POV-Ray : Newsgroups : povray.beta-test.binaries : v3.8 Isosurface artefacts test case. Windows/OSX confirmation? : Re: v3.8 Isosurface artefacts test case. Windows/OSX confirmation? Server Time
19 Mar 2026 01:51:02 EDT (-0400)
Date: 13 Oct 2019 17:15:00
Message: <web.5da392ff6caf17cdfeeb22ff0@news.povray.org>
hi,
William F Pokorny <ano### [at] anonymousorg> wrote:
> >>>> Perhaps, finally, a good test case for isosurface artefacts I've worked
> >>>> around for years! Confirmation Windows / OSX showing similar artefacts
> >>>> would be useful. Linux users not on Ubuntu 18.04 too.
> >>> same artefacts (identical looking) on a Slackware box, using
> >>> 3.8.0-alpha.10013324.unofficial.
> >> Thanks jr.
> > pleasure.
> > (am dismayed -- riled, actually -- that no Windows/Mac users found the few
> > minutes it took, apparently)
> :-) Ah, everyone is busy and focused upon what they're focused upon. I'm
> bad at even minor task switching/juggling. Plus! Could be they see the
> man off wandering in the weeds - as a man off wandering in the weeds.
quite the image..  </grin>
> The code involved makes use of abs/fabs, min, max and the like.
> Behaviors of which - especially when you don't get the expected C++
> standard library version(1) - can be different.
> (1) - As happened with vector.h abs() use when linux users initially
> tried the v3.8 user defined camera. The immediate fix was to use fabs(),
> but on my to-do, someday, list to look at vector.h more closely. I
> suspect it still the case we are getting the c99 math functions in
> vector.h and not the standard library versions due cyclic includes, but
> maybe not, and maybe I should stop looking for weeds to whack.
> Related to (1): Had the thought to perhaps enforce std::abs, std::min,
> std::max use over bare abs/fabs ?/..., min, max names enabled with
> 'using...' statements in coretypes.h & types.h. These in particular are
> known to have MS VS to other compiler implementation differences.
in a way I'm surprised that POV-Ray does not contain its own low-level maths
library, I'd have thought that an advantage.  so, I wonder (not knowing the code
base + off the top of my head) whether collecting various low-level routines
into a "convenience" library included with POV-Ray would not help with platform
independence/"implementation differences".  libraries like the GSL (see
attached) are highly optimised and easily wrapped/"plundered".
regards ,jr.
