POV-Ray : Newsgroups : povray.beta-test.binaries : FYI: radiosity changes integrated Server Time
1 Apr 2026 23:57:34 EDT (-0400)
  FYI: radiosity changes integrated (Message 1 to 10 of 17)
Subject: FYI: radiosity changes integrated
Date: 17 Jan 2009 07:55:01
Message: <web.4971d497997e4df5195cc4820@news.povray.org>
this image shows a detail of a building rendered in Beta29/30 and Beta30rad1.
The whole rendering shows the complete building and has a resolution of
W4500xH3000.
Settings are equal except nearest_count and low_error_factor at the suggestion
of clipka:
radiosity
 pretrace_start 16/image_width
 pretrace_end 2/image_width
 count 500
 error_bound .1
 //nearest_count 1
 //low_error_factor 0.5
 recursion_limit 1
 normal on
 always_sample off
On Vista64
QuadCore @2.66GHz
the rendertime was 23min with Beta29/30
and 220min with Beta30rad1.
Another rendering from another side took 41min with Beta29/30
and 695min with Beta30rad1 (and was the reason why I hadn't enough patience to
use the XP32 machine with Core2Duo @2.4 ;). I've cancelled the process, after
making sure that the speedcomparison was as usual.)
As I mentioned in povray.beta-test the output looks better in b30rad1, if you
look for example into the opened window or under the roof.
Full of hope
TomAust
Download 'beta30_beta30rad1.jpg' (574 KB)
Preview of image 'beta30_beta30rad1.jpg'
Subject: Re: FYI: radiosity changes integrated
Date: 17 Jan 2009 09:15:00
Message: <web.4971e6efbea0b42d1c9be6790@news.povray.org>
"TomAust" <aus### [at] aust-manufakturde> wrote:
> Hi,
> W4500xH3000.
> of clipka:
>  //nearest_count 1
>  recursion_limit 1
> On Vista64
> QuadCore @2.66GHz
Are you aware that commenting-out the nearest_count setting gives you a default
value of 5?
Anyway, this starts to seriously bug me. From my test renders I had the
impresson that serious slowdown occured only at higher recursion_limit values,
not with single-bounce shots. Now all reports coming in seem to indicate
otherwise.
Blood-stained excrements of a male bovine.
I can imagine only one thing that could cause this difference in a single-bounce
shot: Effective trace depth.
What are your global trace_limit and adc_bailout values?
(Would you be willing to disclose the scene file so I could do some toying
around with it? If public posting is not an option, you might send it to
christoph <at> lipka-koeln <dot> de.)
> Full of hope
> TomAust
Yeah - I, too, hope to be able to find the cause of those slowdowns... obviously
they're more serious in practice than I expected, so the status quo is
unacceptable.
(BTW, the building looks strikingly familiar - I fancy that I've seen the
original somewhere in the south of Cologne... Zollstock maybe?)
Date: 17 Jan 2009 10:45:01
Message: <web.4971fcc1bea0b42de089b5cb0@news.povray.org>
> > Hi,
> > W4500xH3000.
> > of clipka:
> >  //nearest_count 1
> >  recursion_limit 1
> > On Vista64
> > QuadCore @2.66GHz
> value of 5?
Of course, I commented out these two points only for the rendering with
Beta29/30, which was the last run.
> otherwise.
Oh, I really don't want to injure you, you are my hope! ;)
Hm, where is my dictionary?!
No special settings here, in fact not set at all, so they are default.
Yes, of course, but with many, many incs, declarations, macros, etc. and a bunch
of selfcreated fileendings - perhaps a reason for the slowdown?
So I should use your mailadress.
The renderings are visualizations for a planned building in Bonn (so another
point to keep it in confidence) and mostly architects are pretty influenced by
mainstream... ;)
But what a coincidence, neighbour!
Greetings from Bickendorf, not as bad as its reputation!
Date: 17 Jan 2009 12:43:45
Message: <497218d0@news.povray.org>
  Why is everyone comparing the radiosity of Beta 30 with the newest
radiosity version?
  Unless I'm completely mistaken, the radiosity code in 3.7 beta
versions <= 30 was, by all intents and purposes, non-functional and
certainly not intended to be used for anything. The code was just
provisionally there to give *something* (rather than eg. just crashing
the program) but not as the intended functionality.
  What people should compare against is the radiosity in 3.6.
Date: 17 Jan 2009 14:15:01
Message: <web.49722d1cbea0b42dddc0094d0@news.povray.org>
> radiosity version?
Because Chris Cason asked for feedback about "integrated radiosity changes"
between b29/30 and b30rad1...?
TomAust
Date: 17 Jan 2009 14:15:02
Message: <web.49722d4ebea0b42dd3a05d570@news.povray.org>
> radiosity version?
Unfortunately, from what I've seen in my test renders is that there is no great
difference in speed between 3.6 and 3.7.0.beta.29 (at least when comparing pure
CPU time). This is because the radiosity code wasn't so dysfunctional after all
- it was just broken, but that didn't influence speed much.
So the drastic increase in reder time does worry me.
Date: 17 Jan 2009 14:34:35
Message: <497232cb$1@news.povray.org>
I agree with Warp, since we are not only concerned with speed but the
quality of the output. Being the last release build, 3.6 is the standard
against which any changes should be measured.
"clipka" <nomail@nomail> wrote in message
news:web.49722d4ebea0b42dd3a05d570@news.povray.org...
>> radiosity version?
> great
> pure
> after all
Date: 17 Jan 2009 14:56:13
Message: <497237dd@news.povray.org>
  If the speed (when rendering with one single thread) stays the same as
in 3.6 but the end result has less artifacts and higher quality, the
situation is a complete win.
Date: 17 Jan 2009 16:39:10
Message: <49724ffe@news.povray.org>
> radiosity version?
On a personal level, I'm pretty happy with beta<=30 radiosity. I can see
where it can be improved somewhat, of course. I would be very unhappy if
the render times got higher and higher with each new release. I would be
worried that it might stay slow :S
I don't think it's as dysfunctional as you say it is. There is an issue
with render-block-sized squares showing up sometimes, but changing
pretrace_end to a lower value makes those artifacts vanish. Black
patches show up also, but lowering adc_bailout fixes that problem (as
long as it's not caused by reflecting or refracting objects).
The quality, the speed, or both? If I can still squeeze artifact-free
radiosity out of pov.b.3.7, I'll be happy. As long as it doesn't take
too long, of course.
I think if the POV-team is going to pursue a higher-quality radiosity
implementation at the great expense of speed, there should be an option
to use the old "broken" 3.7 radiosity if desired. But clipka seems to be
concerned about the speed as well, so I probably have nothing to worry
about :)
Sam
Date: 17 Jan 2009 17:50:01
Message: <web.49725f93bea0b42dd3a05d570@news.povray.org>
> about :)
Rrrrright!
Radiosity is just about slow enough as it is (um, well, I mean, was in 3.6). I'd
have accepted a slowdown of something like factor 2 as a price for artifact-free
renders, because it would probably mean that old quality would be obtailable at
old speed by choosing different settings. But we're talking about factors of 10
or more.
I won't accept anything that looks like you can't get the same quality as 3.6 at
roughly the same speed.
