wrong places.)
> - The CPU might not be getting enough ventilation because of too much dust
>   on its heatsink. You should check that.
> - Wrong BIOS settings can cause the CPU fan to either spin too slowly
>   (causing overheat) or too fast (causing fan noise that's way louder
>   than it has to be.)
All true and all known to me (I have build and sold computers for ~15
years). But this still leaves the question why a small change in code can
raise the temperature of the cpu
Ger
