POV-Ray : Newsgroups : povray.beta-test.binaries : Playpen idea for povr -1 to 1 seed patterns. Server Time
17 Mar 2026 21:18:22 EDT (-0400)
  Playpen idea for povr -1 to 1 seed patterns. (Message 1 to 10 of 20)
Subject: Playpen idea for povr -1 to 1 seed patterns.
Date: 11 Oct 2020 14:14:51
Message: <5f834b9b@news.povray.org>
While thinking of deleting the quilted value pattern, started to toy
with the idea of replacing it with a seed pattern having values in the
function_interval range of -1 to 1.
The wave shape modifiers have been extended to support +- function
values, but to make use of them without some seed, you need to create
functions as input.
What if we had one or more seed or base patterns aimed at being fuel for
more complex patterns?
Idea thus far looks promising.Two images attached. One showing the
concept from seed pattern through to more complex patterns derived from
it. The other a larger fall color image using the technique.
A - The seed pattern on a y plane. Negative values as red and positive
values as green. The black between the near 0 values.(using
function_interval)
B - What is in A, but used directly in an isosurface.
C - Combining two of A in an average pigment. (function_interval)
D - Pattern of C as an isosurface.
E - C pattern (adding sine_wave along with function_interval)
F - Using E in an isosurface.
G - Adding six more rotations of A to the C average pigment.
H - G using the modified povr cubic_wave (selection) functionality.
I - H adding phase -0.1 to shift the colors toward negative red.
J - H again with phase +0.1 and adding some turbulence.
K - J adding the povr wave inverse wave keyword.
L - J made more turbulent. Adding a light to the scene.
Bill P.
Download 'seedpattrnstory.jpg' (438 KB) Download 'fallcolors.jpg' (285 KB)
Preview of image 'seedpattrnstory.jpg'
Preview of image 'fallcolors.jpg'
Subject: Re: Playpen idea for povr -1 to 1 seed patterns.
Date: 12 Oct 2020 07:25:38
Message: <5f843d32@news.povray.org>
One more isosurface image using something similar to L to displace a
surface.
It reminds me a little of a tunnel I once traversed. A tunnel created by
blasting through solid rock.
Bill P.
Download 'hmmhmm.jpg' (295 KB)
Preview of image 'hmmhmm.jpg'
Date: 12 Oct 2020 10:15:11
Message: <5f8464ef$1@news.povray.org>
One more. I had thought I could create another image where I scale the
seed derived pattern very small creating a really good stress tests for
the am3 anti-alias mode.
Since that set of cases am1,am2,am3 cases making sure there was no
overall color shift, I've been carrying this a the am3 mode really worth
much over heavy am1/am2.
It's valuable here. Fed the input on the left (no AA) - there is  much
more 'line-ish' detail below what is seen. The am3 mode came out quite a
bit faster than am2 for equivalent threshold and depth. The fixed am3
and confidence set at 0.98. Resulting images not identical, but very close.
3 minutes 56 seconds (236.791 seconds)   am3
Pixels: 490000 Samples: 425852553 Smpls/Pxl: 869.09
5 minutes 30 seconds (330.180 seconds)   am2
Pixels: 521284 Samples: 531634923 Smpls/Pxl: 1019.86
869.09 -> 1019.9 ---> 17.35%
236.8s -> 330.2s ---> 39.44%
Bill P.
Download 'am2vsam3.jpg' (131 KB)
Preview of image 'am2vsam3.jpg'
Date: 13 Oct 2020 04:13:51
Message: <5f8561bf$1@news.povray.org>
On 10/12/20 10:15 AM, William F Pokorny wrote:
> I've been carrying this a the am3 mode really worth much over heavy am1/am2.
Argh... Should have read something like:
"I've been carrying this doubt whether the am3 mode really worth much
over heavy am1/am2."
With the example posted, it's the best choice.
Bill P.
Date: 14 Oct 2020 15:05:41
Message: <5f874c05$1@news.povray.org>
And should add another very good reason to keep - and use - aa method 3
is the stochastic seed capability. This lets us get a repeatable aa
method 1, 2 type result without the randomness of the jitter in methods
one and two.
Bill P.
Date: 19 Oct 2020 09:20:07
Message: <web.5f8d91847d75f86cd98418910@news.povray.org>
So just to be clear: The image on the left is with NO AA, and the image on the
right is with the stochastic am3 method? That looks really good.
> one and two.
So it seems to be the best thing to use for AA in animations... although there
are two notes in the documentation:
"Conversely you can produce exactly the same output each time. See also:
Stochastic Seed."
That sounds good. But...
"Note: The jitter sequence is also affected by the actual image content, and
will thus always differ between the frames of an animation."
If I understand this correctly, it makes me wonder if there *would* be a
visually noticiable jittering when using the am3 method. I guess I need to try
it, to see.
Thanks for these tests.
Date: 19 Oct 2020 09:55:02
Message: <5f8d9ab6$1@news.povray.org>
> it, to see.
Good
Good question! I don't believe jitter is used in am3, but I did not test
that belief. Let us know what you find.
Bill P.
Date: 19 Oct 2020 17:30:00
Message: <web.5f8e045f7d75f86cd98418910@news.povray.org>
> > it, to see.
I just tried to test it, but it's throwing an error.
I'm running the latest v3.8 development build in Windows, but it does not accept
the   Antialias_Confidence=  keyword in my quickres.ini file(!)
[1280x960, AA special]
Width=1280
Height=960
Antialias=On
Sampling_Method=3
Antialias_Confidence=0.98  <------- not accepted
Antialias_Threshold=0.05
I tried instead to use +AC0.98 on the command line, but it does not work there
either. I don't know what I'm doing wrong. Help!
Date: 19 Oct 2020 17:55:00
Message: <web.5f8e09b27d75f86cd98418910@news.povray.org>
I forgot to mention that Stochastic_Seed (or +SS) is not accepted either, in
either location.
It seems that v3.8 in Windows is not recognizing those terms. :-(  If I leave
them out completely, I AM able to render-- but without the Stochastic_Seed
mechanism, I can't do a 'thorough' animation test for possible jitter.
Date: 19 Oct 2020 18:30:00
Message: <web.5f8e13487d75f86cd98418910@news.povray.org>
> either location.
I did an animation test anyway, by simply leaving out the two terms.
my .ini file:
Width=1280
Height=960
Antialias=On
Sampling_Method=3
Nothing moves in my scene, or the camera; just static animation frames. I took
two consecutive frames into Photoshop, 'differenced' them, and exaggerated any
possible defects. And I don't see ANY difference between the two images-- no
out-of-place pixles at all. :-) Perhaps Stochastic_Seed is already 'on' by
default in the Windows version(?). In any case, the renders are beautifully
antialiased, and consistent.
Perhaps a *moving* camera might show something-- but any am3 difference from
frame to frame would be hard to verify by itself, since everything else is
slightly changing as well.
