POV-Ray : Newsgroups : povray.beta-test : texture transparency and radiosity : Re: texture transparency and radiosity Server Time
22 Nov 2026 19:04:33 EST (-0500)
Date: 6 Feb 2002 22:14:23
Message: <3C61EE21.D5E6D02E@twoalpha.net>
Christoph,
A transparent surface like glass for example works fine.  What I am talking
about is a .GIF texture with an assigned color to be transparent, such as:
#declare mypigment =
pigment
 image_map
   gif "lattice.gif"
  transmit 21, 0
 filter   21, 1}
 scale <1.000000, 1.000000, 1.000000>
where color 21 is the transparent color that I want radiosity to go through.
Light sources will go through the transparent color but radiosity will not.
I will make a scene tonight to post to the binary section a bit later.
Dean
Christoph Hormann wrote:
> Dean wrote:
> > I have an object that I am  using a .gif texture for.  the reason for
> > this is to use the transparency of selected palette colors.  Is there a
> > way to have radiosity travel through the transparent colors?  Currently
> > I have been trying to use low intensity area lights to try and fake the
> > effect and the result is always much too bright.  I had the same
> > difficulty in V3.1 so I would not call it a bug per se.
> I have never had any problems with radiosity and transparent surfaces, if
> you think there is something not working as it should, post a short
> sample.
> Christoph
> POV-Ray tutorials, IsoWood include,
> TransSkin and more: http://www.tu-bs.de/~y0013390/
> Last updated 06 Feb. 2002 _____./\/^>_*_<^\/\.______
