POV-Ray : Newsgroups : povray.beta-test : PNG output much brighter than preview... : Re: PNG output much brighter than preview... Server Time
13 Nov 2026 00:25:43 EST (-0500)
Date: 15 Jan 2007 18:00:09
Message: <45ac0779$1@news.povray.org>
[Followup-To set to povray.general as this isn't really about the 3.7
beta anymore]
Take this as my vision of a future, prefect, gamma corrected world and
not so much of a solution for today's gamma problems ;)
Warp wrote:
>   Gamma correction in PNG causes lots of problems. For instance, if
> you want to make a web page with a certain backtround color and add
> a PNG image which uses that exact same color, you can blame gamma
> correction for the fact that often you won't. While you can do that
> with any other image format, and the image will match the background
> color in the web page perfect, with PNG it often won't. It depends on
> the browser. Some browsers read the gamma correction, others don't.
> If there's no gamma correction, some browsers will guess a gamma
> correction (screwing up the colors) while others will take the pixels
> unmodified.
This may be true, I have not experienced it myself, though. In theory I
don't think it should be a problem if browsers implemented gamma
correction correctly. What I mean by that is that they should correct
both images and colors specified in css (assuming they are specified in
sRBG I guess, which seem to be the de facto standard). In practice
browsers don't do this of course and and I doubt that css (or any other
w3 standard) defines any gamma correction, so they probably never will.
You still need embedded gamma information (or standardized gamma) if you
want an image to look the same regardless of the target system's gamma.
I believe that is an important thing for CG-art.
>   Other image formats simply don't have these problems. If you use
> a certain color in a gif or jpg or whatever, you will get that certain
> color, and it will perfectly match the same color used in the background
> of the web page. With png you might or might not get the color you want.
> In one browser it may look good, in another it may not.
With gif (or others) you get the pixel value you want, with png (with
embedded gamma) you get the perceived color you want. In web pages the
former is more important (because browsers don't gamma correct css
colors) and when showing the image to others the way it's supposed to
look the latter is more important. It all depends on what the image's
purpose is.
>   The PNG standardization organization screwed up. They gave unwise
> rules on what to do when a png file has no gamma information. Some
> programs follow this rule, others don't. What is worse, if there *is*
> gamma info, some programs will read it, others won't. Thus you might
> get even 4 different results depending on the gamma info and the
> program.
(I have not studied the PNG-standard closely so IIUC...)
Fact remains that if all programs followed the standard's rules
regarding gamma (unwise or not), any given png-image would look the same
regardless of the target system. As I see it the problem is that
programs don't follow the standard. In practice you can't (easily, if at
all) fix the programs so you have to find some workaround. I don't have
any solution but it is not a good idea to remove gamma support from
programs that have it (e.g. povray).
>   In my personal experience the least problematic course of action is
> to not to include any gamma info in the png file. While that will not
> guarantee anything (some programs may start "guessing" a gamma info
> for it even if you don't want it to), I think most programs will then
> just take the pixels as they are, in the same way is with any other
> image format.
As you can see from my posts I am sort of a fan of gamma correction, but
I'm more of a theoretical guy, not doing much raytracing and image
related work right now. I once started writing my own raytracer and that
was when I encountered gamma first. After reading many articles on the
web I understand how it works and why it is needed. I think it's a
necessary evil, in a perfect world we would only use gamma 1.0 with
floating point values. It's non-linear hardware and the limited dynamic
range of 8-bit values that force us to use gamma correction and the fact
that different manufacturers chose different factors that make it a
PITA, IMHO.
Daniel Nilsson
