POV-Ray : Newsgroups : povray.beta-test : memory problem with radiosity : Re: memory problem with radiosity Server Time
17 Oct 2026 15:21:39 EDT (-0400)
Date: 15 Feb 2010 10:08:24
Message: <4b796368$1@news.povray.org>
Le 2010-02-14 21:01, Patrick Elliott a écrit :
> On 2/14/2010 1:58 PM, Ken Willmott wrote:
>> Darren New<dne### [at] sanrrcom> wrote:
>>> Thorsten Froehlich wrote:
>>>> Given that turning virtual memory off is impossible in Windows that
>>>> seems like an odd suggestion...
>>> Turning virtual memory off in Windows is trivial. I don't think you
>>> can turn
>>> off virtual addressing, but that shouldn't have an impact on this
>>> problem.
>>> Control panel->System->Advanced->Performance->Advanced->No page file
>>> Admittedly, it's behind two "advanced" tabs, but the help tells you
>>> how to
>>> get there too if you put "virtual memory" into the search bar of the
>>> control
>>> panel.
>>> Darren New, San Diego CA, USA (PST)
>>> Forget "focus follows mouse." When do
>>> I get "focus follows gaze"?
>> Interesting, I had no idea this was possible. Actually though, I
>> believe it is
>> probably better to leave it alone. It's probably there to allow better
>> real-time
>> performance for time critical apps.
> As a rule, usually is. Windows will try to page, even if it *has*
> sufficient system memory available, due to how it loads/unloads things
> it doesn't need immediately. And, you run into major issues "if" you
> don't have it and hit the memory limit.
> About the only thing its good for, if you have the system memory, is to
> wipe it with a reboot (after turning it off), run a *detailed*
> defragger, which consolidates files properly (most won't), then put it
> back, and restart. This causes the original to be removed, and a new one
> to be created, contiguously, at the end of the high end of the
> partition. I doubt 7 is any better than any other version has ever been
> at this, so **eventually** the page file gets so screwed up that
> everything runs like crap. Killing the file, consolidating everything,
> then restoring it is the most effective solution, but if you have enough
> free space, there are 1-2 things that *specifically* defrag the page
> file, during startup, and before its in use.
> Otherwise, you could turn it off in Windows, but, as I said, Windows
> doesn't like you doing it **at all**.
Never let windows complete control over the page file, and don't leave
it on the same partition as windows.
One of the best way to manage it is to create a dedicated partition with
nothing else on it, then to hide that partition.
If you have more than one hard drives, create a drive leter less
partition as the first partition on each drives and make those contain
your page file. It should be the first thing done on any new system.
