POV-Ray : Newsgroups : povray.beta-test : Heightfield bug (most probably an inverted normals problem) : Re: More info (Was: Heightfield bug (most probably an inverted normals problem)) Server Time
12 Nov 2026 08:50:49 EST (-0500)
Date: 24 Jan 2002 09:48:07
Message: <3C501EB7.263F96C0@atosorigin.com>
"Włodzimierz ABX Skiba" wrote:
> I can be completly offtopic but could be normal determined by order of vertices
> in triangle?
From memory:
In 3.1 code, the short answer is NO, at least for mesh,
because the mesh code is free to reorder the vertices of any single triangle.(*)
So even if you carefully generate all your triangles with a +side and -side,
once in the mesh structure it might be impossible to get back to the original
order. It's often simpler to use a smooth_triangle which allow to explicitely
specify a normal for each vertex (but take more memory, of course).
(*) and it does it, according to its own private criteria.
Non Sine Numine
http://grimbert.cjb.net/
