POV-Ray : Newsgroups : povray.beta-test : Heightfield bug (most probably an inverted normals problem) : Re: A possible solution, though difficult Server Time
11 Nov 2026 15:55:42 EST (-0500)
Date: 23 Jan 2002 13:13:01
Message: <3c4efd2d@news.povray.org>
Christopher James Huff <chr### [at] maccom> wrote:
: Any idea what the visual effects of this will be?
  It will look correct (well, not 100% correct, but smooth triangle shading
is never 100% correct anyways).
: You will be seeing a surface with the normal pointing away
: from you
  That doesn't matter because it's only used for the illumination, nothing
else.
: I think that unless you toss an "fabs()" into the mix, you
: will end up with negative diffuse values.
  How so? From the point of view of the light source, nothing strange is
happening.
  It should work correctly in the way I proposed.
  And where do you propose to put the fabs()? I don't understand it.
: I still like my method: If the triangle normal is pointing towards you,
: but the interpolated normal is pointing away, ignore the intersection
: and the next one with the same object. The effect should be that you
: just don't see the corners that you shouldn't be seeing...it might even
: round out the outline a little.
  This will result in big holes in the mesh in some cases (note that the
normal vectors at the vertices of the triangles do *not* necessarily have to
be the average of the adjacent triangle normals; they can be anything).
