On 1 Apr 2002 08:30:59 -0500, Warp <war### [at] tag povray org> wrote:
> Officially confirmed bugs:
> * Macro bug (job000146)
still exist
> * Several blob bugs (job000189)
> blob problem
still exist
> Blob : Toward a solution
> http://news.povray.org/3B991C90.D715B7A3@free.fr
still exist
> Possible bug with blobs
> http://news.povray.org/3c407ad3$1@news.povray.org
still exist
> Additional (?) blob bug
> http://news.povray.org/Xns9115B92CF7D8ACQ@204.213.191.226
still exist
> Blob rendering error
> http://news.povray.org/Xns91203DC7F3CCQ@204.213.191.226
still exist
> Bug with blobs and media
> http://news.povray.org/3be5f0b2@news.povray.org
still exist
> Blob component textures transformed twize
> http://news.povray.org/3bf70645@news.povray.org
still exist
> blob casting incorrect shadows on itself
> http://news.povray.org/Xns919C1CAA3E23Egerovandordatanethu@204.213.191.226
still exist
> * Superellipsoid bug (job000190)
still exist
> * Slowdown using +a +am1 +ua (job000191)
> (Using +ua and antialiasing with method 1 causes abnormal slowdown.)
can't recreate
any reference to original script ?
>* Color dot operators as macro parameters bug (job000201)
still exist
> * Radiosity doesn't take double_illuminate into account (job000207)
still exist
> * Mapping warps+transformation bug (job000212)
still exist
> * Photon bug (job000213)
still exist
> * POV-Ray crashes with some very long function definitions
still exist
>* Crash with "Reallocing Finite with extension"
still exist
>* max_trace_level affects radiosity recursion_limit
> (This is a design decision and the possibility of a change is being studied.)
still studied probably
> Bugs with no official confirmation:
>* Crash with empty scene
verified by Rune, fixed by Thorsten now probably
>* Media problem
> (A visible whitish line appears at the edge of a transparent container
> box for media. Needs confirmation.)
> Reported in:
> Media visible container line in front of object
> http://news.povray.org/3bf45a3d@news.povray.org
I can confirm appearance of bright line. I have changed camera location in
example to location <1+clock, 1.7, -5> and started animation.
I have rendered with +FN with standard settings 800x600, AA 0.3.
> * Prism transformation problem
> (Conic prism illumination is not correct after certain rotations. Bug
> status unclear.)
Note I have repeated this behaviour with matrix also (coded rotation)
http://news.povray.org/d1oh6u821648rvs7frgmt4cl7u41s6cmmo%404ax.com
> (Note: It has been reported that this bug would not happen in POV-Ray 3.1.
> This needs verification.)
What about recompilation of 3.1 with the same compiler and settings as current
betas to verify compiler issues ?
> Reported in:
> rare conic prism bug
> http://news.povray.org/3C51212E.9090707@irrwerk.de
still appear, hard to say what it is
>* Shadow rendering problem
At first I think originall report needs some changes. First instead multiplying
coordinates of camera probably scale sc should be applied at end. Second
light_source should be also scaled with sc to recreate the same exact world.
Anyway I think it is EPSILON problem.
> * Crash during radiosity pretrace
> (Needs confirmation.)
since example crashed after 7 hours on Athlon 1 GHz, 512 Mb RAM
I'm probably not the best person to check this with poor PII 233 MHz, 128 MB
>* Slope pattern problem
> This issue is being investigated.
So nothing to confirm probably (but still exist)
> * library_path to network drives problem
Can't confirm becouse no such enviroment possibilites at this moment
> * Image_maps using png images are gamma-corrected (when they shouldn't)
> (Confirmed by users.)
Can't confirm becouse lack in knowledge.
> Fixed bugs:
> * CPU time used printing problem
> (CPU time used in NT-derived OS's not reported in stream when render
> completes normally. Confirmed by users.)
> Reported in:
> [win] "cpu time used" not works properly
> http://news.povray.org/llj84uk2findr74u9jpge6dlteqf19c70o@4ax.com
this is not fixed in beta 15
when +GAout.txt is used then cpu time not appear in stream
ABX
