POV-Ray : Newsgroups : povray.beta-test : Field rendering status : Re: Field rendering status Server Time
28 Nov 2026 20:25:49 EST (-0500)
Date: 29 Oct 2001 15:48:10
Message: <3bddc08a@news.povray.org>
I figured this out. First import the file (or list of still frames) through
File -> Import. Then place the clip onto the timeline. Right click on the
clip and go to Video Options -> Field Options. Select "Interlace consecutive
frames."
Then choose the Rate Stretch Tool (next to the razor blade tool) and shrink
the clip to half it's length.
That should give you what you want.
- Slime
[ http://www.slimeland.com/ ]
[ http://www.slimeland.com/images/ ]
"Slime" <noo### [at] hotmailcom> wrote in message
news:3bddb178@news.povray.org...
> I have the PC version of Adobe Premiere, and although I haven't used it
> extensively enough to say that this is or is not possible, I would
> appreciate instructions on how POV's feild rendering could be imported
into
> it. As far as I can tell, from the way it uses feild rendering *itself*
with
> transitions and things, the two-feilds-in-one-frame method (the one POV
> *doesn't* do) is the necessary one.
> - Slime
> "Thorsten Froehlich" <tho### [at] trfde> wrote in message
> news:3bddaabc@news.povray.org...
> > In article <3bdda363@news.povray.org> , "Vampyrium"
> <cyb### [at] hotmailcom>
> > wrote:
> > >   So, this is an apple thing. If you check out Adobe Premiere (PC
> version)
> > > you will find otherwise.
> > No, it isn't.  As there should be no difference between the Premiere
> > versions on Macs and PCs.  Also the other remaining DVD authoring
software
> > company Sonic/Daikin (they recently merged) seems to supports such
import
> > with their products (I don't know anybody who has access to those).  So
I
> > really don't see a problem other than that POV-Ray doesn't adjust the
> clock
> > frequency to create twice as many images when field rendering is used -
> and
> > that is a really simple to "fix" problem.
> > If you have a problem importing the format in Adobe Premiere I can try
to
> > find someone who has the PC version and send you detailed instructions
for
> > PCs if you think the PC version is different...
> >     Thorsten
> > ____________________________________________________
> > Thorsten Froehlich, Duisburg, Germany
> > e-mail: tho### [at] trfde
> > Visit POV-Ray on the web: http://mac.povray.org
