POV-Ray : Newsgroups : povray.beta-test : Colored specular highlights feature request : Re: Colored specular highlights feature request Server Time
30 Oct 2026 07:05:22 EDT (-0400)
Date: 28 Feb 2013 23:24:16
Message: <51302d70$1@news.povray.org>
Am 28.02.2013 23:57, schrieb Simon Copar:
> I posted this request as FS#263 on the bugtracker. It is a nice possibility for
> an extension in next version (3.7.1 or something). The old syntax
> specular <number>
> could be retained for compatibility, and a new syntax with curly braces could
> provide a full-featured specification, similar to pigment:
> specular {
>    specular | phong | other future algorithm names //type
>    <scalar> | <color> | <pattern> | <function>
>    roughness <number>
>    [metallic]
>    [copy_transparency]
>    [optional transforms, warps, turbulence]
> This would also migrate all highlight-related keywords in the same block, which
> is more consistent with other blocks (such as reflection).
> Does any of the official developers think this is an acceptable idea? It would
> not be difficult to implement, just use Pigment_Function class that already
> exists (yes, I looked at the code). I could take my time and write a patch for
> this.
As one of the official developers, the highlights syntax has actually
bothered me for quite a while now, with my main point of concern being
the parameterization of the existing feature:
- With the highlight brightness settings specifying the maximum
brightness of the highlight, rather than how much of the incoming light
would be reflected, it used to be difficult to find realistic highlight
brightness settings to go along with a particular reflection brightness.
(This has been addressed by now with the "albedo" keyword.)
- The specular and phong models use totally different parameterizations
for how blurry the highlight looks, making it non-trivial to switch
between the two highlight models. It also means that if blurred
reflections are implemented some day, whatever parameterization is used
for that one will make it non-trivial to pick matching settings for at
least one of the highlight models. So ideally we should have
"phong_roughness" instead of "phong_size" (or a "specular_size" instead
of "roughness", but personally I prefer the roughness-style
parameterization). Or change the syntax "somehow" to use the same
keyword for both highlight models; one such approach would indeed be to
have just one "highlights" block (I wouldn't use the "specular" keyword
there) with one setting being the highlight model to use.
- What is completely missing so far is fresnel-based attenuation for
highlights, because in reality highlights vary with angle of incicence
just like reflection does. Again having a dedicated "highlights" block
would make it easy to come up with a consistent syntax (just use the
"fresnel" keyword in the "highlights" block like you would in the
"reflection" block).
Some other thoughts on your suggestion:
- Pattern-based control over highlights is indeed quite a frequent
feature request; to some degree similar effects can be achieved by using
a texture map, but this is only half the truth: Where extreme but
gradual changes in highlight roughness are desired, texture maps won't
get you anywhere. However, I think this is better catered for by a
"finish map"; after all, when you vary highlights chances are that you
will also want to vary diffuse and specular reflection along with it.
- There has been arguing that a single highligts block would be too
limiting, because specular and phong highlights couldn't be used
together on the same surface anymore. I disagree with that view,
because: (A) The reason given is that sometimes it might be desirable to
have both dull and sharp highlights on the same material; however, I
find it rather arbitrary to limit the number of highlights per texture
to 2, and also require that one be phong and the other blinn_phong; if
there is real need for multiple highlights per basic texture, this would
better be catered for by allowing an arbitrary number of highlights
blocks per finish. (B) It isn't difficult to achieve multiple highlights
per material by using layered textures.
- The internal data structures used for pigment, texture and normal maps
are subject to change in the near future, from the current C-style
structs to C++-style classes, so this might not be the moment to
implement a finish_map feature.
- One thing that should be considered when developing a new highlights
syntax is that some day we might see blurred reflections, in which case
a direct correlation between reflection and highlights settings would be
strongly desirable. So maybe the highlights settings should be part of
the reflection block in the first place, in which case we'll possibly
end up with no other highlights-specific parameter than just the model
to use (the "roughness" parameter would be shared with blurred reflections).
